240V charger blowing breaker
Danface
Dan
Central Mass
2023 Lightning XLT
This is technically true: breakers trip while fuses blow (they melt or fuse, but the common term was blow).
Old habits die hard, so when breakers started becoming more common in homes over fuses, people continued to say "blow" when a breaker would trip.
After all, how many of us say, "dial" when placing a phone call?
BUT we all make "Carbon Copies" of our emails so take that new fangled technology!
Etsquared
ET
Orlando
F150 lightning
I have been charging my f150 at home on a 240v charger for 1 year and never a problem.
yesterday I used a DC fast charging station for the 1st time ever.
now when at home my 240 charger is blowing my breaker in 5 min
is there any coincidence that this is now happening after I used DC for 1st time ever?
Had similar issue tightened outlet wires like only a USAF Mechanical gorilla can problem vanished
roddiaz1
Rod
Pittsburgh
I don’t mean to get too geeky or technical here, but, is there any chance you’re having additional demand from some other appliance or use in the house (hot tub, heater, oven, furnace, etc.) which accidentally happened to coincide with your visit to the Electrify America station? Just a thought.
Encinitas CA
23 Lightning
Ok. Here is the update..
1. I spent time with Ford today to troubleshoot the SW issue I was having with my charge assist app button not working.
2. Did soft reboot of vehicle and it did not immediately fix the SW error issue
3. As I was pulling into the garage it worked for a second see attached.
4. the. I got same error again after
5. Electrician came over and checked the circuit breakers and amp flow pulling from the vehicle (was pulling little over 30) so all good and didn’t trip the breaker
6. So now the hypothesis, did the sw soft reboot to fix the charge assist app actually fix something else that was causing my vehicle to pull more amps (like it was thinking it was still at a DC fast charger (like ev go) and the SW rest “reset” to acknowledge it was now only pulling from the Ford Mobile charger on 240v
7. Will we ever know without any vehicle logs?
8 and yes to the previous post I was smart enough not to have any other appliances or high amp things running. ?
9. So now have to call Fors again to see if they can still fix my other issue which is the error message and charge assist app not working. It’s now blank with no error.
Ford F-150 Lightning 240V charger blowing breaker IMG_2504
Ford F-150 Lightning 240V charger blowing breaker IMG_2492
Runaway Tractor
Yes
The two charging rates are not connected. Level 2 AC charging is done with the truck's onboard AC to DC charger. DC fast charging is controlled by the external DC fast charger regulating the rate. It's impossible for to have anything to do with the other.
That being said, if the truck's level 2 onboard AC charger was confused about something (super technical explanation), and was attempting to pull more than it should through your mobile charging cable, that would explain a great many things.
If rebooting the truck made the problem go away, and the electrician confirmed everything appears secure and working as intended, sounds like problem solved.
myke
MikeGeiger.ca
'23 XLT ER, '14 FJ Cruiser 6MT
IT/Networking/ISP/OSP Consultant
Could be low supply voltage; that’d drag the current up.
AC charging is current-controlled. Voltage variations don’t matter.
pritish
Pritish
Novi, MI
Cybersecurity
I did not see if Big J is using the mobile charger or the Charge Station Pro.
For Mobile Charger, it is rated for 30 amp so it ideally should be on a 50amp circuit (which you already have).
If you are using Charge Station Pro, then there is a very simple solution to this. The problem is that you have the Charge Station Pro which is rated for 80Amps on a circuit that is 50Amps. To limit the charging, there are two things that can be done to limit
1. Software: Go into the Ford software and set the amps to 40amps max charge. FordPass -> Account -> Charge Station -> Settings and set "Max Charge Current" to 40amps. This is software controlled so anytime you connect to the Charge Station Pro (assuming that it is connected to your WiFi), the current will be limited to 40 amps and you won't trip.
2. Hardware: Turn off the breakers and then open up the Charge Station Pro cover. Looking at the circuit board, there is a tiny dial that has the amp settings on it - bring it down to 40 amps. Note: after you do this, there will be an amber light that shows up - it indicates that the charging is happening at slower rate. You will find the information on max current setting on Page 15 of the Charge Station Pro manual.
https://content.fordpro.com/content...ord-Charge-Station-Pro-Installation-Guide.pdf
The Fordpass app is extremely unreliable in limiting the current rate, tested it last night for follow-up on another thread.
ONLY use option two noted above to limit the hardware current draw if the FCSP is installed on a limited capacity circuit.
Bokenator
Curtis
Georgia
2023 Lightning Lariat - Antimatter Blue. 2020 Hyundai Palisade Limited
I didn't know that manually dialing it back to a lower setting triggered the amber light...thanks for inadvertently educating me!
My Lightning was charging plenty fast (I average between 22 and 27 miles of range an hour at the reduced setting), but occasionally I see the amber light and was wondering what was going on. The Ford Charge Station Pro app has not worked right since about a week after initial setup, so I figured it was related to that. Or maybe related to the reduced charging rate once I achieved more than 80% charge... I charge to 90% when I bother to plug it in.
Nice to know the system might actually be working as intended, and probably won't be burning my house down. (y)
pritish
Pritish
Novi, MI
Cybersecurity
Page 18 of the manual indicates all the LED statuses and what they mean. Even some of the service engineers do not know this. I have had to figure out a lot of things myself :(
Encinitas CA
23 Lightning
Good to know thanks. I only use the mobile charger give. I can’t upgrade my service to the house. Much appreciated.
