ECG-24.2.5.7 - Gateway Module
OCSTEVE39
Steven
2024 Ford F-150 Lightning Flash
Oh I beg to differ
Happy to have you add some value if you can
He has - in his only other post on this "worthless" forum :). User name says it all.
Ford F-150 Lightning ECG-24.2.5.7 - Gateway Module 1740876974612-o7
Effonefiddy Lightning
Alfred
I would like to see them fix the issue of the music starting 50ft. from my truck before I even get in. It should start when you open the door. But I'm not holding my breath.
zinkscott
Christian
2023 F-150 Lightning Platinum
Cloud Engineer
Anyone noticed weirdness with preferred charging times and Charge Station Pro after this update?
It’s constantly “starting charging”, then says “scheduled” then the charge station resets and it loops. I had to remove the charging times to be able to even charge normally because clicking “start” would cause the charger to loop and the airflow flap on the front to go up and down.
Ricks Lightning
Rick
Los Angeles
Plumbing Contractor
I too received 2/27/25 the same update on my 24 Flash . Noticed it on my Ford pass app. I wasn't plugged into my charger and it updated.
Looks like a mass ota update around the same time frame for us non EAP users. Does that mean when they release BC1.4 we will all get it around the same time?
My guess is 1.4 will come on 4/1. Yes, I called it first.. it only makes sense.
Rick
That's the feeling I'm getting, rounding up all the loose ends before a big roll out of BC-1.4, when that will happen is anyone's guess, April fools day could be the day.
detansinn
United States
I got the ECG-24.2.5.7 update on Saturday morning. 2023 Lariat ER.
It’s encouraging so many trucks got this update at the same time. I am stoked at BC 1.4 coming soon. Fingers crossed.
PS. My kid brother just got a new 2024 Flash. ?? The Lightning brotherhood is now literally a brotherhood. ?
Riverant
MA
2023 F150 Lightning Lariat ER
Got this while at the grocery store. 23 Lariat. Came back to a scary “turn truck on now to save power” or something similar.
no issues but it was a relief to see an OTA after I fully updated modules on FDRS. Wasn’t 100% that wouldn’t break something.
Stalemate
Jeffrey
Seattle, WA
2004 Mustang v6, 2023 F-150 Lightning Lariat
Utility Electrician
I got this update OTA sometime in the past few days. Haven't noticed anything different so far, though.
Runaway Tractor
Yes
This one came through to my 23 lariat a few days ago as well. No notifications on the truck or the app. I noticed by accident today. So once again, great job to the failure of a college interior that does their app development.
ds03
Dan
Charlestown, NH
Musician
How? I have automatic updates turned on, but the last update was Nov. 2024 (10.1.1).
Our last update had been in November, same as yours. Today, the truck downloaded and installed ECG-24.2.5.7. Hopefully other updates will follow, and hopefully you'll get this update soon.
21st Century Truck
Martin
Today, two+ days after I got this Gateway update I noticed that AutoAndroid, which consistently used to get confused and fail to switch the Sync screen background from dark to white after exiting a dark urban tunnel, or just would have the Sync map go blank after emerging from a highway tunnel, now reliably switches light and dark backgrounds as needed and never goes blank anymore.
So there indeed is a difference, at least in the interface between the Sync and this application.
Tdub
Royal Oaks, CA
Here I am complaining about not receiving any OTAs in months and lo and behold, I got one today for the gateway module ECG-24.2.5.7.
I went to the store not more than 10 minutes from the house, by the time I shopped and returned home I got a successful update notice when I turned off the truck.
That funny! I was complaining to myself for the last few months about the lack of updates, and low-and-behold, an update, even though I don’t know what is meant by the description of what the update is all about!
Caliber357x
‘23 Lightning Platinum
Happy to report after being out of the country since 2/25, I got in my truck this evening and received this update. Last one was 10.1.1 on 12/18/24. ‘23 Platinum, not in EAP.
