ECG-25.2.5.7.1 - Consistent Battery (LVB) Performance
luebri
Neenah, WI
I saw this posted on X, and now just received the EAP survey which may mean I got it as well, but that is hard to say based on all the random surveys that got sent earlier today to a few of us.
I'm Not near my truck right now to check.
Consistent Battery Performance This update refines the Gateway Module to prevent
drainage of the 12V battery.
luebri
luebri
Neenah, WI
I did get it but have not received a notification in either the app or the truck. I had to browse to the software updates page on the truck to check and it showed as updated. I would have never checked if not for the early access email.
That said 30 minutes before getting early access survey I did go on a short drive and found it odd my driver display was on an abnormal screen than normal.
bthanos
2023 F150 Lightning Platinum
System Architecture (retired)
Uh I have ECG-25.2.5.7. Does that mean my battery is draining ?
Yeah, just got the survey, nothing in the FordPass app and no popup message on the Sync screen. It does show completed under Software Updates in Sync and I have this on myFord Account Software Release Notes page:
Priority Update - Battery Management
03/06/2025
This update refines the Gateway Module to prevent drainage of the 12V battery.
ECG-25.2.5.7.1
SmoothJ
New Jersey
2022 F150 Lightning
I just got this update and an email as well. It appeared to stop my auto target charging, and it was "waiting" to charge which I found odd. I just started it, and it appears to be charging now.
Using Car Scanner / Forscan Lite, I was able to determine this OTA updated my Gateway Module Strategy (F188) from ML3T-14H021-RCL to ML3T-14H021-RCP
@Mike G @rugedraw
EDIT: It's now even reflected in my online As-Built.
So this is in the EAP testing phase at the moment?
If so, let's append thread title EAP until it goes to the general public, saving the why haven't I got it posts from the peanut gallery!!
lightning-spark
Vancouver, Canada
2023 F150 Lightning Lariat ER
@Mike G @rugedraw
How can you find this info using Car Scanner? Do I have to install Forscan Lite? Cheers
luebri
luebri
Neenah, WI
Since I have been part of EAP (~12 months?) Ford has never made it clear when we are getting a "special EAP" update. The survey I referred to is the same exact survey I have gotten while receiving what I have perceived to be a general release update, since non-EAP member have posted as such on this forum and there was absolutely zero delineation in communication from Ford about their updates other than the surveys we get I have felt free to post.
So my long winded rambling is trying to say... until Ford can give EAP members communication whether an update is EAP only or not, we are free to share.
I was never communicated this was EAP only, so I shared
Whammy Bar
Just got it. F***** up my charge session and I had to restart.
Ford F-150 Lightning ECG-25.2.5.7.1 - Consistent Battery (LVB) Performance 1000029846
I simply want to modify the header to indicate that it's ~likely~ to be in EAP phase, not banning or deleting the conversation, I too have given up suppressing these types of threads, but would REALLY like to minimize the whining that's bound to happen.
BTW, another recent thread indicates the survey email server has suddenly come to life and folks are being flooded with stale communications.
SMH @Ford Motor Company
SmoothJ
New Jersey
2022 F150 Lightning
I had the same issue. Be sure to report it in the survey.
