chriserx
Louisiana
Does the comma go offroad when the truck is turned off? Or does the road cam stay on the screen?
Road cam stays on the screen, I've caught it red handed twice just because I happened to be walking by the truck with it off. Could potentially be a bad cable, I am using the stock comma cable, and it did give me problems initially.
UncleTony
Tony
2023 Lightning Lariat
Cybersecurity Engineer
If the road cam stays on the screen, it is likely falsely detecting ignition like you are thinking. My first guess would be your harness or harness box is having an issue.
Ajzride
Alan
Houston
Eng
correct. I misunderstood the initial comment.when I had problems with the device not shutting off it was my harness box.
chriserx
Louisiana
Either direction, ignition on or off, i want to narrow it down, I'll keep looking for any logs I can, are there any SSH commands to view the CAN bus live? My gut says probably not since the traffic volume is likely pretty high but figure I'd ask anyway
UncleTony
Tony
You would need to setup an open pilot dev environment to view the logs.
This can help you get started.
https://github.com/sunnypilot/sunnypilot/tree/master/tools
Not to discourage you from going down that route, but its only $100 for a new harness and you can return it within 30 days if its not your issue.
Reactions: EVO
chriserx
Louisiana
I've already enabled ADB and SSH even though I don't particularly care for the way they do SSH key exchange. I'm sure it's fine though. On bp-4.0 I wanted to see if experimental mode had improved any since installing on the Corolla so I added the 2025 to the fingerprint list. Didn't care for it so turned it back off. bp-5.0 is looking pretty good so far though.
EVO
Randy
2024 lightning flash
electrician
Tried to install 5.0 I get a SSH Authentication Failed. Under updater it says updates disabled SSH error. AJ can you save me again since apparently this areas server is broken.
Ajzride
Alan
Houston
Eng
Anthony is working on it right now, it is not specific to you at the moment.
Reactions: EVO
Ajzride
Alan
Houston
Eng
If you are Eric Meek and you submitted an order for a dock, please send me a DM, I can't reach you on email.
Ajzride
Alan
Houston
Eng
bp-5.0-beta should be back online for installs now.
EVO
Randy
electrician
It doesnt show under select branch and I`m still getting ssh failure
mmarchand
Matt
I was able to get BP 5.0 installed yesterday. I was experiencing some ping pong on the highway and was hoping 5.0 would resolve this, but that doesn't seem to be the case. Is there a different model I should try or is there a specific setting I can slowly adjust to try to reduce?
Ajzride
Alan
Houston
Eng
How can we tell you to try a different model if we don’t know which one you are on?
mmarchand
Matt
Sorry, didn't know if there was one specifically meant for 5.0. It's just on the stock one that loaded with 5.0, Firehose
