New BlueCruise Version 1.4 - Rollout IPMA-24.204.10.9
PACSMAN
Fred
Massachusetts
F150
I received the 1.4 update as well last night.
PJnc284
Garner, NC
I just want my percentage and amperage sliders from the 25s to work on my 23. On the bright side, it does show the charging speed on the big screen. 😁
Ford F-150 Lightning New BlueCruise Version 1.4 - Rollout  IPMA-24.204.10.9 20250608_184434
RocketGhost
Spencer
Memphis TN
2022 Lariat ER
Just went and hooked up my 12v charger to make sure it's got enough charge to take an update. Just in case I'm on the list for this rollout.
Adjusted thread title to eliminate "March 2025"
LightningStrike
Georgia
2023 Lightning Plarinum
Blue Cruise 1.4 OTA In progress now
Just started the Blue Cruie 1.4 OTA Update...said it would take up to 83 minutes....a bit nervous that it will complete successfully and not brick the truck
Update - went through without a hitch…you could hear the charger electronics humming for about 35-40 min as it started…maybe to ensure the 12v had enough juice to complete the download and start the update. It did lose 1% of the traction battery during the update
MrH42
Cincinnati, OH
2023 Lariat ER, 2024 Miata
Got the update last night. Drove to work this morning which is probably 30 miles of Blue Cruise highway.
Seems smoother? Less bouncing back and forth.
I didn't have any automatic lane change capability though. I looked in the options and didn't see the ability to turn that on at all. The update said this control will added later???
PJnc284
Garner, NC
It isn't true "automatic" which is in 1.5. You short tap the turn signal and it should change lanes. It flashes the turn signal until the lane change completes. If you're willing to tinker, you can add the toggles using FORScan but lane-change assist and in-lane repositioning should work out of the box.
MrH42
Cincinnati, OH
Thanks. Sounds like I need to get the toggles via FORScan. I thought it was strange that they push this update for BC 1.4, but then describe in the update that the toggles to actually turn on the feature is coming later. I just wanted to confirm I was interpreting that right.
PJnc284
Garner, NC
yeah it should work by default but who knows. We've seen instances where you need to disable and reenable something to get it working. And Ford has a habit of adding stuff and not give you the toggles. They did the same with WAL so if you had your BCM updated at the dealer or got the OTA they pushed out that enabled it, you got WAL by default with no way to disable it. FORScan is quite nice for tweaking things that are disabled also (e.g. matrix headlights).
F150 Lightning FORScan thread - Version 2 | Ford Lightning Forum For F-150 Lightning EV Pickup: News, Owners, Discussions, Community
rugedraw
Javier
Miami
Auto Sales
You interpreted it correctly.....the toggles come with a separate APIM update, but you can use FORScan to add them.
So the truck will not change lanes on its own if you tap the blinker - and BC is engaged, and the lane is very conservatively clear?
Anybody else getting this latest round finding that Lane Change Assist doesn't work?
rugedraw
Javier
Miami
Auto Sales
The IPMA update not enabling the config for BC 1.4 is a known issue. This is why there is another IPMA OTA that is config only that enables the features if the IPMA update that updates the firmware doesn't update the config. The config only OTA is IPMA-DC-24.204.8.27.
Good to know. I wish when folks say they got an update that they would scroll to the bottom of the release notes and say the exact release.
My BC 1.4 back in January was IPMA-24.204.10.9
