Need a quick 5-10 min warm up setting
TBA
CA
23 Lariat ER+Tow Tech & Max Tow; Anti Matter Blue
It’s great that you can schedule a departure time in the Ford App. But what I find strange is that there is no setting for “Quick” departure. Typically, I know about 10-15 mins before I need to get in the car and drive somewhere. It would be very useful if Ford added a setting that warmed up the battery and perhaps started the seat heater 5-10 mins prior to departure.
What does everyone think about this idea.
TreesandBees
Durham, NC
2023 Lightning Lariat ER
Yes! I assumed this already existed and I just had not found it yet
Reactions: s_c
alockbox
US
Ford F-150 Lightning Lariat
If you have it setup in FordPass, you just remote start it, and it auto-shuts off after 15 minutes (with a countdown on display). You can also extend it 15 more minutes at anytime.
Toby57
Randy
kansas
2018 F-150 XL 101A
Must set up an app. Thank you.
The reason this doesn't exist is because you can't warm the battery in 10-15 minutes. You can hit the Remote Start button anytime you want.
Lightning Rod
North Coast
2023 Ford Lightning Lariat ER
CNC PROGRAMMER/MACHINIST
Does the Lightning not have remote start that would operate those things?
This is what I assumed. When I get my truck soon, I just figured I could hit the remote start prior to departure like I've done for decades.
Toby57
Randy
kansas
2018 F-150 XL 101A
Does one " have" to warm the battery before driving?
Does Ford recommend this, or is it just for comfort?
sotek2345
Engineering Manager
If you can preheat the battery while plugged in it can reduce range loss in the cold. That is the only real benefit.
luebri
Neenah, WI
My process is to set my charge time to a narrow window from 5 AM to 7 AM. Which is the last 2 hours of my lower tier tiered usage rate. I depart at 7:20 so I just do a remote start about 10 minutes before to get cab toasty, I figure the battery is still relatively warm from charging window and doing remote start means the steering wheel is actually warm, unlike the scheduled departure glitch
Drillerr
Darin
Utah
2019 Ram Limited
Does remote start warm the battery like preconditioning does?
GoGoGadgetTruck
Ohio
2021 Mach-E First Edition, 2022 Lightning Platinum
this is a gap going back to even the MyFord Mobile days for the early Ford EVs and PHEVs. Remote start has always been the workaround as others have mentioned, but as has been pointed out, that doesn't help with the battery temperature at all. You aren't able to fully condition the battery in that time necessarily, but it would be nice to have it partially conditioned at least.
LightningShow
MA
'22 Lariat ER
Product Development
It makes absolutely no sense that an on-demand preconditioning button does not exist. I leave for work and come home at different times every day. The scheduled departure function is useless to me. Not to mention that it bricks the heated steering wheel, but that's another issue.
