- First Name
- CHRIS
- Dec 16, 2022
- alexandria virginia
- 2023 F-150 LIGHTNING, 2012 Nissan Leaf, 2015 Toyota Prius, 2000 HD 883 Sportster
- Occupation
- Patent Atty / Electrical Engineer
Yes, it is puzzling.possible. the meter seems fine, and the entire unit/circuit has been working for over a year. i didn't use it for about 2.5 weeks in cold weather, and then started using it and it failed towards the end of its first charge. odd way to fail? idk.
If it is the power source/wiring...
Breakers can fail - was it brand new when installed?
They have a lifetime, and they are not all created equal, unfortunately.
And wires over time can become loose in their connection terminals from expansion and contraction as they are heated by current and then cool down afterwards, especially at higher currents.
That is why torquing to the specified amount is so important when connecting, both at the FCSP and at the breaker end of the wire.
The torque for the breaker is usually should be printed on the breaker itself.
