FCSP Software Version 2.500.34-ford.27+26-08
Just checked my version after getting caught up on this thread.
It's now at 2.500.34-ford.36+26-28.
So between Tuesday or Wednesday and today it updated.
When I tried to connect to the FCSP it did the usual "sorry, can't find the FCSP" once and then I was able to connect.
Will keep an eye on things and see if anything else happens.
Did you do a power-cycle of the FCSP just prior to this improvement?
F150Redux
Daniel
2025 F-150 Lightning Lariat
Computer Geek
My last FCSP power-cycle was Tuesday late morning.
The only improvement I see is that the software was updated. The "sorry, can't connect" issue is about the same as it has been since I added the extra Wi-Fi mesh node in the garage. It connects much more often than it still did before, but I still get the issue once in a while.
I wish I knew when the update installed. I had been keeping the truck unplugged, but I had to charge up Thursday night, so it was plugged in from about 6-7PM Thursday night until Friday afternoon.
Interesting, I'm "hoping" in one hand that a spurious download would fix my system, to date that hasn't happened, still unable to log in to see what the version status is, the truck still charges.
rdr854
Northern Virginia
If only I could connect to my FCSP.
It's still reachable from within the Ford app so I can see usage and the like; but I cannot access it via the Charge Station app regardless of the number of resets of the FCSP I effect.
Same here! Interestingly enough, it works well with my Volvo,EX90, but consistently faults out with the Lightning - although it will eventually charge to 80%. I have tried other public Level 2 chargers with no issue.
Aminorjourney
Nikki
Internet
www.transportevolved.com
2023 F150 Lightning Lariat, 2017 Chevrolet Bolt EV, 2006 Vectrix VX-1
More data:
I've been working on this for the last day, and it looks as if Ford or Siemens has shut the door on folks wanting to get their own data out of this unit.
The Bootloader exploit has been nuked. A USB Ethernet dongle doesn't register. And until someone figures out the way around it, the latest software is something I can't get to behave.
Personally? I have my secondary 'rescued' FCSP now offering its motherboard to my outside charging duties. I will install an ethernet, socket, and I'm making *progress* getting full local control (without the flaky Siemens/Ford stack or Internet).
But yeah, if you want to keep your FCSP working and what you have working, consider blocking it temporarily from the Internet, and/or doing the root method if you're so inclined and have the knowledge to do so.
My wife (a software engineer turned manager/scrum master/project owner) says that "What someone can make, someone can break".
I live by that ;)
K6CCC
Glendora, Calif.
No changes here. FCSP charges the truck fine. I can use the Ford app to change the Charge Station Max Charge Current and the change is reflected in a charge session. I can not read power from Insights from a charge session since last week. In the Charge Station app, I can see my FCSP, but can not connect to it. I can however ping the IP for the FCSP from my phone or computer.
Jim657
Guelph Canada
23 F150 Lightning Lariat , 22 Mach E GT
My charging session started 35 minutes ago and the FCSP is showing transferring power (green) in the fordpass app now. My charging rate is the normal 17.3 kw. Definitely something is up.
I have the same issue. Showing transferring, even though I don’t have that set up. Also can’t see the version number anymore through the Ford app. Not sure when that went away. The other night the station was charging at 1 kW to 8 kW normally it charges right at 17. Not sure if it’s related or not.
Ford F-150 Lightning FCSP Software Version 2.500.34-ford.27+26-08 IMG_9132
K6CCC
Glendora, Calif.
You don't. That you see in the Charge Station app.
Jim657
Guelph Canada
It used to be located in the Ford app under Charging Station. I used the Charging Station app initially to set it up, but I deleted it afterward. I guess I’ll have to download the other app if I want that info now. Thank you.
Ford F-150 Lightning FCSP Software Version 2.500.34-ford.27+26-08 IMG_6036
Ford F-150 Lightning FCSP Software Version 2.500.34-ford.27+26-08 IMG_6038
Jim Lewis
San Antonio, TX
@Jim657 , I wouldn't worry too much about how the FCSP firmware you have now behaves. Based on your post, you are probably at least a version or two behind the latest that's out now and as your image shows (see below), you have a firmware update pending.
Ford F-150 Lightning FCSP Software Version 2.500.34-ford.27+26-08 1787194837997-f3
Ok, time for an update:
Good job. Ford should hire you folks!
Ford/Siemens have the primary duty to fix these FCSPs their OTA locked us out of, that's for certain.
But they could make you an authorized repairer and pay you for it.
I'm sure there are a lot of us who would gladly send you our FCSP's for a warranty fix. :)
I'm also a big fan of the right to repair.
It can get dicey legally with software when it comes to vehicle and related equipment warranties.
My limited understanding of it is...
The Digital Millennium Copyright Act has an exemption from copyright claims for vehicle software modifications for "diagnosis, repair and maintenance," as long as not tampering with emissions controls or other regulated requirements.
And there is nothing that prevents the vehicle manufacturer from putting lock-outs in however, and/or refusing to honor warranties if the 'repair' can be linked to the damage in the warranty claim.
Vehicle owners and authorized repairers are however allowed to bypass the lockouts for allowed purposes.
Also, the FCSP should be considered exempt under the "home electrical system or appliance" exemption also allowing "diagnosis, maintenance or repair."
How far can you go with "diagnosis, maintenance and repair" is a question.
Adding new functionality could cross the line.
Electrical code regulations come into play with EVSE's as well.
Something we will be grappling with for years to come.
PS: I appreciated your acknowledgement of native peoples at the close of your video. One of my ancestors was a Unami (Turtle clan) of the Lenni Lenape tribe (meaning the 'men of men' or 'original people') woman born in 1706 who married a European immigrant/settler who lived peaceful with the indigineous people of the area (New England).
