Charging at home not stopping at 80%
jallen
2009 F150 XLT / 2023 Ford Lightning Pro
I read a ton of posts about this issue prior to getting my truck, and I thought I had it figured out. Was working initially. Have the truck set to 80% at home. Have the app set to 80% at home. Have the home address set. Truck SHOWS it’s at home, so it’s not confused…and yet app says charging to 100%!
What am I Missing? See photos.
Thank you all in advance!
Ford F-150 Lightning Charging at home not stopping at 80% 26EF0C9A-24FE-4DFB-883F-C43905522BD8
Ford F-150 Lightning Charging at home not stopping at 80% AE359016-B0F1-42E9-ABF7-955D7CB57441
Ford F-150 Lightning Charging at home not stopping at 80% B4607587-D82F-419D-A4A1-924CA072BBD7
To use your home settings you must select "Use preferred charge settings". You cannot select "Charge when plugged in".
jallen
Thank you! That must have reverted during one of my 12v “resets.”
I’ll change that 1 setting and then give it another go. Seems like there are unnecessary layers of complexity between truck and app settings to get this done!
True.
In addition, at times FordPass won't take the settings. And sometimes, the settings (like for a departure time) get erased with no explanation.
Akbrian
Alaska
F150 Lightning 2022
This person has it right! And it seems like every software update throws a new wrench in the charge settings. May have to “reset” you location and setting individuality in the truck and app.
Does anyone consistently use and set different charge levels for different locations? I really wish Ford would simplify this. I understand the concept, but I just don't think it is worth the frustration for the few that might set different levels for different locations.
metroshot
Pat
Montclair, CA
2022 Lariat F150L + 2023 MME
Networking Tech
MIne charges at home to 100% every time as I want, but at public DCFC, it stops at 90% everytime.
Has been this way since day 1 even with all the software updates...
Bwanapete
Peter
Cazenovia, NY
2022 Lightning, 2023 Tesla MY, 1941 Lincoln V12
I had this problem but after I got the big wall charger installed, no more trouble. So I am wondering why the truck chargeport and the charger head have the additional contacts below the J722 or whatever it is called. Because public chargers that don’t have this additional part and they work just fine.
That's the pins for CCS charging. For the 80amp Ford charger, it uses that for bi-directional.
htobin
Howard
Ovalo TX
F150 Lightning 2023 Lariat
Retired surgeon & jet aircraft pilot, Active rancher
How do you eliminate the selected charging times so that Ford supplied charger begins charging whenever it is plugged in. I can’t find that option on the application or in the truck
TheWoo
Manhattan, KS
Select "Anytime" under "Set my own time"
Ford F-150 Lightning Charging at home not stopping at 80% 1000005504
htobin
Howard
Ovalo TX
I have looked but can’t find that option. All I see are clock settings
Click Delete Locations to remove the profile.
Ford F-150 Lightning Charging at home not stopping at 80% 1706285256087
In the Sync screen, you can delete it as well, (truck needs to be in accessory or run mode)
Trash can icon
Ford F-150 Lightning Charging at home not stopping at 80% 1706286419429
Or you can simply disable it with the switch off/on
Ford F-150 Lightning Charging at home not stopping at 80% 1706286462902
Ford F-150 Lightning Charging at home not stopping at 80% 1706286490028
