richguy82
Richard
2023 Ford Lightning Lariat
I have a shifter related story. I thought it was similar to some of the posts I had read here. I went into a PDQ restaurant the other day and saw a Ford Raptor in the drive through. The drive through is very narrow and I thought he was stuck. He was still there when I left so I went over to see if I could help in some way. As it turns out, he was trying to free himself from the narrow drive through and his shifter just locked up in reverse and started flashing. I offered to help him disconnect the 12V since I didn’t know what else to do, but the tow truck driver showed up right then. This is definitely making me want to make the switch now….
Apologies, I was trying to post this in another thread.
richguy82
Richard
let me know which, I'll move these posts there
I suppose it’s somewhat relevant to this thread, but I was looking to post into the recent rotary shifter thread.
Vancouver, Canada
2023 F150 Lightning Lariat ER
I purchased a rotary shifter that I would like to test but not install. Is there an easy way to remove some trim and get at the connector temporarily so that I can test the replacement shifter? Thanks in advance for any help! :giggle:
The Weatherman
Dean
South Central KY
@lightning-spark
Yes. But you will have to leave the trim open while testing.
The Weatherman
Dean
South Central KY
What do you mean level the trim? Can I just remove the drivers side trim and have enough access? Thanks
No, I don’t think so. It’s a tight fit with little room to remove the connector unless you pull the GSM out first. But hey, you might have small enough hands to do it, but my hands are pretty big.
OtterJohn
Philomath, OR
Pulled the trigger this afternoon: ordered the ABS version of the Etsy tub, and the Escape shifter via eBay link others have had success with. Probably be end of August before I get everything, but that's fine...but I'm looking forward to this changeover. :)
VAL.ABAPO
2025 F150 LIGHTNING
Just installed my version today and it worked great. I've got a handful of people to thank that made this possible.
@jmyer72 thanks for the initial idea and the link to the shifter on ebay.
@asianman35 huge thanks for printing this out for me after I was unable to print this on my own printer. He printed and shipped this thing in no time.
@ENDianDigital thanks for posting the original file on Thingiverse. I modified it to fit my Nalgene and it worked out perfectly.
I'm happy to share my version if anyone wants it.
Very happy with how it turned out!
Which rotary shifter did you get? Im using the same bin design. TIA.
Coachmrj
Melvin
2024 Ford Lightning XLT SR
Teacher/Coach
I got started with an assist on the print from @Drayday55 for the rear-seated tub with a large cupholder in the front, and have just made an upgrade after purchasing my own larger printer and grabbing the Bronco Sport shifter! I enjoy the way everyone is keeping the thread fresh with remixes of the original. I now have my first complete install and some printed bins that I didn't use while getting the print done. If anyone needs a hand, like I was given, just DM me. I printed mine in PLA+ because ABS went stringy on me ( I didn't have the dryer on the filament and wasted 18 hours). I did increase the walls in the build for more strength and changed the supports away from the tree style to the accordion. I haven't had any problems with the East Texas heat over 100 degrees so far.
Ford F-150 Lightning Stick to Rotary Shift Knob Conversion w/ 3D Printed Rotary Shifter Holder IMG_2934
Ford F-150 Lightning Stick to Rotary Shift Knob Conversion w/ 3D Printed Rotary Shifter Holder IMG_2933
Ford F-150 Lightning Stick to Rotary Shift Knob Conversion w/ 3D Printed Rotary Shifter Holder IMG_3126
Ford F-150 Lightning Stick to Rotary Shift Knob Conversion w/ 3D Printed Rotary Shifter Holder IMG_3125
Ford F-150 Lightning Stick to Rotary Shift Knob Conversion w/ 3D Printed Rotary Shifter Holder IMG_3123
jeff_h
WV
2023 F-150 Lightning XLT ER
Paint-Drying Observer
I have one with round cup holder and found the below 2-pack for $4, used the black one (wife was happy to have the green one in kitchen for opening jars) and cut the diameter down about 1/4" at at time until it fit nice and snugly. Now the screw head (mine has one of the screws there) is covered, the rubber piece is snug in there and doesn't get stuck to the bottom of coffee mug, and if it needs cleaning it's easy to reach in and grab and remove and wipe down with cleaner as needed.
https://www.walmart.com/ip/Silicone-Jar-Openers-2-Pack/5605934707
HisSvt2
2023 F150 Lightning 2024 Mustang Mach-E
Admin
I asked before but haven’t seen yet in any videos , if anyone with an XLT with the smaller infotainment screen has done this and has the exact proper removal procedure for trim pieces it would be greatly appreciated these trim pieces are quite expensive so I don’t want to break anything. Thanks
