pjr
pjr
2023 Lightning
In the name of science I can report that the Maverick NZ6P-7P155-AD, Escape PZ1P-7P155-HC and E-Transit NK4Z-7P155-D shifters work (for me, no guarantees or responsibility how it works for you) and appears to retain all functionality including Auto Hold.
The Escape dial has ambient light in the base of the dial, Maverick and E-Transit does not, neither of them have a mechanical / motorized return, it's just the LED indicator emulating that it's moving back.
Thank you
HisSvt2
2023 F150 Lightning 2024 Mustang Mach-E
Admin
First post here new member
Order my rotary knob from ford and the mount from Etsy which may be a bit but from what I see for my XLT it looks like I have to pull some dash trim and unscrew the bottom controls to pull the center trim does that sound about right? Also has anyone painted the 3d part to give it a nicer finish or better heat resistance? Also what size screws are we using to attach the dial to the 3d part? Thanks
jeff_h
WV
2023 F-150 Lightning XLT ER
Paint-Drying Observer
I also have an XLT with the smaller screen, see post 361 of this same thread where I added a few notes and pics from my install. It may have been cleaner to "pull some dash trim and unscrew the bottom controls to pull the center trim" but I ended up using a big screwdriver to pry things apart in order to get the tabs out of the center dash area then cut the tabs off (pic in post 361) before putting things back together as the side pieces and top frame appear to hold things in place just fine.
MammalFur
Grant
2025 F-150 Lightning Lariat
I was thinking if I went ahead with the conversion I'd like to put the rotary shifter in place of a trailer brake controller (which my truck does not have) - anyone have any thoughts on that end?
masonta
Electrical Engineer
HisSvt2
Admin
Thanks for the reply. I saw a video from a regular f150 same year looks like mine and I have the proper trim tools so doesn’t look to bad just that ling trim piece is only part to really be careful with as it’s actually a $400 dollar piece on Ford parts😬
RLXXI
S. E. Louisiana
Auto tech
I think I'll wait before buying anything replacement part wise for this truck, it's still brand spanking new, 2 weeks old this coming Saturday.
I should have no problem swapping it out when the time comes, this is the type of work I did when I worked at a Ford dealer. I fully plan to buy an extended warranty to cover all the electronics and things of this nature before the 3 yr BTB warranty is up, I've personally seen those pay for themselves in one visit to my shop.
trucktrucktruck
Ben
F150 lightning flash
Question for anyone with the Ford Escape shifter. I bought LX6Z-7P155-U from this eBay site which I know some others have bought from. But the actual part number printed on the part was PZ1P-7P155-AC
Has anyone else who bought from that site get one with the same part number? I'm trying to figure out if I need to return it or not.
masonta
Electrical Engineer
I believe the ford PN is listed on the other side (or underside, I can't remember exactly).
In any case, the escape shifter i purchased had that same number on the right side (you can see it in the attached image)
Ford F-150 Lightning Stick to Rotary Shift Knob Conversion w/ 3D Printed Rotary Shifter Holder 20250630_202235
trucktrucktruck
Ben
Great! Thanks so much.
jeff_h
WV
I'm not giving up the rotary shifter, have seen several posts here and on reddit from owners who have reported issues with second or even third shifters, and remember there was a QA hold on that part for a few weeks wasn't there? No thanks, my rotary shifter is working fine so not inviting trouble by going back to the OEM.
richguy82
Richard
2023 Ford Lightning Lariat
I have a shifter related story. I thought it was similar to some of the posts I had read here. I went into a PDQ restaurant the other day and saw a Ford Raptor in the drive through. The drive through is very narrow and I thought he was stuck. He was still there when I left so I went over to see if I could help in some way. As it turns out, he was trying to free himself from the narrow drive through and his shifter just locked up in reverse and started flashing. I offered to help him disconnect the 12V since I didn’t know what else to do, but the tow truck driver showed up right then. This is definitely making me want to make the switch now….
But are our 22's & 23's susceptible as the 24's & 25's called out in this CSP?
