Mike G
- First Name
- Mike
- Jan 6, 2022
- N. AL, USA
- 2022 F-150 Lightning, 2023(J1) Mach-E GT-PE
I want the Jetson's sound effect sooo bad for my truck!
We believe in you. Make us proud!The ultimate would be to create an app to update the sound yourself from your mobile device, or use the rest of that 32M flash to load multiple sound files and select the one you wanted
Thats the idea!I want the Jetson's sound effect sooo bad for my truck!
I would find a way to compress an audio clip from Ludacris' "move b*tch..... get out the way" song, but I'm a little ratchet, so don't mind me. ?Don't throw tomatoes at me.... but I personally would probably just mimic the Tesla sounds (as that's what I am used to). (They are far less annoying).
That is something I had thought about... And ordered this board to play with but this would also require the circuit to detect the audio. I do have a can bus sniffer, so detecting the play backup and play forward sound messages shouldn't be too hard.What if you could just develop a separate module that connects to the speaker leads that detects when a sound is input and causes it to output a sound programmed into it to the speaker? So basically when there's voltage or whatever coming from the truck module the new module is triggered to intercept and generate an output to the speaker. The truck module wouldn't have to be messed with, and the new module would emulate speaker feedback (resistance?) so the truck module thinks the speaker is working.
