Implausible Range Estimates after power cycle?
kubel
US
2024 Ford F-150 Lightning Flash (+9.6kW PPO, Max Tow)
Does the truck normally recalculate incredibly pessimistic range estimates after power cycling (5 minutes off) at a lower state of charge?
I was getting 1.4 mi/kWh (carrying a big load, I'm ok with that efficiency), was around 46% SoC, guess-o-meter was saying somewhere around 70 miles and it was about 44 miles to the next charging station, so I was confident I could get to the charger. I stopped at a rest area for 5 minutes, and came back to a range estimate of 41 miles, not enough to get to my next charger. Nothing changed, just 5 minutes powered off.
I had to double back and charge at a closer slower station, and I that's when I took this picture of the dash. 34%, 31 miles estimated, 1.4 mi/kWh. It doesn't come close to adding up.
Ford F-150 Lightning Implausible Range Estimates after power cycle? photo_2024-10-28_15-59-21
Ford F-150 Lightning Implausible Range Estimates after power cycle? photo_2024-10-28_15-57-05
Could you update your vehicle data, year trim battery?
It's calculating as if an SR battery but worse.
Does the ATV ramp have lighting that's plugged into the 4 pin trailer hitch?
Does the truck think your pulling a trailer, I'd switch that off.
Ford F-150 Lightning Implausible Range Estimates after power cycle? 1730152183019-g
kubel
kubel
US
Updated profile, this is a Flash (LR battery). Mad Ramps do plug into 4-pin, but trailer is not enabled and I got correct range estimates with it plugged in earlier and later in the trip. It was only after the 5 minute power down. Could it have defaulted to a trailer enabled on power up and I didn't notice? Is there normally an indicator on the dash (other than cross traffic disabled) that indicates a trailer is enabled?
One thing I thought of after the trip is I should have enabled a trailer on this trip so it remembers my efficiency in the future with this setup.
tubby
Press
Iowa
It's like the onboard bed scales are calculating a high weight in the bed. Oh wait, most of us never did get bed scales, so we have no idea how they work. :)
You can't trust the range estimate. Stick with math, it won't lie to you.
131kWh * .46 * 1.4mpk = roughly 84 miles.
I think you would have been fine to continue, assuming you are able to maintain that efficiency. Around 25% is what would have been required to go the 44 miles. You can always slow down even more if your efficiency drops.
I can't remember if there's something to let you know about reduced range, but I would not be surprised if the truck powered on and "saw" something connected to the trailer port and reduced range. That's a bummer you ended up doubling back. I think setting up a "trailer" profile for that setup is a good idea. Keep in mind when you are in tow/hual drive mode, it will turn on battery conditioning which will use up a little extra power and might impact efficiency. If you don't need the battery conditioning it should be more efficient to use normal mode.
