UpWithFilm
Ohio
'22 Kia Niro Ev, '23 Avalanche Lightning XLT
Ford F-150 Lightning 🙋‍♂️ What Did You Do To Your Lightning Today? IMG_0819
I know I posted about this before, but after almost a month of further development (and countless versions), I'v finalized my coin replacement MagSafe mount. Cable can run out the bottom or through the back. Currently routing to the cubby port, but eventually plan on pulling the trim and running it to the port in the arm rest.
Considering making a standalone post in the forums to see if there's any interest in it from other members.
priceb
Price
Western North Carolina
2023 F150 Lightning XLT
College Instructor
22 PRO... 26,000 miles
-Added Adaptive Cruise with Lane Centering and Stop-N-Go(Radar, harness, programming) $760
-removed Frunk beeper connection, amzingly quiet now! $0
-used Forscan to: Disable Auto Door Locks, Auto Door Relocks $0
Disable Seat Belt reminder $0
What I'd like to be ABLE to do, but so far have had no one have success doing:
:Disable lights to 'Auto On'
:Default to SPORT Mode at every ON
This should fix the headlights 'Auto On'. Set it to 1 for last known. Worked for me.
HeadlampPosAtIgnOn_Cfg (HPAIOC)
726-74-01xxx*xxxxxx--0 =HPAIOC AUTO1 =HPAIOC LAST_KNOWN
LUXMAN
F150 Lightning PRO and XLT
Pilot
NIce!.
If you figure out the SPORT MODE Default please let us know!!
butterfb
Brett
Orlando, FL
2023 Lightning
Senior Support Engineer
I like the other hitch cover lighting bolt that is available on thingiverse but wanted something different and liked this sites logo so playing with my own take on the design, printing the hitch part later, this is all done in PLA and if i like it will get some ABS and reprint it once its finalized.
Ford F-150 Lightning 🙋‍♂️ What Did You Do To Your Lightning Today? Hitch icon
Howard_Scott_Warshaw
2022 Lariat ER, rapid red
I finally got around to making some software updates to my '23 XLT via Forscan and did the following:
  • I tied the bed lights I installed a few months ago into my Zone Lighting and enabled the physical on/off button.
  • Changed my temp blinkers from 3 to 5.
  • Added universal window control (roll front windows up or down with key fob).
  • Switched all cameras to be able to be used at speed.
  • Turned on the glare free/matrix LED headlight feature.
Once you got Glare Free to work, did you notice that your normal auto highbeam feature no longer works when Glare Free is switched off?
Lytning
Georgia
Ford Motor Company
Official Ford Account
F-150 Lightning
Installed Putco pedal covers today. Really like the look and feel, really nice grip! Install was easy.
Looks good, Doug! ? Thank you for sharing this mod with us and for being part of the Ford family!
UpWithFilm
Ohio
Would you humor a random internet person and try it to see what happens? I'll mail you a cookie.
So I tried it last night. I turned off the updated Glare Free and yes, it switches my headlights to standard manual on off for high beams. Which makes sense. The Glare Free feature takes the place of the auto-high beam feature.
Thanks for confirming. Address for the cookie?
LUXMAN
Pilot
Would you mind sharing the selections you made to get the "all cameras to work at Speed"?
Also, do you happen to know how to make SPORT mode the default when I turn on my truck?
THANKS
Walle1jm
2022 Ford F-150 Lightning SR XLT 312A
She is a little dirty and about to be more so with the impending snow coming this week but figured I would add to this post.
Added Ford official black lug nuts using some FordPass points after seeing many others do the same on this forum.
Ford F-150 Lightning 🙋‍♂️ What Did You Do To Your Lightning Today? IMG_5599
Ford F-150 Lightning 🙋‍♂️ What Did You Do To Your Lightning Today? IMG_5600
