Ford Mobile Charger trips GFCI outlet (110) and do I need a 50 AMP GFCI circuit for Ford Mobile 240 charging?
itdwebman
Northeast
Tried some charging with the Ford Mobile Charger and discovered that when plugged into a 110V GFCI outlet - the GFCI tripped. When I plugged it into a 110V (no GFCI) I was able to Charge my Lightning EF Lariat without issue. Does anyone else have this issue? Should I stay away from GFCI circuits?
Also - are there known issues plugging in the mobile charger to a 240V 50 AMP GFCI circuit (which is recommended by Ford?)
I know the 48A and 80 AMPEV L2 charger installation says not to have a GFCI circuit - as it is built into the charger.
I will be installing the Ford Charge Station Pro when shipped to me.
Thanks
cdherman
Kansas City
RAV4 Prime, 2016 Leaf
GFCI with 120v -- I don't know. The mobile unit has GFI in it, I think. So no need to worry about using a standard circuit. 120v charging a Lightning is horrid though.
Ford Mobile EVSE allows charging at 30A. Into a 40A or 50A 240v outlet there is no problem. 240v GFCI circuits are rare as heck. Only used with EVSE and perhaps the occasional pool or hot-tub. Ford "recommends" them, because NEC code now says the 240v plug used for EVSE needs to be GFCI. This NEC rule is NOT because the EVSE needs GFI. That is built it. Its because un-informed folks could pull out the 240V plug before disconnecting the J1772 plug. This will result in a nice little ball of electrical arc if the vehicle is actually charging. A lot more danger than just a 120v plug pulled while under load.
I didn't really answer either of your questions, but perhaps a bit helpful.
The Ford mobile unit really sucks by the way -- unable to derate to 24A, which would be so useful for folks that can find a 30A dryer circuit (need 80% derate for cont duty to 24A). But the Ford unit is $500 boat anchor. Sorry to be so negative. Portable units need to be programable -- whole purpose of portable is that you don't know what kind of power you are going to find......
I’ve used mine on both voltages with GFCI without problem.
itdwebman
itdwebman
Northeast
This is most helpful - sounds like I do not need the GFCI breaker for the 50AMP Outlet. I got the Mobile Charger as there will be times I will not be near an EV charger.
Hmm - thanks for the feedback. Interesting.
Your GFCI outlet might be troublesome / over sensitive, might consider swapping it.
davehu
hot springs, AR
GFCI outlets can be finicky. some time ago with our lake house..... oh ever mind the details. THEY ARE FINICKY!
cdherman
Kansas City
There needs to be more recognition that if you are ordering a truck or have the option, then the deleting the Ford mobile charger is a wise choice. Far more flexible units are out there for much less money. $500 buys a lot of other far more capable and linked EVSE. I bet Ford makes about $350 for every one sold.....
Joneii
Central PA
F-150 Lightning, Tesla MY
Check your GFCI outlet. It is most likely the problem, not the mobile charger. I’ve used mine with GFCI outlets and it worked fine. If it turns out to be a problem with the mobile charger, remember that it is covered under the 3 yr/ 36 month warranty of your truck.
You may not "need" the GFCI breaker for the 14-50 receptacle, but code could require it to be installed.
I think that requirement started with the 2020 NEC.
MontanaLightning
Montana
2023 Ford F-150 Lightning
GFCI's will need replaced after so long due to increased sensitivity.
flyct
Jerry
South Florida
2024 Ford Lightning Platinum 2024 F-450 Platinum & 2-2023 Tesla Model Ys
Blissfully Retired
A 14-50 GFCI is not required by code if the outlet is intended for RV usage But it is required if intended for EVSE usage. All my 14-50 outlets were installed for RV usage. Before plugging it unplugging I turn off the outlet with the nearby breaker. I never plug or unplug with outlet being live.
One exception are my hot tub and pool pump 50 amp services. Those are protected by a 50 amp GFCI breakers.
That’s not true if your state has adopted NEC 2020 or later. Prior to 2020, GFCI was only required if the 14-50 served an EVSE. As of 2020, the only exceptions are for receptacle outlets serving dryers or cooking equipment that is fastened in place.
itdwebman
itdwebman
Northeast
Thanks all for your info - the best source of "real" information anywhere around. I asked my electrician for a GFCI breaker only because Ford recommended it. It is not code where it will be installed. I likely will ask that the GFCI 50amp breaker be switched out with a standard 50 AMP breaker to avoid any "issues".
I chose to include this Mobile Charger in my build - but fully understand that it might not be the best and is not configurable via APP like other chargers.
