Uncommanded Parking Brake Activation
x47
Indiana
This is not what I wanted to write for my first post, but here we go.
I've got a several month old 2023 F150 Lightning Lariat ER with about 3000 miles ... and the parking brake keeps coming on when the vehicle comes to a stop. It isn't auto hold, the doors are closed, etc. You have to fiddle with the door, shifter, and parking brake button quite a few times before the issue goes away. Not the best experience in a busy intersection.
Unfortunately for me the truck behaved when I took it into the dealership the first time for this issue. Usually it happens a few times a day. It isn't obvious how the condition can be cleared once it happens.
Pictures are worth a thousand words so a video should be better. Does anyone have any ideas what I can ask the dealership to look into when I go back?
The Weatherman
South Central KY
Does this seem to occur when you are stoping on unlevel ground?
There is feature that sets the brake in this situation. It should release automatically thou when you begin to depress the accelerator.
Reactions: x47
x47
Indiana
No! It happens when I'm in drive or reverse and pretty much anywhere around town. This video in particular was taken in a flat parking lot, and the parking brake turned on many times even when I remained in gear.
The Weatherman
South Central KY
If it’s not releasing at the lightest of touch on the accelerator then you need to take in to for service and work with them until you can get it to show out.
Reactions: x47
x47
Indiana
To clarify this isn't an issue with auto-hold. That works as expected.
Grumpy2
Central Oregon Coast
23 F150 Pro SR
Retired Hvy Construction
x47
Indiana
Well there's no immediate evidence of the red liquid of motor death but I'll ask!
If it's not just your seatbelt then bring it to the dealer. The parking brake icon is just an icon on my truck. When the word brake comes up in red it usually means a brake fault.
it looks like the system is not 'seeing' the vehicle as 'in gear', and protecting the possibility of rollback by applying the parking brakes - seems like a small SENSOR that is the issue.
x47
Indiana
Is your seatbelt buckled?
Yep
I'm trying to get in touch with them now.
That's kind of what I'm wondering.
New information -- as of today the truck is now sometimes showing "Auto-Hold System Fault". Auto-hold was disabled by the computer this morning. When I tried enabling it again it complained it could not do so as a door was open. No doors were open and no door open indicators were on.
Looks like one computer is getting one story and another computer is getting another story.
We've had recent software updates for the "door modules" but this might be an actual failure of the module or wires to switches & sensors.
Reactions: x47
Ford Motor Company
Official Ford Account
F-150 Lightning
TomB985
Isanti, MN
2022 Lightning XLT ER
As I read through your post, my first thought was that your truck thinks the door is open. I then saw your second post about not being able to re-enable auto hold because your door is open.
I’m pretty sure that’s where your problem is. A bad switch or wiring problem is telling your truck that you’ve opened the door, and it automatically sets the parking brake for safety. This feature has good intentions, but makes it really frustrating to park my trailer because I’m in and out of the truck several times.
Your truck is acting perfectly normal if you were opening your door when this happens.
x47
Indiana
Now the question is which switch / wire is bad such that the instrument cluster doesn't think the door is open but another engine control module does.
