EV motor maintenance? Gear fluid change? When?
PreservedSwine
Fort Myers
2023 Lightning
Over 600 page owners manual, and the closest thing I can find is changing the "transmission fluid" at 160k. Since we don't actually have transmissions, are we to assume this is the ev motor gear fluid?
Other than flushing the brake and cooling system fluid periodically, are we supposed to change the ev motor fluid occasionally as well? I'm assuming letting the ev motor fluid go unchanged for too long would ruin the motor, but I really don't have anything to base this on.
Any input appreciated.
shoopg
Garrison
Utah, United States
www.lightningretrofit.com
'22 F150 Lightning Pro | '21 Polestar 2 | '18 Charger Scat Pack | '98 Ford F250
Cloud Engineer
It is technically a single speed gear reduction transmission.. I'm going to be changing the fluid in both motors at 75k personally. I want to inspect the fluid for metal before the warranty is up.
21st Century Truck
Martin
I had this very thing go BLOOOEY on my old Mach E Mustang, when the fluid in the front motor leaked internally through the motor seals. The techs showed me the orange motor connector when they took that motor out under warranty, and the fluid was visibly oozing through the orange connector's pins.
Per the techs' discussion with Ford Corporate and with me later, the fluid is the usual Motorcraft Mercon transmission fluid, and its function is to both cool and to lubricate the big electric motors. Some of the motors' internal parts are lubricated while other internal parts are dry... hence the internal seals.
I assume the Lightnings' electric motors use the same or very similar technology.
BTW -when, still under warranty but toward the end of the warranty as it was affected by the motor changeout (12 months's warranty for a major new part like that) the front motor had to be changed out once again i.e. 3 front motors in 75 thousand miles / 26 months of ownership, I traded that Mach E in for the current Lightning. I figured "let's make this hard-driven Mustang the next guy's problem" despite the depreciation.
RLXXI
3rd rock
Automotive Technician
According to the owners manual, 150,000 miles change the oil in the transmission, other than that it's just look at stuff, rotate the tires, replace the cabin filter every so often.
Farafield
Kim
Vermont
Ford F150 Lightning Flash
Check coolant.
You can review the maintenance schedule in the Ford app as well.
Jseis
Washington
On a Lightning tear down (Munro), I recall he “estimated“ final drive transmission ratio from the electric motor at 7:1 and max motor rpm at 14,000.
Given the lack of ICE engine heat/waste heat , a gear drive oil change at 160K seems reasonable.
RLXXI
3rd rock
Exactly.
WXman
Central Kentucky
2025 F-150 Lightning Flash
Meteorology/Transportation
All the published specs show it at 9.61:1. But I'm not sure I follow you on the heat thing. What does engine heat have to do with axle gear temperature? I would venture to say that the electric motor gear oil will get hotter than the differential on an ICE because the case is also housing the motor, whereas on an ICE truck the differential is separate, and it catches a lot of airflow.
Robert1380
Robert
2025 Ford F-150 Lightning Platinum
Retired law enforcement
What’s involved and how difficult is it to service the motors yourself and change out the fluids?
21st Century Truck
Martin
I understand it's a question of access, above the bottom armor plate and to both the drain plug and to the fill plug up on the side.
As he said though it doesn't have the heat of the motor (or torque converter) to really tear up the fluid. It may get warm (I have seen 140f) but fluids handle pretty warm temps well, even significantly higher than that wont break down the fluid. In differentials they may be exposed to more airflow however they have a MUCH smaller fluid amount, the motors also have a MUCH MUCH larger surface area to shed heat. And just the amount of fluid itself will extend the service interval and with 100k on a differential being easy, having a much large fluid volume makes 160k seem more than reasonable.
Piquette
Trent
New Hampshire
2022 Lightning Lariat
I usually take my Lightning in every 5k miles to rotate the tires and have the service team check over the vehicle. After checking the truck over, the service technician makes a video showing me the critical areas that have been checked. While watching the video I spotted what looked like an oil filter attached to the rear electrical motor. I asked my service advisor what I was seeing, and he check with the technician who confirmed that it was an oil filter, but it wasn’t scheduled for replacement until 150k miles. To my eyes it looks like regular oil filter, just like the ones I have changed on my ICE Fords in years past.
Ford F-150 Lightning EV motor maintenance?  Gear fluid change?  When? IMG_2683
i
