Ajzride
Hey all, I've had my 3x installed and running with no issues on my '23 XLT for the past year with no issues, until the past few weeks. I started getting a "Canbus disconnected. Likely faulty cable error" message on the comma sporadically, and the truck would throw camera and parking sensor errors at the same time. I could usually disconnect my comma (I have a 3D printer and printed a quick-disconnect mount similar to the one Ajzride has designed), then reconnect it, and it would usually come back up and work fine. But, recently, that has not been the case.
I have a Ford Q4 harness that I modified (cut and soldered in an extension). I assumed it was a bad solder joint because when I disconnected the comma, all the errors the truck was throwing went away.
I've taken the harness out, desoldered/resoldered all the connections I made with the extension, to no avail. I'm at my wits' end on this one. I'm not sure what to do at this point other than order a new harness and adapter to try it.
I have probed all the pins on the harness I have, and I have good continuity across all conductors, including the pairs with resistors to prevent start-up errors.
I have also tried swapping out all the USB cables from the harness box to the comma and eliminating all adapters to no avail.
I'm at a point now where the truck is throwing errors when the harness is plugged in, regardless of whether or not the comma is connected on the other end. The only thing I can think to try at this point is to order a new Q4 harness and the lightning coupler to try that combo.
Any help on this would be greatly appreciated.
It could be the actual harness box. Based on the time frame, you probably have the old style harness box with a mechanical relay. Honestly the best path forwards is to order a new Q4 harness kit and the coupler. This will get you the new style harness box which is solid state instead of mechanical, along with the automotive grade resistor coupler that Uncle Tony designed, which is far more robust and much more balanced for the system than the resistor design I initially made a video on installing.
