✅ 11/21 Lightning Build Week Group (MY2023)
wingfiry
Ryan
Cleveland, TN
2023 Lightning Lariat ER
My order is Scheduled for production next week 11/21 (Lariat ER). I had thought that I would have seen a blend date and window sticker by this point, but nothing yet. Anyone else having similar results?
Take a look at your ford.com online order/reservation, you might see a change in the build week, possibly to 12/5 or later. If it has not changed, then possibly you have a typo on the VIN your searching, welcome to share it with me in a DM so I can verify., or you can try validating it with this utility --- Check Digit Calculator
jsnowball81
Austin, TX
2021 F250
Following up on what @TaxmanHog suggested. Your VIN may have changed due to the switch from All-Season to All-Terrain tires. If extract your VIN from your order status page again you may find that it is different from the email for sent and/or previous status results.
wingfiry
Ryan
Cleveland, TN
Come to think of it, that tire change is about the time is stopped working. Do you have a link to the details on getting the VIN by chance?
jsnowball81
Austin, TX
2021 F250
This is the method I used and it got me squared away. Credit to @REDHORSECA and @TaxmanHog
  • Firefox
  • Login to your Ford.com/ MY ACCOUNT/ go into your Lightning "Reservation & Orders" page
  • Click "View" to see your Lightning's configuration info "YOUR ORDER"
  • Make sure your Lightning is "Scheduled for Production" with a build date "Week of #/##/2022".
  • [F12] to go into Firefox the browser's "Developer Tools"
  • My Firefox Developer Tools shows up on the bottom half of the main browser window. In some cases, it may take the right side of the browser window.
  • In the Developer Tools larger window, select the [Network] tab and also the [XHR] tab on the upper rows of the Developer Tools window.
  • Click inside the Browser window Ford page and press [F5] for Firefox to refresh the browser page. Refreshing the "YOUR ORDER" web page will load up data into the Developer Tools window below.
  • On the upper bars of the Developer Tools window, there is a picture drawing of a tiny funnel "FILTER" for you you to input your Order Number ########. Enter only the numbers.
  • You'll probably get 2-3 hits in the filter results window below, look for the columns [Type] JSON/ highlight that specific record.
  • When you highlight that filter result a smaller window will show itself to the side.
  • In the smaller side window [Headers] tab is probably highlighted, click the [Response] tab and data will cache in the smaller window
  • Click the "Raw" slider switch to show the raw data. This is the final step that allowed me to see my VIN#.
  • Go and click in the smaller cache window results and highlight all the data [CTRL]+"A"
  • Open a Word or Notepad document, Paste [CTRL] + "V" all the data into the text document.
  • In the Word or Notepad Search for "1FTV" (the first letter is a number one), in my search results, My Lightning VIN# was very near the top of the data dump.
  • My VIN data looked like this: "catalogId":"WANAB-TFD-2022-F-150","vin":"1FTVW1EL1NWG05xxx"
wingfiry
Ryan
Cleveland, TN
  • Firefox
That was it! Many many thanks!! My VIN changed with the tires apparently.
That was the problem, I sent Ryan his new VIN and pre-formated hyper link to his sticker.
I'm going to look a bunch of VIN's that were recently scheduled for stickers but did not generate for this revision.
An easy way to revise your own VIN, paste the original in this utility [ Check Digit Calculator ], but change the fourth digit from 6 to V, then check validation, the algorithm will propose a new check digit, replace the old check digit with the proposed value [ninth character], run the check again it should come up valid, then use that revised VIN in your window sticker query
wingfiry
Ryan
Cleveland, TN
An easy way to revise your own VIN, paste the original in this utility, but change the fourth digit from 6 to V, then check validation, the algorithm will propose a new check digit, replace the old check digit with the proposed value [ninth character], run the check again it should come up valid, then use that revised VIN in your window sticker query
Thank you both for all your help. I was concerned. ?
Thebear
Chicago
2021 F-150 XLT PB | 2023 Lightning Lariat
Just found my window sticker everything looks spot on. Super excited about how early this is being built. I was convinced I was SOL for the $7,500 rebate. There’s still hope… ?
Wsl346
Austin, Texas
Alright 11/21. It's your week. Best of luck on a speedy production and delivery. I only have two of you from the forum tracker. If you want to be added to my list, let me know.
moonwhalerNC11/21/2022Lariat
Mike DubsMA11/21/2022LariatER
Thebear
Chicago
feel free to add me.
State IN
build week 11/21
Blend date 11/23
Trim Lariat
Battery ER
wingfiry
Ryan
Cleveland, TN
You can add mine:
Build Week: 11/21
Blend date: 11/22
Lariat ER
drkeys
keys
Tampa, FL
2023 F150 Lightning Lariat ER - Anti-matter Blue
Ordered First minute when F150 Lightning was revealed, has super low reservation number but got skipped by dealer and other customers paid extra to be first.
I finally got invited to oder 2023 wave 3 (after got skipped out 2022 Wave 1-7). Build week 11/21 (original Build date was 11/23 got moved up to Blend/build on 11/21 recently).
Got window sticker on the 11/10 confirmed the dates, Today just got the Tear Tag and module as popped. 24/556 of the assembly line order for the build-week 11/21/22.
Hopefully to able to make delivery before end of the year.
Boys - keep your hopes up. --- I got 2023 Lariat ER without Bed-liner, no additional options, and (all the chip shortage stuff got removed heated steering, advanced security, and scale/balance like everybody else). This sucks but it's not a deal breaker
Ford Charge station pro from sun run already contacted to setup delivery (but i have a tesla charger will just buy an adapter for it.
Elmn8r
Logan
Up-State SC
2012 F-150, 2017 Shelby GT-350, 2022 Mustang MachE
You can add mine:
Build Week: 11/21
Blend date: 11/22
Lariat ER
