Thanks Ford for the improved hands-on-wheel detection; Advanced Driver Assistance System update (24-PU0105-CMR-FX)
DaveInSA
25 Lightning Flash
I doubt they will ever get it light enough for Me. I spent 1,000s hours flying Hueys and, after hundreds of hours, when I was on the cyclic flying, you would never see that cyclic visibly move (pilot technique) especially at hover when added lift was so valuable. You can actually “think’ movement when you are one with the aircraft.
I drive the same way, my kids were always amazed that going down the interstate it would appear the wheel never moved unlike their mother who was constantly moving the wheel left and right Even when going it a straight line.
The damn hands on the wheel drives me crazy because I have to “make” added inputs all the time when they just aren’t needed. In a Huey, and less so in a car, every one of those movements waste energy. In the huey that meant added lift and you could fly closer to the edge. 250lps of lift was really valuable. The added lift meant more ammo and supplies delivered or, even more importantly, that was one of our guys I could carry out of a PZ.
Completely unrelated to OP but interesting:
The F22 was originally designed so the stick didn't move at all. But enough pilots complained they had to add a tiny bit of movement to it.
Old Aviator
Larry
WPB, FL
Consultant
Well, there is a new CMR update that popped up in FDRS first for the Mach E and also for the Lightning. I wonder if this is the new version and Ford used the same OTA name?
:ROFLMAO: I have zero experience with any of this. The most complicated thing I've even flown is a 2-handed kite, and this makes perfect sense to me.
Unfortunatly Harry was mislead on one point. While its true helicopters don’t glide they can autorotate which is a form of gliding. Simply stated if all you have is an engine failure and you quickly quit trying to apply lift (lower the collective which controls blade pitch) you can fly the thing to the ground. When you do that the air going “up” thru the blades will keep then spinning (think about pinwheel on a stick it spins as air move thru it) You can control the aircraft all the way to the ground and then pull the nose up slow down and use the collective to increase blade pitch and lower the aircraft on to the ground using the stored energy from the blade inertia. Of course the rotor RPM will decrease dramatically so you need to be very precise. I have done a thousand or more of those in training and as a instructor pilot full contact to the ground and to water (on floats) from every flight condition low level, high level, 180 degree turns, etc. Once you get over the terror it’s the best roller coaster ride you have ever taken!!! So while I was never afraid of engine failure because you learn to fly always aware of where you can go if the engine fails, unfortunately engine failure was your “best case” emergency. All the hundreds of other things that can go wrong with a helicopter were the issue, some of which you might survive with great skill and others for which there was no probability that you had any input as to saving. In the UH-1 operator manual Emergency Procedures section (which I to memorize verbatim to obtain my instructor rating) the manual states “in the event of a tail rotor failure the best course of action may be to initiate an immediate autorotation, but in some cases this will only exacerbate the condition” :sadface: I should mention you have about 3 seconds to make the right decision. But I still love the damn things!!
Nikos
Nicholas
Taylors SC
F 150 Lightning
Aircraft Mechanic
I received this update on my ’24 Flash a few days ago and since then have been very pleased to experience a much improved hands-on-wheel detection setting when the cruise control is engaged. Now the pressure necessary to satisfy the sensor is just right. At least for me, resting even just one hand on the spoke with a very slight pressure on it is enough to keep from being nagged. Kudos to Ford for making improvements like this along the way of my ownership.
Agreed. Just finished my Labor Day trip to Pamlico Sound/Oriental NC, going to using the southern route and returning to my home using the northern route.
Yes…I noticed it a lot. BC/Hands free felt more refined and engaging with me during this trip. Made the 9 hour drive more comfortable, especially on this Labor Day drive home. The delays and traffic jams were numerous. BC performed solidly the entire trip home.
Stevo
Steve
Albuquerque, NM
2022 Lariat ER
I am hoping they push these updates to the abandoned 22 model year. I would sure like to see these “the truck keeps getting better” moments that other model years are getting. The last real update I remember added karaoke. Man that was a meaningful update.
OP, glad you got the update.
richguy82
Richard
2023 Ford Lightning Lariat
The idea that you even have to apply any pressure is kind of dumb IMO. This and the eye tracking are my only two major issues with this truck. I get a couple of alerts with one hand on the steering wheel just going a few miles from my house. With my wife’s Honda it seems to use like an infrared or touch capacitive sensor instead. You just need a finger or two on the wheel and it never disengages no matter where you have your hand on the steering wheel.
Rip
Rip
2024 Lightning Platinum
Quality Consultant
Hopefully I'll get this one as well. The current setting on my 22 is annoying!
Well, it's all annoying compared with BlueCruise hands-free. How often do they update whatever maps or algorithms they use for that?
larrylsb
Larry
NM
2023 F150 Lightning
I’m so tired of having to move the steering wheel to get rid of the “keep your hands on the steering wheel “ message. I go down a straight road for about three miles and I get that message at least four times. I wonder, can I sue Ford when I get or does the hitting of someone in the oncoming traffic because I have to move the steering wheel because of a stupid message on the dashboard?
