Labs4Lightning
C
I want to avoid the dealership at all costs. I've had similar experience with my last truck sitting in their service area for over 4 months.
If there is a part involved, as long as I can safely drive it, there's no reason for it to sit on their lot.
@IdeaOfTheDayCom
i hear you about not wanting to leave for many days.
the past 2 trips I begged that they not let it sit for days before putting hands on for diagnosis. With end result sending me home while waiting for part. Which in both trips could have been 10 days earlier = 20 days saved. Lost warranty days and payments for no use.
now it’s been sitting for 2 days while they find out how long to get part. Really!
Mine installed!
I had about 80% charge, left unplugged after I drove it to the grocery store and back. The BMS reset seems to have done the trick for me.
Ford Senior Master
Pell City, Alabama
Service Manager
I’m not sure what the dealers problem is in completing the updates. I know that I personally do 3-4 a week with no problems. I also have not had to replace a gateway modules in about 6 months.
The key to getting the updates to go through is placing the 12 volt charger on the power supply mode until amperage drops to maybe 2 amps or less. Then reset BMS and proceed with programming. Yes it is time consuming. I have spent up to ten hours fully updating all modules. In some instance there are TSB’s or other symptoms(such as failing OTA) which allow for covering the updates under warranty. When it’s not covered I do it anyway if the customer is willing because it’s the right thing to do for my loyal owners.
IdeaOfTheDayCom
Joe
Staten Island, NY
IdeaOfTheDay.Com
Software Developer
So I guess there’s no way for a customer to do it, which is funny considering the FordPass alerts ask for us to help them install it (and doesn’t say how).
It wouldn’t be an issue if the alert told us “you need to have your dealer install it”, instead of that bogus message.
Ford Senior Master
Pell City, Alabama
Service Manager
If I had that issue and didn’t have access to the tools I do I would probably disconnect 12 v battery and trickle charge for a couple hours. Reconnect battery and drive for about ten minutes. Then let it set in an area with good cell service.
That’s what I would try. I am not sure it would work but Its Worth a shot.
Dgut
Danny
Chicago
Lightning Lariat SR
Finance
Thank you!! The battery reset worked! After the reset, the SOC via OBD was at 92. Update pushed through. Now, looking forward to the other updates.
Thanks again!!
Have you tried resetting the BMS? No disconnecting the battery doesn't reset it.
Reset procedure (no scan tool needed):
1. Put the car in accessory mode (push start button without depressing brake pedal)
2. Flash the high beams relatively quickly five times
3. Depress and release the brake pedal three times
4. Wait 3-10 seconds and the battery icon on the instrument panel will flash.
5. Your BMS is now reset.
Note: Without any previous data to work from, it's a good idea to drive the truck and maybe throw the charger on it a couple times to get the SOC reading more accurate, but if this is a 12V battery SOC issue, this should solve it!
After banging my head and reading every forum post I could find, I think the BMS reset did the trick so thank you!!! How dumb is it that the solutions to what should be an easy update potentially involves driving around aimlessly for hours or buying and hooking up a trickle charger to charge a stupid 12v battery that sits on a 131kw battery. Beyond frustrating to me that @Ford Motor Company cannot be more helpful when there are clearly lots of people having similar issues. Simply letting us know what precondition is not being met would go a long way.
I bought my 2022 ER Demo last week and the Ford Pass App showed an update was available but the truck showed everything was up to date. Despite confirming with the the dealer that sold the truck to me the truck was updated they handed it over with the last update (3.5.5) having stalled in mid December. This began a regular process of checking for updates, surfing forums to see any solutions, and then trying said solutions. I made a dealer appointment and was willing to take time off work to try and get it fixed but then I kept reading that many dealers are unable or unwilling to fix. After charging the truck to 95% and letting the truck run in idle, the update finally downloaded (I think via wifi) but then began the countless fails to download with Ford sending notifications to Help Them Install their update without offering any help for us!
Long story… I’m venting… after trying everything short of going to a dealer, the BMS reset that makes you feel like to are entering a NES Contra code seemed to do the trick. Or maybe it was the trickle charger before that. Or maybe charging to 100%. Or maybe running my car for an hour.
IdeaOfTheDayCom
Joe
Staten Island, NY
IdeaOfTheDay.Com
Software Developer
I followed the link from the FordPass App that tells you more about Power-Up installs, and noticed a few interesting things.
Ford F-150 Lightning Priority Update: 22-PU-1009-MIL-DTE Calculation 1677325743662
Based on that, I'm sure all of us me most of that list... we're parked, "ignition" is off, etc.
However, there are a couple of things I don't think I've tried together.
1. Setting the parking brake. Perhaps they want to be sure that with the computer off, it won't roll away?
2. Your headlights are turned off. Mine are set to Auto. Maybe it needs to implicitly be in the off position?
3. Your vehicle was driven for a minimum of 30 minutes prior to avoid low battery (presumably the 12v). I generally drive at least that each day, but perhaps the LAST trip before parking needs to be that long?
Then, apparently ignoring what they just said about must be before 12 a.m. (not exactly 12 a.m.), they have this screenshot completely ignoring the not exactly 12 am rule:
Ford F-150 Lightning Priority Update: 22-PU-1009-MIL-DTE Calculation 1677325817603
You guys don't need to drive the truck to charge the 12v battery. This isn’t an ICE vehicle. Just start the truck, turn the shutdown timer off, get out and lock the door. Let it "run" for awhile and it will charge the 12v.
Ford F-150 Lightning Priority Update: 22-PU-1009-MIL-DTE Calculation 1677325817603-png
One would ~think~ they would program an exception rule to prevent us from setting a midnight starting time, logic would be"
12:01 am or later
but
No sooner than xx minutes (projected install time plus 10 minutes for sanity sake) subtracted from midnight, this allows the process to complete before the truck turns into a pumpkin.
Next question I have is ..... is it GMT, EST Local Time.....???????
Logic would dictate local time, but if the process involves closing out the procedure by reporting to the mothership, maybe that needs to happen while not breaching 12:00am mother ship time, which might very well be GMT regardless of where the master controller actually sits.
IdeaOfTheDayCom
Joe
Staten Island, NY
IdeaOfTheDay.Com
Software Developer
12:01 am or later
but
Very good points.
We know the factory is in EST, but that doesn't mean the server is. Perhaps just avoiding 00 minutes is a safer bet, so whether it adds or subtracts hours, it won't fall at exactly midnight regardless of the time zone.
My next test will be:
1. Take a 30+ minute drive.
2. Putting the parking brake on manually.
3. Turning the headlights OFF, instead of auto.
4. Setting the scheduled download to 5 minutes or so after stopping, so the 30 minutes of driving leaves the high voltage batteries warm, and the 12v at a charged level.
5. Give Jubu more rum and ask for his intervention.
Ford F-150 Lightning Priority Update: 22-PU-1009-MIL-DTE Calculation 1677335038466
tomjackbear
Western MA
Hyundai Sonata, Honda HRV, Ford F150L
My experience with failed installs is that they were all 12V SOC related (at least that is what the truck was reporting back to Ford).
When charging the 12V directly I never saw (via an OBD2 reader) the truck reporting above a 92% charge even though my 12V charger was reporting 100% charge.
There is a long thread on the Mach-E forums about AGM batteries and sulfication and its effect on being able to charge batteries to 100%. I’m not really sure that is at play in these cases…my experience didn’t exactly match up to that thread but i think it is plausible.
In general though I think the idea is in the right place and explains why it works fine for one person and not another: small differences in our 12V batteries cause them to either not take a full charge and/or incorrectly report their state of charge. I don’t think this charge health is material to the day-to-day use of our trucks. However when something, such as the software updates, are sampling for a very specific number (that is quite high) we run into these issues.
Disclaimer that the above is just a guess based on personal experience and spending too much time reading forum posts. I eventually went the FDRS route to install my updates which is a quite expensive route but did solve the problem.
Labs4Lightning
C
@Ford Senior Master
3 trips to dealer
they now say it needs a gateway module. 60+ failures DTE update.
1st trip: tech reported side sensor module failure
2nd trip: tech, 2nd module did not work - did not attempt DTE update
3rd trip: tech attempted update, failed (minimally tried manual update) decided it needs gateway module.
now I wait for part and try again.
40 days at dealer for that bit of work.
@Ford Senior Master
3 trips to dealer
The knowledge level at these dealers reminds me of a T-shirt I saw years ago - if their brains were dynamite they wouldn't be able to even blow their nose.
Absolutely nothing wrong with the truck and Gateway would be a very good guess. Just a load of hard to meet all at once requirements that their own engineers created and keep the SW from installing.
Reports of failures over 100 times that eventually still install.
Ford Senior Master
Pell City, Alabama
Service Manager
@Ford Senior Master
3 trips to dealer
I just sent you the error which is stopping your update. The error stopping it is definitely low battery state of charge.
Ford F-150 Lightning Priority Update: 22-PU-1009-MIL-DTE Calculation Screenshot 2023-02-25 4.33.38 PM
Thanks for continuing to help and support this forum and users. How can the other dealership want to order a gateway, when the answer is truly this easy to find remotely by someone else.
