PJnc284
Garner, NC
Man,
That sucks, hopefully that is the only thing that is damaged if that is the case.
I wish i had someone in Florida to help me clear the codes...
Im the complete opposite, i had Windows for many years, then for work they issued me a macbook pro and when my windows laptop i had from college died, i just never had a reason to buy another. I windows desktop in the house for gaming, but that doesn't help me lol. Guess ill be shopping for a cheap used windows laptop.
Where in Florida? Post in the forscan or fdrs threads and there may be someone that can help
EVO
Randy
2024 lightning flash
electrician
The unit is working fine however it doesn't seem to be updating. I plugged in the 12v so it will be on when truck is off. I Attached a picture. Am I missing something?
Ford F-150 Lightning Comma AI self driver assistant PXL_20250817_230550764
UncleTony
Tony
2023 Lightning Lariat
Cybersecurity Engineer
That is not the right menu for updates. That is a dev menu. The software tab should have the update status.
EVO
Randy
electrician
Okay, thanks. Is there a, this is the settings, here are the toggles you need enabled, etc. I hate bothering you guys with seemingly simple questions. if I just had some type of instruction sheet it would be help full.
UncleTony
Tony
Reactions: EVO
EVO
Randy
electrician
Storx
2022 Ford Lightning Lariat ER, 2022 Tesla Model S, 2017 Tesla Model 3
Yea, when he plugged into the grey plug, he sent 12+ and 12- through several connectors on the harness box meant for canbus traffic. he also sent ground to a few spots expecting 12+
Update, when i woke up for work, the faults were all gone. I had no issues driving my 40 mile trip to work. Im going to place an order for the little box, sucks but mistakes happen and ill gladly pay for just that over something more expensive in the truck.
I will say, going back to the video i wish i had continued to watch to see the correction in the video, i would recommend going in the video on YouTube and cut that section out to assure another goofball like me doesnt make that same mistake. I wish the plugs were different to make it more obvious, because it easily goes into both plugs on my box, in the video you mentioned it doesn't fit.
I did order the cable recommended for forscan on amazon lastnight and it was on my doorstep at 5am.
Ajzride
Alan
Houston
Eng
I could not figure out how to change the video. The only option is to delete it and the create a new video. Perhaps I should just delete it now that i have a second video up.
RyZac
Owen
2023 ER Lariat w/Max Tow; 2021 LR Model Y w/ Boost
My 23 Lariat ER got BC 1.4 yesterday. Of course I haven't removed the Comma to see how it behaves. Lol
UncleTony
Tony
Its nothing to write home about. Its a bit more stable and drops out less. Other than that, you gain automatic lane change on blinker.
Reactions: EVO
PJnc284
Garner, NC
pfft. I've had it since last October and still bought a comma. Have another 2.5yrs left of my trial too.
UncleTony
Tony
I have until 05/22/2027 on mine.
RyZac
Owen
Comma has been working great on bp4.0. The only notification I get is a " Lane-Keeping System OFF" when I first enable the comma. Hit OK once and enjoy the hands free after that.
Reactions: EVO
WilliamRobert
Western Pennsylvania
2022 F-150 Lightning, 2023 Mustang Mach E
happily retired!
Finally got my Comma with bp4.0 to work in my 2022 lightning Lariat. This is the cable that made it happen!
Ford F-150 Lightning Comma AI self driver assistant IMG_1402
campalex24
Alex
2024 Ford Lightning Flash
Hospistalist
Then I would agree that the comma seems to be defective. You can always try your thunderbolt cables for good measure. They should operate the same, as they are the same as 3.2 gen 2x2 internally (In this use anyways).
Edit - Disregard the TB suggestion, I see that you already tried that earlier on.
@UncleTony @Ajzride
Wanted to let ya know the knew one showed up, plugged it in with the custom harness I had ordered (thank you!) and it immediately worked, without problems, so it would seem it was the other device! Thank you immensely for helping me work through troubleshooting so I didn't just give up on it!
