Jaug
Jason
Fargo
2021 F150 Platinum
So... staying awake late was soooooo worth it. I think
GWM - about an hour total with a 32 minute wait after the restart prompt (aways worked in the past)
APIM - about 45 minutes total with a 15 minute wait after the restart prompt
Mongoose plus flew through it without a hitch.
Ran a scan after all clear
I did have to do a hard reset on the Sync system to get the hand free stuff to show up. Still haven't gone for a drive to test. Way too late and the family wouldn't appreciate me opening the garage and driving out and back in.
I assume this brings me up to 2.5.3.
Normally I am not excited to head to work but tomorrow morning is like Christmas morning :)
jmm3807
Phoenix AZ
www.seasavvyaquarium.com
2021 F-150 Platinum 4x4
Business Owner
Finished. Drove for almost an hour. Lots of bluecruise highways here. Works great, definitely worth it.
Side note: still have IPMA, PSCM and GSM updates. Don’t really know if I should do any of those considering I know the GSM is a bug and the others I updates like 2 days ago. I think the IPMA and PCSM are bugs as well. Will wait for others to chime in and confirm.
Looks like bluecruise is finally here for Job 1’s.
Ford F-150 Lightning ECU module programming guide using FDRS 93DFB8BA-4C38-48E7-8C4A-C5B4769B485A
Jaug
Jason
Fargo
2021 F150 Platinum
@DeltaDeuce and @jmm3807 how long after your APIM did it take to get the activation email? When I go to connected services on Ford online it says activation pending. Hopefully this just takes some time to run through the system.
Lodans
Austin, Texas
2021 F150 Powerboost King Ranch
Building Automation
So I seem to be stuck. I did the GWM and Apim just fine. I did the ipma and power steering module but they will not go away, there are no errors or dtc's. I show hands free under the sync about but do not show it under driver features even after a hard boot. I looked at connected services and show blue cruise activation pending so I guess I will wait. Any suggestions?
jmm3807
Phoenix AZ
Business Owner
So I had to click activate on mine then it flipped over to activation pending. However mine works currently and still says activation pending.
Bob_Mac
Bob
North Carolina
2021 Ford F-150 Platinum
Cyber Security | Developer
Same here. Already activated and appears used.
Just so everyone knows myself and @JEB being the first to get the Mongoose we thought the same thing but, @JEB called them and they said it was normal with the activation (already activated). He can explain in more detail so no worries.
BHunted1
Sumner County TN
2021 Ford-150 Platinum Hybrid
Good morning. I have 5 updates that won't go away Yesterday. ABS, IPMA, PSCM, GWM and GSM.
the last thing I went to do was the GWM that showed up after doing the long IPMA module.
When I try to run it, I get the below. Any thoughts what is causing that? Soon as its light, I will try this all again. Went at these for over 5 hrs with the Mongoose.
Procedure Unsuccesful - InitializeCommsHardware Could not communicate with the VCM. This is most likely a data issue
Bob_Mac
Bob
North Carolina
There are many who are experiencing the ABS, IPMA, GSM and PSCM still showing after successful updates. My suggestion is to reboot the GWM from FORScan and try that update again and see what happens.
BHunted1
Sumner County TN
Will do. Will let yaz know.
MikeYQM
Moncton NB Canada
2021 F-150 Platinum Powerboost | 2013 BMW M3 Comp
Has anyone tried to power through this last batch of updates with a Nano? Or did everyone give up when the CCM failures started happening?
Jaug
Jason
Fargo
2021 F150 Platinum
It was almost instant.
I never did get one and it’s still pending activation on Ford online. But it worked this morning just fine. Another thing I noticed with these last updates is my camera in motion for the bed and hitch finally work. Also the side card bed view is there.
That hasn’t worked before this morning. I haven’t done any forscan changes because I wanted to get updated through bluecruise first so it was cool to have the camera work.
unfortunately this APIM update doesn’t get rid of the black border for apple Care play. Haven’t really noticed anything else yet.
Jesse-Infotainment
2024 F150 Lightning Platinum
Can someone that has done the gateway update confirm if they still can connect through forscan?
sailorz
2021 F-150 Platinum FX4
I wanted to add a note for others on this subject. A lesson learned from Sync 3 is that the partition table of the USB drive also matters. With Sync 3 the USB drive must have an MBR partition table not GPT. I assume Sync 4 operates the same way. It's possible someone could buy a recommended drive and still have updates fail if this is overlooked.
For future reference, having a USB formatted with an MBR partition table does not seem to affect the likelihood of the initial APIM update kicking off immediately or not. The two USB's I've used are both MBR and neither caused an update to start. Cant say if using GPT would cause it though. That said, while testing this, and after a couple of weeks of keeping my second USB drive in and then moving back to the first USB, the truck has decided it will go ahead and take the update this morning.
Fordphanatic
Boothwyn
2021 Platinum F150
Union Carpenter
You will not be able to do the CCM with the nano
