- First Name
- CHRIS
- Dec 16, 2022
- alexandria virginia
- 2023 LIGHTNING PRO, 2012 Nissan Leaf, 2015 Toyota Prius, 2000 HD 883 Sportster
- Occupation
I am still on my original 12v battery in my 2012 Leaf (delivered in DEC 2011).12v batteries have been the weak link for basically every EV. I went through two in 10 months when I had a Rivian (under warranty fortunately). If yours is a few years old then definitely prepare to have it replaced. Some people get lucky and it goes out slowly, while others are left stranded without warning. I've experienced both!
I keep it on a plug-in trickle charger in my garage when not in use.
Also, I never run the AC or heat but I do use the heated steering wheel and heated seat in winter so I don't drain it all that much when I drive, just the usual vehicle computer and maybe an iPod or XM for music.
My last ICE truck (a 2001 Ranger) had a battery that lasted 14 years (a Ford 100 month battery), also on a trickle charger but it was on a little solar panel that sat on the dash (pointing south btw) and plugged into the cig lighter/acc plug. From what the manual says, it cannot/should not be plugged in that way to the Lightning:
From the manual (page 182 in my 2023 MY manual):
Do not plug in any device that supplies power to the vehicle through the
power points. This could result in damage to vehicle systems.
On the other hand, the little battery in our 2005 Prius had to be replaced twice in 10 years.
Our 2015 Prius is still on the first battery. I read that some people use 12V wheelchair AGM batteries in their Prius' because they are about $60 and fit nicely - Toyota wants $200 for theirs! So that will be my choice when the one in the Prius goes...knock on wood.
The bottom line is 12V lead-acid batteries last longer if they are kept fully charge most of the time, hence the trickle charging (a $40 item compare that to the cost of a new battery). Yes, AGM batteries are lead-acid batteries.
Ford does not make it 'easy' to trickle charge the one in the Frunk of course...leaving Frunk open is not convenient/safe unless you can do it in a garage, and some say leaving the Frunk open uses battery, haven't verified that though.
I haven't gotten around to running a wire to a more convenient place like inside the cabin for a dash solar trickle charger and those might not get up to the voltage AGM's prefer to float at 13.8 or so, although I think there are some designed for maintaining AGMs.
