Pro Power Onboard Relay Location?
jpatt2020
Jason
Canton Ohio
2024 F150 Lightning Flash
Hi All. Wondering where all of the relays are for the pro power 9.6kw system. The interior outlets seem to always default to "on", but I have to turn the bed and frunk outlets on through the touch screen. Are the relays in the box under the hood (I don't see them listed in the owner's manual)? Or in a special module somewhere?
I suspect (without proof) they are internal to the DC/AC inverter.
jpatt2020
Jason
Canton Ohio
Kind of what I'm guessing also. You would think they would be serviceable, though. Hopefully someone can answer! Maybe I'll listen for clicking later in the garage with someone inside turning them on/off.
Typically 'fuses' are on the Inverter, itself, and with the truck, the extended fuse locations in the bed simply tie back to those... but, all are made 'active' by the truck's software. CAB outlets are 'always on', but Frunk and Bed outlets have to be either turned Active via the center screen, thru ProPower, or at the outlets themselves... which also allows you to RESET them, the same way.
jpatt2020
Jason
Canton Ohio
Looking for the relays, not the fuses.
chriserx
Louisiana
I don't have one so I can't look, but if there are ethernet sized cables going into the inverter then it's almost certainly internal.
there are no 'relays' you are referring to...
jpatt2020
Jason
Canton Ohio
There has to be a relay or a transistor for each set of outlets. One for the frunk, one for the bed, one for the interior. How else would they switch on and off? Either different sections of the inverter are powered on and off via transistor/relay, or the inverter is always fully powered (what I would suspect), and the output is relayed to the different outlets as you turn the on/off from the infotainment screen.
I was looking at the wiring diagrams last night and all I saw was a fuse leading straight to the inverter. Which typically means any relay would be integral.
Got interrupted before I could finish looking, I'll dig into this evening some more to be certain.
This is what I would expect….the inverters are switched on/off by a comm signal. The “switch” is part of the inverter.
JMD359
One843657295470895!
22 F150 Lightning Lariat,2022 Toyota Rav4 Prime,2011 F350 6.2L
Mechanic
Most likely internal , putting a relay on the outside would be more expensive and harder to seal out the road salt and water mist these trucks get subjected too. Most manufacturers do not care about service ability anymore to prove my point just look at Stelantis and the IPM modules
jpatt2020
Jason
Canton Ohio
As far as I'm aware, there is none. The inverter output goes directly to the outlets. It is 2025. I would not expect there to be relays.
There have to be relays or transistors or the outlets couldn't be turned on and off remotely. It's just a question of where they are located. Inside the inverter, or elsewhere. Serviceable or not.
If the "AI Overview" is correct as others have suggested it seems the "relay" function is internal to the inverters that power the PPOB controlled by software, so no physical relays just an inverter on-off through the menu as I understand it.
Ford F-150 Lightning Pro Power Onboard Relay Location? PPOB control
---What AI says:---
The Pro Power Onboard (PPO) relays and control modules in the F-150 Lightning are integrated within the vehicle's high-voltage inverter system, with physical breakers/resets accessible in the cab and cargo bed, all managed by the truck's software. ..
You won't find them as simple, standalone relays in a traditional fuse box; they are part of the sophisticated power electronics, with breaker resets found on the outlets themselves (for 7.2kW/9.6kW) or via the center screen for all systems...
The "relay" function for tripping/resetting is handled by integrated components and software, with physical reset buttons at the outlets for the heavy-duty systems....
The Pro Power Onboard system in the Ford F-150 Lightning uses internal fuses and circuit breakers rather than typical, user-serviceable automotive relays for the high-voltage AC power.
fhteagle
D
'22 Lightning Lariat, '23 MYLR, '13 Forester, sold '13 Volt
There does not have to be the relay you are searching for on the AC side of the inverter. The inverter can just not have power to its DC input side via MOSFET (yes I know this is a form of transistor), which might not be accessible at all. Or, there could be a thyristor on the AC output of the inverter.
Reactions: chl
jpatt2020
Jason
Canton Ohio
Did you ever look into this any further? Where is the 9.6 inverter located? Under the bed? Thanks for the help!
