K6CCC
- First Name
- Jim
- Sep 12, 2024
- Glendora, Calif.
- 2024 Lightning Flash ER in Antimatter Blue w/9.6 PPO , 2017 Corolla (wife's car)
- Occupation
- Retired from 2-Way radio systems
May sound like a dumb question. Are you plugging your adapter into the truck and then plugging the NACS cable into the adapter, or are you plugging the NACS cable into the your adapter and then plugging the adapter into your truck? The reason I ask is many people here have reported that only one of those procedures work - and it's not the same. Personally the only time I have had a Tesla SuperCharger fail (showed Charger fault) was the first time I used it and I plugged the adapter onto the cable and then into my truck. After not getting it to work, I disconnected everything and the second try I plugged the adapter into the truck first and then plugged in the NACS cable. Worked perfectly. Ever since, I have plugged the adapter into the truck first and it has worked every time (both V3 and V4 stations). I have the A2Z Typhoon Pro adapter. Many people have reported that they have to plug the NACS cable into the adapter first.
As far as a Tesla or EA membership, remember that you can pay for a membership, and then cancel it. The membership will be valid for a month. If you are going to be taking even a one day long drive that will require one or two fast charges, it will likely pay for the membership for the month. One more note on that - make sure it actually cancels. I activated an EA membership a couple months ago for a trip where I expected to charge one time at an EA station. After I completed the trip I cancelled the EA membership. It showed that I cancelled, however I couple days ago I saw my credit card was billed for another month. I called EA and the person was able to see that I had cancelled it and did not know why it auto-billed. That person submitted a request to refund. We'll see if that works.
