Has your truck received this update?
  • Total voters
    149
For those following along it home, it was not the software. It was a physical problem with the charging port hardware, which has been replaced and solved the issue.
Broken micro switch or other component ?
Eric22
Eric
Staten island
F150 lightning lariat extended range
The dealer changed the whole port hardware is that a fix for everyone?
Snoboredca
Rick
Brentwood, TN
2022 Ford F-150 Lightning Lariat
That's what they told me, but they gave me the impression it was just what happened to my truck. Meaning yours may or may not be damaged, I have no idea what would have damaged mine. It looked fine from the parts I could see.
Eric22
Eric
Staten island
Mine stopped trying to install the update should I reset the system?
Eric22
Eric
Staten island
Couldn't get the update tried multiple times the update screen is now grayed out shows the update but it says no updates available
WTH
Jim657
Guelph Canada
23 F150 Lightning Lariat , 22 Mach E GT
WTH
Sounds like you got it download it but it won’t install. I can’t even get it to say that there is an update.
Eric22
Eric
Staten island
This is what I have
Ford F-150 Lightning Priority Update: 23-PU0105-DC-CHG2: Improved DC Fast Charging IMG_5019
Jim657
Guelph Canada
I had trouble getting Pu306-BCF-DET to install it eventually did go through but I haven’t gotten an update since July 12. The PU0930-RBA-CHM is the one I’m trying to get
Robilium
Ca
2023 Ford Lightning, Tesla S, X, F350 Diesel
two of my three failures happened with my fobs wrapped in aluminum foil away from the garage. I talked to someone at Ford and the response was that the precondition were not met and it would be pushed again. They would not give me further details on what precondition was not met.
does leaving the fob in the truck make it so it won’t update? I may be weird but I just leave my fob in my truck all the time. In 25 years it’s never been stolen. My update has been stuck for months :(
Ford F-150 Lightning Priority Update: 23-PU0105-DC-CHG2: Improved DC Fast Charging IMG_1105
No. My truck is parked in my garage with the fob in the cup holder and I get updates.
Phil3315
Phil
NC USA
2022 Lightning Platinum
Mach-E forum. Known issue, handshakes with some chargers. Used to be fine, I think a prior update broke it, and this fixes it.
Agreed, my truck is a year behind in updates, but I have none of the problems people are talking about and I don’t really care for Phone as a Key, so I guess the failed updates are a blessing
Phil3315
Phil
NC USA
I tried everything to get it to update, but I have never left a fob in it, insurance doesn’t pay when you do that. I tried putting a charger on the 12v battery every night for 2 weeks, charging to 85% every night before the 2am update schedule, turning lights off manually, being on WiFi… All the crap they told me, even charging to 100%. None of it helped. Then one day when I was out of town parked in a friends driveway, battery at 67% and no WiFi, and that’s when it did the update. So I think they’re grabbing at straws to try and explain their software shortcomings. It literally updated at 2pm with none of the conditions met when it was set to update at 2am, maybe the times are backwards?
