Ajzride
Alan
Houston
Eng
I'll see if I can get it installed after I figure out how to get this extremely short power cable ran to the obd port.
I cut it down and solder sealed it back together.
Drayday55
Drayday55
Andre
San Diego
22 Lariat Lightning
Contractor
Also, Ferrite does Jack on the comma power cable. Installed one on each end and a loop in the middle.
Ferrite installed on every cable in everyway possible way and it still flashes errors for about 5 seconds on startup. So harness modification looks like the only good solution still.
I can also confirm the ferrite choke does nothing.
UncleTony
Tony
2023 Lightning Lariat
Cybersecurity Engineer
I was going to ask if it could be shortened. Wasn't sure what all it's sending through the cables. I'll cut it down once I have time to play with the unit.
UncleTony
Tony
How long do you get errors for? Mine are just long enough to popup the message then they are clear. I'm not sure this bugs me enough to mess with it more than I have.
UncleTony
Tony
Ok, for those that are ordering new kits..
Comma sends you all you need now for the F-150 platform. They now include the long USB C cable with a USB C to USB C connector and the 90 degree standard cable. I taped my connectors with Electrical tape because I was thinking it would end up under the headliner. Now that it is installed, it sits right next to the rearview mirror casing. Leaving the tape as of now because the adapter is silver and it looks better black.
If you want to use Blue Pilot, it seems you will have to use the link @Ajzride posted for staging
installer.comma.ai/bluepilotdev/staging-2.1
otherwise you get stuck on the registration.
Blue pilot is way better than (Base) sunnyride after about a 20 mile comparison on each.
Personally I am going to leave the stock harness on my setup for the time being due to the startup errors being pretty minimal and the fact that I almost always remote start the truck.
1000% times better than blue cruise.
Edit to Add: Ferrites won't do anything to resolve the issue, in my case, I had no errors until I plugged in the USB C and comma unit.
El Duderino
2025 Flash
I am working a deal to lease a 2025 Lightning.
Anyone know yet if the 2025 models have TRON encryption?
Ajzride
Alan
Houston
Eng
If you have a VIN we can try to check FDRS and see if the tron utility shows up
El Duderino
2025 Flash
Thanks for checking! Bummer man...
astrand1
Alex
Studio truck driver
Ok some questions about comma. Really my biggest question relates to the acc and braking. I have a 23 lariat w/BC included for 4 yrs which is nice. I like BC but one thing that drives me nuts is the braking. Like when in stop and go no matter what distance setting it’s on the system seems so aggressive with the brake. I drive a new transit van and it had acc. The braking was so smooth! No matter what someone did in front of me, cutting off quick stops etc somehow it was able to make nice consistent smooth braking events. It felt like how I would drive and do drive. Sometimes you eat up some of the following distance to create a smoother stop where the lightning does everything it can to keep that distance. Almost feels like it’s going to put the front into the ground to slow down. Hopefully you guys get the point. So question is when using the comma does it take over the following distance and braking to any degree or does the oem system always handle that?
Ajzride
Alan
Houston
Eng
You can choose to use the OEM ACC or use the Comma ACC. The comma ACC has a lot more adjustability for follow distance, and acceleration and braking profiles. My experience has Been that aggressive drivers prefer Ford ACC and relaxed drivers prefer Comma ACC.
the best thing would to be either to find someone close and take a ride, or buy one and test it yourself. Comma has a no questions asked 30 day return policy if you don’t like it. Just cost $10 for return shipping.
astrand1
Alex
Studio truck driver
That’s great news. This might just push me over the edge. Yeah sometimes I like to drive fast but mostly not aggressive and that’s what it feels like. I did see about the 30 day trial. I’m thinking I might just try it. Another question. I’ve been watching videos about sunnypilot and now I’m reading about blue pilot on here. I like that if you have the connected nav option on comma you can send a route to comma and it will mostly drive and in some cases kinda try and make some soft turns sorta like fsd does. In your opinion which is the best one for the lightning? I realize they are in beta etc. I’m not afraid to tinker and like testing new tech I’m just looking for some guidance on where the best way to start is. Thanks!
Ajzride
Alan
Houston
Eng
BluePilot is just sunnypilot with a bunch of Ford specific patches applied.
comma got rid of connected navigation because it never worked. They are supposed to rewrite it in 2025 And put it back out there.
basically it behaves like BlueCruise (hands free lane centering) but on any road, not just mapped interstates.
