Range not close to as advertised
Brent@ANParts
Diamond Sponsor
Brent
www.autonationparts.com
Ford Bronco
Marketing
Are you in a hot area? That could definitely be affecting your range. If so be prepared for a significant range boost in the winter. If you're somewhere cold, disregard that hah!
RickKeen
Minnesota
F150L SR Pro
sw engineering manager,
Reminder, EPA EV Range ratings are based on EPA mileage measurement courses.
EPA "Highway" course has an average speed of 48.3mph.
EPA "City" course has an average speed of 19.6mph with 23 stops per 11 mile cycle.
potato
BC, Canada
2023 F150 Lightning XLT ER
This. You will get the rated range at slow speed in the city. But nobody cares about range in that situation. You will NOT get the rated range at real life highway speeds. That's just the way it is.
WaterboyNorCal
Erik
NorCal
2023 Ford Lightning XLT SR
Nunya business ;)
I’m not sure that ā€œnobody caresā€ about city range, but I get your point. All EV manufacturers should push the EPA to devise a ā€œhighway rangeā€ and ā€œcity rangeā€ rating that would be far more helpful to prospective buyers.
I average 2.1 miles/kWh on the highway at 70mph, which means I get about 200 miles of ā€œrangeā€ in my SR Lightning. Around town, I average 2.7 miles/kWh, which would translate to a ā€œcity rangeā€ of about 260 miles. The truck has an EPA range estimate of 240 miles. Then there’s the issue of ā€œwinter rangeā€ā€¦ ?
The solution is all about infrastructure. If we had more DCFC stations, especially along rural highways, people would be more likely to get over range anxiety. Not sure if we will get there in my lifetime. I used to think that we were close, but recent events have made me question whether or not Americans want to transition from ICE vehicles.
Jackdforme
Barry Allen: 2025 Ford F150 Lightning Flash
Just reset the BMS then drive it and don’t think twice about range. If you got slightly less gas mileage you’d carry on with life. It’s such an EV thing.
Small point of clarification...in an EV there is little to no loss of efficiency when accelerating quickly. The reasons a gas vehicle are inefficient while accelerating quickly - low gearing, non-optimal RPM, rich fuel/air mixture, etc - don't apply to an EV.
RickKeen
Minnesota
F150L SR Pro
Also the regen during during the stopping proceeding the acceleration.
Hybrids have these same advantages to some extent.
jefrank
Jeff
Fenton, Michigan
I wish!
I may get 2.0-2.1 on the hwy at 70, but somehow it always seems like the headwinds shift on my roundtrip so that I only end up in the 1.8-2.0 range. People say Michigan is flat and windless, my range numbers tell me otherwise. lol
Rip
Rip
Southwest Harbor, ME
2024 Lightning Platinum
Quality Consultant
My quick rule of thumb is:
Summer = 2.5 kw/mi
Winter = 1.8 kw/mi (temps below 45F)
Towing = 1.0 kw/mi
Just take those numbers and multiple by your pack size. ER is 131kw so:
Summer = 327mi range
Winter = 235mi
Towing = 131mi
That's what I've been getting, and I live in Downeast Maine. I bought mine in the winter, and was disappointed by the 230-250 I was always getting. I looked around in here, though, and found that my Lightning was more intelligent than my Tesla when it came to those estimates...it actually used my driving habits and the temperatures to adjust expected kw/mi (and, therefore, mileage).
MaintGrl
Marsha
El Sobrante, Ca
Yes, it's all relative. I took a drive across the county (Contra Costa) on Monday, kinda warm out. It was about a 45 mile drive. I was getting 2.4m/kW, doing 70mph on the freeway, and slower in the rush our traffic (Bout 5 Miles), thought that was pretty good. BUT . . . on the way back I was getting about 1.8/1.9 m/kW. After getting it home, I realized that it was pretty windy out. So, tail wind going, and head wind returning. So the average was 2.1 m/kW which is .1 below my average (2.2). I'm ok with that....
EVO
Randy
2024 lightning flash
electrician
Hello
I just purchased a used 2024 lariat with 10k miles on it. It’s at 91% charge and only shows 236 miles of range. Is that normal and are there settings I should change to optimize the range. I don’t expect the full 320 but thought it would be much higher then where it is at now. Thanks!
Half my miles 40-60 mph, half 70-75mph. Winter average 1.8, summer avg 2.1
jjupi91897
Joseph
Hello
No, summer months should show a higher range estimate. I just finished charging at home. I charged to 90 percent, and it shows and estimated range of 311 miles. The estimate is pretty accurate to what I am actually getting.
Ford F-150 Lightning Range not close to as advertised Screenshot_20250709_213948_FordPass
jjupi91897
Joseph
Hello
Your driving habits will make all the difference in the world. My estimated range charging at home is great during the summer ā˜€ months. At home, I charge to 90 percent, and the estimated range goes as high as 316 miles. I don't exceed 70 MPH. I even drive around with junk in the frunk.
Ford F-150 Lightning Range not close to as advertised Screenshot_20250711_154803_FordPass
Ford F-150 Lightning Range not close to as advertised 20250711_081652
MaintGrl
Marsha
El Sobrante, Ca
Yep, you do have some stuff in the frunk! :wink:
Looks like a lil bit of everything....
HOTAS
ā€˜24 Lightning Flash, Tesla MY, Chevy Volt, PiPrius
Airbus Pilot
This is simply not true. The two biggest range killers in an EV are acceleration rate and speed. Always have been.
Limiting both will allow anyone to exceed the EPA rating .
And any notion that regen on the backend somehow balances rapid acceleration on the front end is false also.
Regen is a terribly inefficient recapture of unnecessarily used energy.
When stopping or slowing are necessary and unavoidable, regen is a Fantastic feature, but it’s much more efficient to have never
used the energy to begin with.
If everyone would limit their initial acceleration rate to no more than ’bottom of the Lightning bolt’ on the power guage, and begin to tapper back as the truck gains speeds, then consciously exploit ā€œ0 powerā€ Glides as much as possible, you would all exceed the EPA rating.
And of course limit your highway/interstate speed to no more than 70mph (or less, is better) and Inflating your tire to at least 40psi.
Now I know that some folks just can’t come to grips with changing the terrible way they are used to driving . But an EV is the only car that will reward that change in behavior with big gains in efficiency and dividends in savings. The change of mindset leads to a new kind of driving satisfaction that far exceeds making lots of noise and blowing lots of black smoke and generally stupid, rude and mindless driving.
