- First Name
- Greg
- Feb 15, 2022
- Dallas, TX
- Lightning Lariat ER, Performance Y
- Occupation
- IT
When using the app to remote start / turn on the AC, do we know if there is any control from the app (iPhone in this case) other than a signal to say 'start' and the truck then decides what to start - heat or AC?
The problem / question is it is over 80 degres in TX these days and I've used remote start twice recently. Both times the truck has started the heater, and turned on the seats and steering wheel. I've double checked in the truck and all of the settings are set to Auto as they have always been. The first time inside the truck was probably 120 degrees and today it was in a parking garage, but still no way the truck should have thought it needed heat.
I only question the app as I'm running a beta, which I won't discuss any further, other than to say it is. I wouldn' t have expected this result though. The truck should handle what to do based on external temp. This second time I did check after the remote start and the app showed the heat, so I was able to adjust it and get it cooling rather than heating.
Anyone else experiencing the issue or is it isolate?
