Powertrain Malfunction/ Reduced Power
Just got this.
23 Lariat SR.
7/23 manufacture date.
29,000 miles
No recall or CSP for battery issues
Got the orange wrench at ~56% battery level and after a 20 mile drive. Had not charged since Saturday afternoon.
Dismissed the warning and I only had 57% power. Went to get a haircut and when I came out I only had 53% power. ?
Made it home and plugged in. Charged up to 62% battery level and it errored out. Orange ring on the charge port now. ?
Called my local dealer and the soonest they can get me in is next Monday. ?
What should my next steps be? Guessing charging is out? I commute 60 miles a day and need to be in the office tomorrow for a meeting. Would I be ok to make that drive or should I make other arrangements?
Yeah, the power + no charging leans heavily towards battery failure. The safest thing would be to make alternative arrangements. Call the Ford BEV hotline and get a case # going. If you need a rental, ask for reimbursement policy. Several have had good luck with this.
JSBishop
Jon
F-150 Lightning 2024
IT Stuff
Powertrain Malfunction / Reduced Power
Service vehicle soon Orange Wrench on dash display 7314.6 miles on a late year 2024
Ford App says Powertrain Malfunction / Reduced Power but dash display reads 100% power available no noticeable decrease in power, but not pushed hard.
Forscan picks up a Code:
P0929 – Gear Shift Lock Solenoid/Actuator Control Circuit ā€˜A’ Range/Performance
Additional Fault Symptom:
- Commanded Position Not Reachable
Status:
- DTC Present at Time of Request
- Malfunction Indicator Lamp is On for this DTC
Module: Gear Shift Module
This is probably the third or fourth time this ā€œService vehicle soonā€ has popped up starting in June. This last time after I stopped the truck, turned it off, plugged in the OBDII reader, turned the truck back on, the orange wrench was still on, took a reading in Forscan, found the shift lock error. Then I pushed the Shifter fold down button and like magic the error cleared. Seems like some kind of bad motivator in that Shifter thingamajig, I distinctly told the dealer when I spontaneously purchased the truck I thought that shifter was not a good idea and some buttons, or a spinner would be less likely to break. Ford if you are reading this, why don’t you make a spinner replacement kit available with a new tray, so I don’t have to 3D print my own and hack a $80,000 truck… Just asking, no I did not pay that much but that was list at the time.
Ford F-150 Lightning Powertrain Malfunction/ Reduced Power IMG_0686
Ford F-150 Lightning Powertrain Malfunction/ Reduced Power IMG_0682
Ford F-150 Lightning Powertrain Malfunction/ Reduced Power IMG_0681
Ford F-150 Lightning Powertrain Malfunction/ Reduced Power IMG_0679
jetfixr1
Anthony
Atlanta
2023 F150 Lightning Lariat ER
Status:
These GSM's are such a piece of absolute shit! Saw a post today on reddit, new 2025 ICE F150 stuck at a drive through because he threw it in park and wouldnt shift. Surprised this isnt a recall yet.
ScubaSteve_TheReal
Steve
Midwest USA
Derivatives
Ugh, got these this am..!! Dealership can’t see me until the 31st to diagnose and order likely battery modules.
Reduced power to 20% and Powertrain malfunction with high voltage battery warning.
POB24(21)
Hybrid battery A - voltage unstable
Status: Test failed, Test failed (current drive cycle), Pending, Confirmed, Test failed since last DTC clear,
Warning indicator requested
This looks like a repeat of my first truck that I lemoned back to Ford back in March 2024 and bought this one.
My luck..!!….Bad luck
Ford F-150 Lightning Powertrain Malfunction/ Reduced Power IMG_1093
Engelwood
Thanks for the response. Will give the dealer a call today and see if they can give me the codes. After reading through this thread and others it sounds like a bad battery module based on others experiences
Made it to the gym this morning which is ~2 miles. The 62% battery level dropped to 60% about 15 seconds into the drive. Thinking that tiny charge yesterday was mostly a phantom charge.
Update: Bad battery module. Truck is out of commission for 10~14 days.
Good news is the dealer has me in a loaner so I'm still mobile. 2025 XLT. The 650+ miles of range on a full tank is nice, but it's slower, louder, and I miss my truck.
ScubaSteve_TheReal
Steve
Midwest USA
Derivatives
Update: <Bad battery module #1
No time frames yet on parts or ship dates as of today @ closing time.
Finding it very strange I’ve owned two 2023 Lightning’s and each one has had a bad module, with truck build dates nearly 14 months apart.
Thinking it’s about time that ford needs to admit that this is a bigger problem than they are saying in numbers of trucks affected.
I've been saying this a while. This isn't a random unknown. It's time it gets bigger attention.
Warren
Warren
Ohio
F150 Lightning Pro
Carpenter
Got mine back from service on Wednesday. Mine is the shifter module, as I suspected. Took a few days to get the part, so will take it back next week for that.
SpaceEVDriver
Arizona
Sigh.
We finally ran into our first major problem in >70k miles of Mustang Mach-E and Lightning ownership.
Got the Powertrain Malfunction/ Reduced Power message in FordPass and the SVS alert on the dash. Pulled the P0929 code with CarScanner.
Ford F-150 Lightning Powertrain Malfunction/ Reduced Power Screenshot_20250808-225712
jetfixr1
Anthony
Atlanta
Sigh.
Another one bites the dust…. Not that its of comfort but imagine how many pissed ICE owners there must be with this POS GSM
SpaceEVDriver
Arizona
No wonder the dial shifter jumped from $80 to >$200 on eBay. I guess I have to find that BEV team phone number sometime this weekend.
jetfixr1
Anthony
Atlanta
1 (800) 392-3673 BEV Team
1 (833) 926-3287 Software
1 (800) 334-4375 Ford Marketing
EvilUser007
2024 Flash, 2015 Model S, 2017 MS
These are the folks mentioned in this thread so far with problems, a couple seem to have self corrected. Who is missing here if someone knows of 33 reports in the forum? Wish folks would put more in their signatures of build date, model detail, and battery type. Maybe @Ford Motor Company would give us a complete list!
230313 Power Malfunction Reduced Power F150Lilghting Forum list of people Screenshot 2023-03-...webp
Let us know of any missing details and outcomes of HV battery problems and I will try to update the spreadsheet:
Here is link to an extended Google Sheet, including another forum battery problems threads:
230313 Powertrain Malfunction - Reduced Power forum track list - Google Sheets
Am I missing anyone?
MODERATOR
Fix link to read only version
Yep. As of today you can add me: 2024 Flash ER build date 10/24 3K miles Service Vehicle Soon, Wrench Icon, Powetrain Malfunction/Reduced Power. "what should I do?" A pwertrain or AWD fault has been detected, contact your authorized daler as soo as possible. Truck seemed to drive fine. Power was equal Front/Rear and not reduced. Made it home (10 miles) without problem. Wrench now gone and no warning except in history.
Edit: Took it to the dealer. They said no error codes in history. I swear I wasn't hallucination (took a pic). Come pick it up it's ready to go. Making me a bit nervous. Should I use Car Scanner or something to check battery health?
Edit: Flash ER, build date 10/10/24
Ford F-150 Lightning Powertrain Malfunction/ Reduced Power IMG_1556
Ford F-150 Lightning Powertrain Malfunction/ Reduced Power IMG_1554
Warren
Warren
Ohio
F150 Lightning Pro
Carpenter
Warning will pop up again. I drive mine for about 3 weeks during the issue, and never noticed anything. I rarely venture more than 10 miles from home though.
