Enabling charge speed on dash.
majorgearhead
Summerville, SC
2023 Ford Lightning Lariat ER
Computer Systems Engineer
I did this mod sometime back. Have a stable 100a power supply (overkill). One important thing after you load the firmware is to apply the asbuilt from the model year that had this IPC version else you may have some weird operational bugs.
I have put many thousands of miles on the truck since doing this and it has worked flawlessly. I love the better Blue Cruze animations and of course the charging speed is super helpful to see speed at a glance when at a charge station. I am very happy I did this mod.
tnugentfl
palm coast, fl
2023 f150 lightning lariat ext range
I have a 23 Lariat. If I do this mod and then use a new as built for the ipc will I lose other nods ina
Have made like matrix headlights, and have to then again?
Yep, I'm planning on adding a nice 175a anderson connector to a good ground and right to the DCDC converter output so I can just plug in to a really solid connection and avoid the clamps all together.
I like you are using a server power supply. I do the same thing. As for clamps, I don’t use them. I made a short 3-foot cable set off the power supply with a ring termination. Then use a 6mm nut to attach to the positive terminal and the BMS sensor (not the negative terminal). There’s enough exposed thread on each of those studs to just stack the terminal and extra nut. Worked well And gives a solid connection. Could put your Anderson connector there.
shoopg
Garrison
Utah, United States
www.lightningretrofit.com
'22 F150 Lightning Pro | '21 Polestar 2 | '18 Charger Scat Pack | '98 Ford F250
Cloud Engineer
They're perfect for the task! This was the first time using this one that I just built so it was a great test. I used a smaller one in the past for a Chevy Volt but wanted to have some head room and build a beefier one for the truck.
majorgearhead
Summerville, SC
I had to go back and reapply the bits I had changed for the mods I did like matrix headlights. I kept all the changes done in a notepad so it was relatively painless. All of them are in the first couple of pages in the Forscan thread.
PJnc284
Garner, NC
You should be able to restore your ipc backup after loading the 2024 config also. Just be sure to make note of what 720-13s and 720-14s were in the 24 config and update after restoring. Otherwise you get a config error.
I'm all for updating vehicles, but this data is right there in CarScanner, so if it isn't an easy FORScan update, I see no reason to bother.
ytwytw
Toronto, Canada
2023 F150 Lighting ER Lariat
So what's the procedure?
I have stock IPC with no customized value
I can use forscan to flash the IPC and then use forscan to modify the hex value via as built and good to go?
The 23 and 24 firmware has different value mapping right? Do I need a 24 latrit LR as built hex to start and write the vin
shoopg
Garrison
Utah, United States
Cloud Engineer
if you’ve got no changed values in the IPC then just do the update and dump this stock as built from a 24 Lariat in your IPC
2101 is due to the lower portion seatbelt config. You can load a complete 24 IPC as build file and write it.. it will clear the 2101..
here is an as build you can use
2024_IPC.ab
windydrew
Kansas
23 Lightning Lariat ER
Solar Installer/Electrician
"The operation is not safe",,, LOL,, it's almost as if they are trying to scare you out of doing MFU :(. Does anyone who has familiarity of FDRS know if these exact same warnings get prompted with FDRS. I've always assumed FORScan just copies everything from FDRS, I'm curious if they added scare tactics to really weed out the less confidents tinkerers?
All that being said, don't be scared. I had a little charger on mine and it failed twice, 2nd time like 3hrs in when my battery got so low the truck started freaking out, lights flickering and all,, I got back from dinner and the batt voltage was 8V,,, Dohhhhhh,,,, All that shit, and it worked on the 3rd try with an 80A automotive roll around charger. Also, let me say, as an electrical engineer, There should be no way to damage anything with failed updates. Since the 90's engineers have figured out how to do checksums and full firmware integrity checks that rely on downloading before ever initiating the actual firmware swap within the processor's memory space. If Ford isn't doing a robust job of this then that is severe negligence on their part. Still we hear about dealers bricking modules and such, it's a bizarre situation we're in with a truck who's manufacturer's strong suite is not software. I'm so glad we have a good community of people curious and willing to push the limits to work on our own shit. I love seeing the overall success of real world owners figuring stuff out. Hack on!
You say that but my Ford dealer basically bricked my 5mo old lightning by not having a charger on it during a CSP which updated all the modules. They had it for 35 days trying to repair, replaced front motor inverter and coolant pump twice. The issue was that the coolant pump ran at 100% as soon as you started the truck. The inverter controls that and they found that after replacing the pump twice thinking it was the issue.
ZSC100
Zach
Tulsa, OK
Electrical Engineer
They didn't brick your truck. They just did something they didn't know how to reverse. If I had a dollar for every time Jesse has stepped in and fixed a truck when a certified mechanic at a dealer said it was bricked I'd be rich.
PJnc284
Garner, NC
If Jesse can't fix something you might as well buy a new truck because Ford won't figure it out.
ytwytw
Toronto, Canada
couple thing for those people flashing their Canadian Truck
You need to use ForScan to change units, its US truck config file, so it comes with miles and Fahrenheit as default
lots of chimes are disabled comparing to canadian version, i wanna the chime when lane assist cancelled, so i enabled it manually in forscan
Glare Free need to be re-enabled, only the IPC part, otherwise it doesnt work
also i like the new interface, finally I have a working bluecurise 1.4 interface that shows lane change animation, feel like bought a new truck
  • 720-01-01 — Vehicle power-down (max idle) & general IPC flag bits (includes the 30-min idle shutdown toggle area).
  • 720-01-02 — Chime behaviors (door-ajar chime, startup “triple” chime; simple nibble edits).
  • 720-02-01 — Key-in / key-left-in-vehicle chime (subtract 0x8 in the indicated nibble to disable).
  • 720-02-02 — Outside-air temp / small telltales enable (bit in this block gates OAT display across CGEA 1.3 IPCs).
  • 720-03-01 — Speedometer calibration / market scale (NA vs EU MPH/KMH behavior).
  • 720-04-01 — IPC calibration block (housekeeping constants; rarely user-toggled). (Sheet lists it under IPC 720 as a cal block.)
  • 720-04-02 — Region code / units base (e.g., US=5553, Canada=4341 → affects default MPH/KMH presentation).
  • 720-05-02 — Units & display formatting (clock 12/24h, temp °F/°C & related UI prefs grouped here). (From IPC 720 grouping in sheet.)
  • 720-07-02 — Info pages / gauges view mask (which instrument pages show up by default). (Companion to 07-01 gauge options in sheet/threads.)
  • 720-09-01 — Driver-assist gating (TSR/FCW camera linkage) (iod/TSR bits live here).
  • 720-09-02 — PACM / pedestrian-alert & related camera flags (common tweak block for alerts/back-up speaker behaviors).
  • 720-10-01 — Turn-by-turn in cluster (Nav/CarPlay/AA TBT) enable mask.
  • 720-11-01 — Hands-Free/BlueCruise cluster gating (HA/BC presentation toggle).
  • 720-11-02 — Additional driver-assist/telltale config (aux flags paired with 11-01 in the sheet).
  • 720-12-01 / 720-12-02 — 2024 IPC auxiliary message/alert group (newer Lightning layout; sheet shows as added IPC 720 block).
  • 720-13-01 / 720-13-02 / 720-14-01 — Seatbelt info screen + chimes (2024 Lightning moved belt logic here; set to zeros to match your 2023 behavior).
Aminorjourney
Nikki
Internet
www.transportevolved.com
2023 F150 Lightning Lariat, 2017 Chevrolet Bolt EV, 2006 Vectrix VX-1
To confirm, because I know if I have questions, others do too. Hoping someone here can confirm in plain language like not so smart.
1) If you have a '23 with IPC mods from previous tweaks you
a) complete the upgrade with the '24 IPC and then you must
b) apply an as-built for your chosen vehicle (in my case, a Lariat ER with max tow etc.)
c) re-do the mods as desired, but using the '24 IPC sheet.
Is that correct? Have I missed a step? Do I need b) or can I go right to c)?
2) Best to do the IPC updates before applying any of the new centre screen changes to charging preferences?
3) 12V, 100A Server supply a good way to ensure the truck stays happy. Disconnect the 12V battery, and use jump start terminals to connect the Server Supply?
Want to give this a go, no stranger to FORSCAN, but also don't want to brick ;)
