Price per KW to charge at home🏠
DM_3
Donato
CA
2022 Lightning Lariat STD Range
teacher
I was wondering about people’s price to charge your lightning at home?
What is your lowest rate per kilowatt?
I pay 14¢ in British Columbia.
Central CA on a solar plan during winter $0.36 off peak when I’m below my baseline allowance and $0.46 when above my base line allowance. Either way, still saving versus pumping gas.
National Grid Mass. just installed smart meters on our house & garage two day ago, I really hope this technology evolves the state regulations allowing the utilities more latitude in offering TOU rates, if they do, I'd follow the recommended usage time frames.
Technically it is per kilowatt hour (energy= power x time) but...
I always charge overnight, Norther Virginia USA:
Summer from 1am to 5am .015 cents per kWh [bill 3 cents for 202 kWh at super-off-peak rate]
Winter from 1am to 5am 1.52 cents per kWh [bill $6.73 for 443 kWh at super-off-peak winter rate]
But that does not include things added to the bill like fuel costs, distribution costs etc. The fuel costs cost more than the energy charges!
Those add between about 12 to 14 cents per kWh to the cost depending on fuel costs, etc.
Also, the on-board charger wastes about 9% or so in inefficiencies (heat etc.) so not all the energy I pay for reached the battery.
I get anywhere from a low of 1.52mi/kWh in a cold winter weather month (Feb 2025) to a high of 3.2mi/kWh in a mild fall month (Sept 2025) according to my records averaging over a month's time but not including the energy wasted by the charger, only the energy that gets to the battery.
I guess my energy cost per mile driven is under 5 cents per mile, including the cost of the wasted energy charging.
NOTE: had to edit the cost per kWh based on most recent bills - the rate changed a bit from what I remembered. Also I am on a special plan the "EV + Home" pricing plan started back in 2014 or so.
NW Ontario Ford Lightning
Robert
NW Ontario Canada
Contractor
The people saying they pay $0.00 because they have solar systems should put a little bit of context into that claim. Solar systems aren't free. Usually the upfront cost is enormous.
Very True !!!
We built our solar in stages over a few years, buying when good deals were available, installation of the entire system by your's truely.
in US$ about $24k materials (PV, Inverters, Wire Disconnects, racking to support the PV and very large ESS battery built from cells).
The system just runs, and the grid is my back up - primarily for "winter" Nov-Dec-Jan. By February we get good solar again and PV panels work better in cold than heat.
Coming up on 60MW total produced, so you could say my solar energy is 40cents per kWh except it is not finished collecting energy, and every new kWh we collect is reducing the average cost per kWh with time.
If we assume 10 more years, then the cost will drop to about 10-cents per kWh on average. During those ten years utility costs are likely to contiinue to rise, but the cost of the system is a set value.
But WAIT - if utility cost is less than 10cents/kWh WHY do solar at all???
1. outages
2. winter
3. Well pump, freezers, heating system requires reliable electricity.
4. My business is also at my home (two birds one stone)
5. The business built the solar-Inverter-battery with 'before tax' dollars.
6. Utility costs are ToU - the low cost is only overnight, with far higher rates during the day - the Battery-Inverter system allows us to store the cheap rate power at night to use all day INSTEAD OF on-peak power rates.
7. independence - and I learned a lot.
In the end, although I call the solar "Free" . yeah, the truth is it cost money and will not last forever. Hope it lasts as long as I do though :unsure:
Karlos
Karl
DFW & Kerrville Tx
Retired CPA, active pilot
DFW area is running average of 0.15/kwh. We have solar & battery backup & try to charge the Mach-e during middle of sunny days to absorb the solar output as selling back to the grid is practically free.
At my ranch hangar near Kerrville on CTEC Co-op the rate is 0.115/kwh but solar panels on the Hangar and the way better Solar buy back CTEC does ( around 0.56/kwh ) makes filling the truck up the same rate 0.56/kwh opportunity cost.
VTHokies
Jason
‘26 Chevy Silverado EV Max Range
how much it was your original investment on the solar panels ?
it was probably somewhere around $18k after the federal tax credit... I was lucky and got grandfathered into a rate plan that offered 100% offset for what I sell back to the grid. So my sellback rate is exactly the same as what I get charged from pulling from the grid and there's no restrictions/limits on how much credits I earn.
Muerg
Spruce Creek, Pennsylvania
engineering manager
$0.22 / kWh 24/7. Pennelec (subsidiary of First Energy).
been climbing in cost last year or so but since getting the truck Oct 2023 the lowest was $0.19 / kWh.
Cvh8601
2023 Lightning Lariat
I’ll call out Pepco in MD for a ridiculous TOU plan:
no TOU: $0.25/kWh
TOU off-peak: $0.23/kWh
TOU peak: $0.335/kWh
Clearly a predatory money grab for those who buy EV’s but don’t look hard at the TOU rates.
flabrent
Brent
Florida Panhandle
'25 Ford Lightning Flash Job 2
By the time I add up "this, that, and the other things" it looks like I'm paying $0.151/kWh
zumahans
Hans
Malibu CA
2023 Lightning
RAdio Station Owner
Zero cents. We charge off the house solar panels. The truck is set to only charge after 10am, to reserve the first hours of sunshine to recharge the house battery. If it's been really cloudy, and the house batteries are low, I simply unplug the truck and let the diminished solar output charge the house battery first.
frautumn
Fred
Northern CA
2022 Ford F-150 Lightning Lariat
Grease Lightning
Johnathan
Albany, Oregon USA
2023 F-150 Lightning XLT
$0.135 off peak for Pacific Power here in the Willamette Valley of the good old state of Oregon. That includes all the annoying fees and such.
Our TOU discount sucks so really it is $0.16 or 0.17 prior to doing the TOU.
