Powertrain Malfunction/ Reduced Power
There is the possibility that it's a HS-CANBUS or MS-CANBUS issue, these various devices communicate with various controllers, and that can get messed up cause spurious issues, that don't seem to be logically connected, but they are through the network(s)
Madasahatter1138
Steve
Vancouver Island BC
Ford Transit
Electronics Tech
New it was just a matter of time, got the message today. Powertrain malfunction/power reduced..damn it!!!
Ford F-150 Lightning Powertrain Malfunction/ Reduced Power Screenshot_20230921_181002_FordPass
Madasahatter1138
Steve
Vancouver Island BC
Ford Transit
Electronics Tech
Power avail. stayed at 100%, and error cleared after sitting for 10 mins off. On restart all was back to normal:unsure:[
dgargano
Arizona
2023 F150 Lariat Lightning
IT Manager
Same here. Mine was bk to normal after a few hours of recharging. Tried to drop off at local Ford dealer but would have had to leave there for 2-4 weeks (without loaner or rental). This is my primary vehicle so taking a chance and still driving it. It's been a month and haven't seen error again. ? as well
jd350b
Ford F350 Lariat 6.7L, 2018 Ford Edge Platinum
Update: So my truck was at the dealer for just over three weeks, I got it back a few weeks ago. Truck seems as it was before the battery module replacement. My service writer said they only have 1 EV technician and that three weeks was good turn around compared to other dealers. From the looks of it, he was right.
jd350b
Conspiracy theory :) :
Ford is downloading these error codes because it is now a more convenient time to get these trucks back to make the known repair. They knew they had an issue with these March-April trucks way back when they halted production. The decision was made to release the trucks, knowing they'd need to get them all back but it would be better to let the heat settle from the stop production, get more parts available and get more technicians trained. All the trucks are now systematically popping up with the HV battery warnings. They were operating perfectly and have all different mileage. Now being shutdown in small groups to be brought back to the dealers...?
mme_and_lightning
MME 2022 Iced White, 2023 Lightning Platinum
OMG, I have a deposit on a Lightning and now I'm a bit worried.
I really, really, really don't want to start a Rivian conversation, but I thinking....what is the more reliable truck???
Deleted member 12322
Guest
I think you will find the vast majority of owners have not had issues, it is rare. That said, a R1T and the Lightning are considerably different. I would definitely consider your individual use case over reliability fears. Do you want a full size or mid size, sportier or lower cost, so on.
Fastmikerx7
FM
Renton Washington
2023 Lariat SR
.GOV
Got my truck back today.
Steering wheel upgrade part was backordered. Grrrr!!!!
MachE Performance was fun while I had it.
I might charge to 100% tonight. I usually do 85% normally.
We'll see.
Fastmikerx7
FM
Renton Washington
2023 Lariat SR
.GOV
I am happy I got my truck back.
Felt big at first against the MachE-P but 5 minutes of smooth silence and ahhhh..
I wish it had Mach E Peformance Magnawhatever dampers though!
The front shocks SUCK on the Lightning!
Maybe they will build a 1200hp/tq lowered Lightning SportTruck!...
Soon...
Hopefully!
Take my $$$!!!!
Idaho
2023 lightning xlt
Can anyone answer if replacing the air dam actuators will fix this error. My dealership says it will send ordered new actuators. I'm worried if they fix something they doesn't need fixing it they'll break something else
USA EV
I imagine they have easier options to achieve the same thing with much less strife. ?
BoostedKWs
NJ
2022 F150 Lighting Lariat SR
EV Charging Engineering Director
Just sent my truck in for the powertrain failure / high voltage battery warning. I was hoping it was a fluke (like the 50% power thing), but restarting and charging didn't do anything. Stuck at 25% power and charging errors out after 10 minutes. Diagnosing tomorrow, hopefully.
Been looking into lemon law - I read that they need to transfer the financing over, is that true? That should keep us from getting nailed on interest rate increases.
BoostedKWs
NJ
Dealer said the entire battery needs to be replaced, no ETA on the part. It was a nice year that I had the truck for!
Entire battery???!?!?!?!?
Usually it's one or two modules within the battery pack.
