WXman
- Aug 16, 2025
- Central Kentucky
- 2025 F-150 Lightning Flash
- Occupation
- Meteorology/Transportation
Not the same thing at all. One is moisture on the inside of the glass. The other is ice on the outside of the glass. Also, frost happens even above 0C/32F.LOL, same thing, one is >0degC.
What I want to do is simply defog the windshield, which requires dry air. In other words, compressor should be on. Doesn't matter at all which vents the air is coming out of, as long as it's conditioned air.
Now if I get ice on the outside of the glass, then yes I'll use defrost setting. That'll come soon. Getting close to November.
Negative's is that it has the worst "auto" setting I've ever had in 20 years. It's like it's not reading the drivers temp accurately. I need to crank up the temp on cold days and drop the temp on hot days.
At least I'm not the only one.This echos my experience as well, but with a 24. My previous ICE F150’s worked great. I could set 70F and leave it there all year.
Interestingly, I just looked in my 2025 owners manual and it states:
"When E-Heat is on, an electric heater warms the cabin and keeps the windows from fogging. Turning E-Heat off saves battery power, which extends your driving range. The electric heater is the only source of heat to warm the cabin."
Hmmm.....
