Red Truck Icon of Doom and Stop Safely Now {Fixed Post #24}
LiteNing
Nic
'23 F-150 Lightning Lariat
1's and 0's and lambdas
Longtime reader, first time poster... maintaining that old tradition of creating an internet account just to get something off my chest (but also seek advice).
Ok internet friends, I'll cut right to the chase: My CPO '23 ER Lightning Lariat with 41k miles has been (mostly) wonderful for the past 5 months, but I ran into the first major problem last Wednesday. After a 4 hour L2 charging session (the limit at my office), I got in the truck to move it. Instead of powering up normally, it started in accessory mode ("Full Accessory Power Active" on the IPC) with blinking green power button. The IPC then showed a message "Stop Safely Now", along with a red icon of a truck with an exclamation point (see attached). The shifter was also locked in park.
Ford F-150 Lightning Red Truck Icon of Doom and Stop Safely Now {Fixed Post #24} IMG_0649 (1)
I tried the usual stuff of turning it off and on again, searching this forum (seems like this error goes away for some people after one or two power cycles) and letting it sit turned off and locked for 30 minutes. When that didn't work, I called roadside assistance to tow it (on a flatbed) to the nearest Ford dealership. First thing the tow truck driver did was hook up a jumper pack, which made no difference.
Some coworkers helped me push it to the entrance of our (low clearance) parking garage so the flatbed could load it. I used the "two pedal trick" to get it into neutral, and I left the truck in accessory mode on the way to the dealership because it kept shifting itself back to park during the push. As luck would have it, the 12V lasted just long enough for the driver to gravity roll my truck off, when the parking brake engaged and the dashboard lit up with every warning you can imagine (parking brake, ABS, front camera, steering, parking sensors, etc). The porter used a jumper pack, a mechanic and an electric pusher to get the truck in a parking space.
The dealer initially wanted $310 just to look at it and $250 for a new 12V before they would touch it. Now, the symptoms I described seem like a pretty obvious HV battery warranty problem (either sticky contactors, or I see some people had problems with the HV battery modules). Why would the 12V just decide to die one day? Doesn't make sense.
On Thursday the service writer (I'll call him Bob, not his real name) called me to say that the new 12V didn't fix it (duh) and this will be a warranty item (so no $310 diagnosis charge, cool, but also duh), but I still need to pay for the 12V battery. Bob also said they would start by swapping the HV junction box (I thought that was only a thing on Mach-e's, but ok...), and if that didn't work I should expect at least a week for them to look at HV battery modules.
So here's my first question for you folks: I know the 12mo/12k CPO warranty doesn't cover batteries... but shouldn't the 12V be covered under the 8yr/100k EV warranty because its failure was caused by the warrantable HV problem? After all, if not for the HV failure (still TBD), I would still have my original working 12V. Anyone else ever run into something like this? Maybe I'm just being cheap, but it's the principle that gets me.
Second, the HVJB is not "a thing" for the Lightning, right? All the forum posts I found through the search feature suggest that only the Mach-e has HVJB problems.
Ok, so I got a text message from Bob this morning, and things go from bad to worse. Whatever they did on Friday didn't fix it and they need to get Ford engineering involved because "the HVB is still energized" (That sounds like sticky contactors to me? But don't most EV batteries have a manual cutout plug you can pull to split the pack? Does the lightning not have that?). Oh, but that's not the best part...
The truck fell off the dolly while they were moving it around the service bay, and there's substantial puncture through the sheet metal on the bed and some deep scratches. I'm afraid this also means they killed another 12V because why else would you put it on dollies unless the parking brake locked again?
Between the as-yet-undiagnosed HV battery issue and the sheet metal, I'm afraid it's going to be weeks before I see my truck again.
Ford F-150 Lightning Red Truck Icon of Doom and Stop Safely Now {Fixed Post #24} IMG_0387 (1)
That brings me to my next set of questions for you folks:
30 days is the magic number for warranty repairs under California's lemon law (including used cars that still have the original new vehicle warranty left)... so it's still a hypothetical right now but... if you were in my shoes, would you or wouldn't you? I'm not really a truck guy, but I love the space, the gut-punching acceleration, the visibility, the floaty ride, ProPower, giant frunk, etc.. That Avalanche paint is just gorgeous. I don't think there's anything else on the market like it right now (and the '25s have smaller batteries and a bunch of feature deletes, right?).
OTOH, this isn't my first (hardware) issue with the truck and the software situation is also driving me nuts (I still don't have WAL). However, the biggest challenge is that my SO is now worried about something like this happening in the middle of nowhere if we take the truck camping, as we had planned to do on Memorial Day weekend.
The damage to the truck is on them. If you don't already have a loaner you should be able to get one in light of this.
It seems like they may have replaced a perfectly good LVB and are stressing the new one while working on it.
What is the name of the dealership? They might fix their mistakes but they aren't starting off very well. Please keep us updated.
Generally, lemon laws don't apply to used vehicles. This is not legal advice and doesn't constitute an attorney/client relationship. I'm not even a lawyer.
Both the Lightning and Mach-E have a HVJB, in fact i just had mine replaced after experiencing the same thing you did.
I wish I had better advice for you. You could play hardball on them. Bottom line, they don't get to play the game of "let's throw parts at it and hope it's fixed". If it's the HVJB they have codes for that. If its the battery they have a code for that. Make them give you the codes.
As far as the 12v goes, tell them to put the old one back in, you are not paying them to try throwing parts at it. And when they say it died when it was drained tell them they did that to the new one and you want a new new one. Bottom line don't let them make you eat the cost, replacing the 12v is an idiot repair when they could have just put jumpers on it to see if that was the problem. That said, at 40k it's not a horrible thing to have a new 12v either, but they likely just drained and killed your new one, which isn't good on them.
jetfixr1
Anthony
Atlanta
2023 F150 Lightning Lariat ER
Second this. Dont let them throw parts at it at your expense. I would ask them to comp the 12V or give you back the old one.
Piquette
Trent
New Hampshire
2022 Lightning Lariat
Whatever the final outcome on the initial repair, find a new dealer. Your dealer’s incompetence is mind boggling.
It's curious that the contactors remain energized, could that be a rogue signal from ECM/PCM ?
Seems like the technician isn't using his diagnostic protocols correctly, throwing parts before fully understanding what the root failure is.
As stated previously, we've seen several reports of contactors (HVJB) failures on Lightnings, not to the same extent as MME's though.
Bigisland Guy
Ed
So Cal
Retired Old Dude
I'm not sure which dealership you are dealing with in CA, but there are some knowledgeable techs in S CA in the OC and N IE that the Ford EV team (whom you can contact) helped me with on my 1st F150L before it was lemoned.
MaintGrl
Marsha
El Sobrante, Ca
Might this be a time to get in touch with the BEV team?
LiteNing
Nic
Thanks for the support, guys! Going to consolidate into one reply since I’m at work:
Yea, I’m thinking about asking them to put me in a Mach-e (preferably a GT) while it’s in the shop. I didn’t go that route yesterday because I never got around to selling my Volt and didn’t want the hassle of going to the dealership… but the commute this morning reminded me what a rattle-y (but reliable) car it is. Feels like driving an underpowered go kart. Kinda fun in a completely different way to the Lightning.
Sunnyvale Ford in Sunnyvale, CA
Yea, we do some strange things out here in CA, and this appears to one of them. Obviously if I went that route I would get advice from a real lawyer (no disrespect to the internet lawyers!)
Yea, they also “could not reproduce” the front end vibration at the 40k service a few weeks ago. That should have been my signal to have the roadside assistance drop it off at a different one. Haven’t had time to do a road test with the mechanic, but it’s such an obvious thing that I wonder if they even checked it. Unless they impress me (in a good way) I don’t foresee coming back to this one.
I’m up in the Bay Area. How would I contact the EV team?
LiteNing
Nic
Well, Bob just got back to me while I wrote the last post.
They replaced one “module” on the basis of some test. That didn’t fix it, so they are going to replace another module. I have asked for clarification and the diagnosis codes but I assume he means HVB module.
Bob says they were not allowed to preorder a second module until they replaced the first one. He did not say if they is a Ford policy or a dealership policy.
WOW, they had a HVB module on the shelf ready to use!?!?
Doesn't sound right to me, unless they are very close to a regional parts hub!
LiteNing
Nic
Bob told me on Thursday morning (on the phone, it’s been text messages since then) that the plan was to do the HVJB Friday and then start replacing HVB modules if that didn’t fix it. He also told me to expect a week in the shop if the HVJB didn’t fix it. So maybe they ordered a HVB module Thursday morning, expecting a long lead time?
Bob also just texted me the diagnostic code: U0312.
U0312 means “Software incompatibility with the battery control module”. Sounds like they F’d something up when they were trying to do the update(s).
These codes don't leave much to the imagination and anyone with FDRS (your dealer is using it) can tell in 5 minutes if there is a battery module issue and exactly which one needs to be replaced. Sadly you're getting screwed by the dealer. Especially starting off with the 12v battery replacement before anthing else.
LiteNing
Nic
Well, I got another update from Bob. The module they replaced on Monday was not a battery module. It was the HVJB (which I thought they had already done on Friday, that's why I thought "replaced the module" meant they replaced a HVB brick). So that sucks, but I guess TaxmanHog was right on the money.
Bob says they are waiting for some one-time use components. No word about replacing the HVB module(s) or resolution of the U0312 code, so I need to follow up with Bob.
One thing I like about Bob: He's fairly proactive about reaching out. Some people it feels like pulling teeth to hear from them.
One thing I wish Bob would do differently: It sure seems like a lot gets lost in translation between whatever is happening in the shop and what Bob tells me, and I seem to always have to follow up with clarifying questions.
I tried reaching out to the EV team by DMing the @FordMotorCompany account, but no word yet. In the meantime I'm just watching Munro Live to learn more about the HV system.
