Mike G
- First Name
- Mike
- Jan 6, 2022
- N. AL, USA
- 2022 F-150 Lightning, 2023(J1) Mach-E GT-PE, '24 Bronco HLE 2Dr
The two most common off-the-shelf powersupplies that many use for FDRS programming are the Clore PL6100 (100A), or two of the Clore PL2320 (20A) powersupplies in a piggyback configuration.
There are many other options available like 'barebones' units that need to be wired up with terminals and power cord.
The IPMA is singularly the biggest challenge for any powersupply since the update normally takes nearly three hours with fast internet (using a Mongoose). Several folks on the MME site have measured around 39-40A during IPMA programming.
You never want to see the voltage drop (in FDRS) down to below 11.0 volts. Or you'll likely be doing this update all over again once you get a proper powersupply.
