Connected Charge Station: Missing charge reports
Do you have missing charge history?
  • Total voters
Starting a thread to track instances of missing data reports, I've experienced this problem several times over the 2+ months I've had my FCSP active.
I did not want to clutter up many of the recent threads where folks are struggling with setup and configuring network connections and the Ford Pass app, if you're having those type of problems, share in those threads.
It seems to occur near the end of a week or weekends. In the past I've gone through resetting the FCSP network configuration thinking it might be the problem, as painful as that is I tried it once again today, networking is working fine, I can see the FCSP device on my network, but Friday & Saturday data did not post to the cloud.
Cleaned up the Ford Pass settings to a base install, by clearing cache and credentials (requiring me to redo PAAK, etc), but the FCSP connection also reestablished with Ford Pass brings me all my prior charge history except those missing days.
I'm starting to think this is a problem with the cloud service not working to receive and store new reports, might be that others are experiencing this problem as well, chime in if you are missing Friday and Saturday charging reports.
On your Ford Pass, upper right corner, tap Account then Charge Station.
Ford F-150 Lightning Connected Charge Station: Missing charge reports 1671905867041
Scroll down to Insights, tap it and review your data
Ford F-150 Lightning Connected Charge Station: Missing charge reports 1671905884125
Today I had two charging sessions, yet no data, note data only reports after the truck has been unplugged.
Ford F-150 Lightning Connected Charge Station: Missing charge reports 1671905909342
The current week summary, missing Friday and Saturday morning events
Ford F-150 Lightning Connected Charge Station: Missing charge reports 1671905974468
Let me know if your seeing a similar issue.
Ffxdude
22 Lightning Lariat ER
Yep, same here. I should have Friday and Saturday as well. I do find it sometimes takes about 12-24 hrs to show up. It also seems to register the charge event based on the day you unplug the truck. So if I plug it in Thursday after work and unplug Saturday the kWh hrs will register as having occurred Saturday (the day of unplug) rather than the day the kW were pulled. I guess that's due to the recording of the whole session - the main kW pull and any subsequent maintenance or preconditioning?
Ford F-150 Lightning Connected Charge Station: Missing charge reports Screenshot_20221224-140140
I agree, recording after the close of the connection session is there intention to pick up everything in one event.
bewbie
NYC
Data isnt available for the mobile charger?
Oafy44
Georgia
23 ford lightning
Landscape contractor
I haven’t received my pro station yet so using portable charger. It keeps records of my charges with the mobile unit so far located in my FordPass app
bewbie
NYC
I dont think as in depth as the posts above, correct?
Tony Burgh
Tony
Western Pennsylvania
22 Lariat ER
FCSP insight charge logging always was spotty at best. Ford Pass charge sessions captures all for me. But Ford Pass trip log is inconsistent.
None of those are critical to me. My home charging plus any concurrent power draw is logged hourly by my utility app. And that’s my pay meter.
For the mobile charger, you see event data in the Vehicle, Charging, Charge Log portion of the app, it does record the session details for both the FMC and FCSP, I'm missing in the connected charge station log history.
Ford F-150 Lightning Connected Charge Station: Missing charge reports 1671911497300
Ford F-150 Lightning Connected Charge Station: Missing charge reports 1671911623919
I'm only trusting my Emporia Vue2 at this point, it's been working perfecting so far, I need reliable data for my travel logs.
Someone fixed something, missing data from last Friday onward is now posted to the Connected Charge Station function under account on Ford Pass!
Ford F-150 Lightning Connected Charge Station: Missing charge reports 1672246947426
Ford F-150 Lightning Connected Charge Station: Missing charge reports 1672246966909
I have at least two sessions still missing for this month. My son's Mach-E charge on Dec 18 and mine on Dec 24th (started Dec 21 and left on). We don't charge much, I'd say about 9 of 10 get recorded.
It's also maddening that the Insights tab defaults to hourly view but in my experience it does not report hourly. Seems like it dumps all the kWh in the hour you unplug even if all those kWh were from the day before and you left it on the charger. I just go to Month view and look at the logs at the bottom.
kvasiir
San Jose, CA
2022 F-150 Lightning Lariat Rapid Red
Mine has never worked even once. Since starting a new job in late October I haven't used it at all though - cheaper to charge on work's dime at the office.... ;-)
Looks like the back end services for the Connected Charge Station app function within FP is down now, last seen working this morning when I reviewed my overnight charging results.
This is what you might see when trying to look at your FCSP charging log
NOTE, that I can connect to my FCSP using the installation utility to verify that it's talking to my local network and likely the WWW, so I conclude that the problem is the FORD backend
Ford F-150 Lightning Connected Charge Station: Missing charge reports 1673403434815
I was just going to make a post about this. I love this truck, but the software is really disappointing.
It's working this morning.
