vandy1981
Tennessee
Plumber
Consolidated window stickers for Pro SR, Pro ER, Lariat ER and Platinum. I couldn't find any XLT or Lariat SR window stickers on the vehicles that were listed on Auto Trader. Someone with more time may be able to find them by randomly entering VINs.
Also forgot to mention that the 3/25/22 was the latest blend date I saw on the window stickers I found.
Would indicate that stickers are getting issued around a week before the blend date. I think this is in line with the ICE F150 process.
Reactions: GDN
shutterbug
Joseph
Phoenix
Unless you need that extra 10-20%, it's still best to keep it at 80%. It's better for battery life, but for me, it's mostly about time.
Mach-e is ~40 minutes from 10-80%
It'll take 20 minutes to go from 80-100%.
Unless that extra 10-20% is getting you to your destination, it's probably just better to move along at 80%.
For ioniq 5 @ 800v, it's
10-80% @ ~20 minutes, and 80-100% @ 20 minutes.
In the 2021 MME 4X models, after hitting 80% the charge rate slowed to 9-15 kWh. After CSP 21P22, the drop happens after 90% SOC. So originally, charging from 80% to 100% took well over an hour. After the update it takes about 10 minutes to charge from 80% to 90%. My experience has been that charging from 20% to 80% took about 45 minutes.
Oneand0
Mario
South Lake Tahoe
Digital Investigator
And a Pro ER with 320 miles of EPA range!!!
So then a Lariat ER the same!? 320 would be nice, that’s what I’m getting with my Model Y, so I shouldn’t feel a difference with my driving routine.
Vorador
F150 Lightning, Ford Escape
Well it will take longer to charge at home and longer to DC fast charge on trips. But as long as you don't drive too far each day, you probably won't notice the extra charging time.
beatle
Springfield, VA
Might be just a touch lower with 20" wheels and the fixed running boards that come on the Lariat. I'm expecting something between this and Platinum due to the efficiency penalty of 22" wheels.
Amps
Mid-Atlantic
Bolt
There is no dual plug, that would make no sense.
To me, having access to a charging port on both sides of an EV makes abundant sense. Especially, if you envision the near-term future of DCFC real-world experiences and poorly located charging ports. And 'more especially', if you are towing. It would probably be even more convenient for home charging.
The world had this one chance to standardize delivering a new transportation energy infrastructure. Instead, we're going to have a wild west of 'wrong way' vehicles at busy chargers trying to get to cables that force them to try to go against the tide of other vehicles. When it's charging, each vehicle gums up the flow for a lot longer time than adding gasoline.
LightningShow
MA
'22 Lariat ER
Product Development
Yup, every EV should have charging ports on both sides. Especially higher end EVs where the cost is justifiable.
If it was an option, how much would you be willing to pay for it? I might pony up for a few hundred, but I suspect it would be in the thousands.
Oneand0
Mario
South Lake Tahoe
My Y has the 20” induction wheels and gets about 320 to 323. Even at 300 with a LARIAT, I’m happy with that. But that little extra is nice when it comes to EVs. It’s going to be interesting. I get great mileage when I set the cruise control at 65 and take my time in the slow lane getting where I need to go, which is half the time. The other half, no way Jose, my mileage goes out the window when I drive faster (safely) for the fun of it!
shutterbug
Joseph
Phoenix
Is that like having every gas car with 2 fuel ports? Or maybe EVs with 4 charging ports (left, right, front, back). Personally I'd rather have extra cup holders, than extra charge ports ;)
Reactions: GDN
VTbuckeye
Joseph
Vermont
If we could pull up on either side then it wouldn't be a problem. It would just be nice if we had options, particularly because the vehicle will be plugged in for much longer than a car is at a gas pump.
vandy1981
Tennessee
Plumber
Does anyone know the significance of the numbers listed within the red box? I think the top number means that it was the 4663rd vehicle to start assembly and the bottom numbers are the order the vehicle was built on a particular day (153) over how many total vehicles were scheduled for that date (228).
Ford F-150 Lightning F-150 Lightning Official EPA Range MPGe Revealed in Window Sticker (Base + Extended Range)! 1647615143651
This one has the same blend date and a lower number on the top (4652) but the bottom has a denominator of 371.
Ford F-150 Lightning F-150 Lightning Official EPA Range MPGe Revealed in Window Sticker (Base + Extended Range)! 1647615317781
Can anyone make sense of this? Is the bottom number based on shift, assembly line or something else?
williams
Tampa FL
2021 Powerboost F-150
Ford Sales
This is all just "funky" EPA ev math. Until real range tests happen, whatever they note here can be taken as a rough estimate.
Rivian is the same w/ the range suggesting 281, but real world tests have it at EPA range (Edmunds tested it fully).
Same w/ Ioniq 5 as well.
Agreed my model Y said 318 range when i purchased it, after owning it 3 months that avg dropped all the way down to 261. Florida is not kind to EV vehicles with AC systems drawing significant power. At these figures Im cancelling.
FordLightningMan
Upstate New York
F150
For the SR, the figure is the same it has been since range was released months ago. For the ER, range has actually improved. Just curious, did you anticipate Ford had been lying about range for the last six months, and was going to massively improve at the 11th hour? I can get canceling an order, but this reason is the strangest one yet.
