Slight Reduction In Acceleration. Has Anyone Else Experienced This Issue.
ClevelandBeemer
At the end of the day 1/4 mile is not a very good way to measure this effect. Not only is there the fact that most people dont have 1/4 mile times of their truck, traction will always be an issue, there is also the fact that 1/4 mile runs are easy to predict and if Ford was really trying to sneak in a stealth power cut could detect dead stop, no throttle to full throttle easily and sneak back the power.
What really needs to be done is to measure HVB current like the Mach-e guys did. Using OBD data we could see if maximum current during NOT-quarter mile runs is potentially higher on early, non-updated 22s and 23s than compared to 24s and 25s. This is a direct measurement of HOW ford would cut power.
A quick stab at the throttle earlier had current in my truck spiking at over 1200 amps but it was hardly a good test
Was someone advocating for 1/4 mile times to troubleshoot?
Timeless Epoch
Chad
2024 F150 Lightning Platinum
Professionally: Disaster Recovery - Recreationally: Watchmaker
You should be able to monitor the power going to the motors in CarScanner during a full throttle 30MPH jaunt. Should hit 433KW’s combined for the large batteries.
Not even close but to each their own.
Obviously they are not the exact same thing, no crap. Nobody is asking for anyone persons personal favorite. For the purpose of testing to determine if there is reduced performance they are practically the same.
As I said, using HVB current is a more accurate method as it is directly comparing the parameter Ford would manipulate to reduce performance.
How are you and 10 other testers going to bench mark a STAB at the throttle, for crying out loud!!!!
WOT is the only way to go, everyone's STOMP will be the same, pussy footing the pedal will result in non repeatable measures
....stab, to full throttle and then relatively quickly back off. Agreed, WOT is the only meaningful way to do this.
I did also say it was not a good test.
Did slightly better testing a short while ago.
. at low speed going full throttle peaked just under 1300amps.
. as speed increases maximum current tapers off. Full throttle at around 60mph gave around 1200 amps, and up around 80 mph full throttle was closer to 1100.
ClevelandBeemer
I mean you literally brought it up, but ok…..
Also HVB current is no more accurate than a 0-60 run. You’re at WOT for about 4 seconds getting meaningful data. Also HVB current is susceptible to TC pulling power to manage traction. So unless it’s is known what the HVB current should be at a given speed then I’d argue it’s just as difficult a metric unless it’s a drastic difference.
Either way both methods can obviously come to the same conclusion.
Woof...whatever, moving on.
HVB current is capped, it is the metric Ford limits in order to determine max performance.
Point being that 0-60 or 1/4 mile time will be suspect able to a bunch of factors. HVB current will have a set maximum. We dont have to determine a variable metric over time, we just have to record a single instance maximum value. We also can record that value over a wide variety of conditions (start speed, throttle opening rate, even traction to an extent, won't change the results).
Again, the maximum allowed current will be the thing Ford limits to restrict performance if they are doing so.
So no, it is actually far more accurate than 0-60 or 1/4 mile time, you only have to record the peak maximum and it is directly measuring the very thing we are trying to determine.
ClevelandBeemer
Woof indeed.
Of course the HVB current has a predefined max, that’s why we don’t have 2,000hp trucks.
However you still need to hit conditions where the truck will ask for the max, then you need to know what the max should actually be. To make this more interesting, the max will vary between the SR, ER, and newer 123kWh battery.
So I’m genuinely curious, are there published maximum for each pack?
Woof indeed.
Yes, the nax is the point, because again, lowering the max is how performance would be reduced.
If you cant hit the max you cant get 0-60 or 1/4 mile times either. Except in those you have to hit the max the WHOLE time, simply measuring current you only have to hit it at some point.
Literally was out tonight in cold snow with wet roads. There was no way to get a run time in but I was able to see maximum current at some point.
ClevelandBeemer
Totally agree. However the 0-60 times are published by Ford, so there is an actual benchmark. Is maximum current limit published for each pack?
Ford uses a rollout as you said, anyone doing this will be using a phone app or at best a race box. Plus as each truck has different weights, in some places SIGNIFICANTLY different weights, the published times and the times a person's specific truck could achieve can be highly variable.
As for max current all we need is to see peak values that are higher or lower than other trucks.
ClevelandBeemer
Indeed, there are many variables. Yet on dry and clean asphalt in temps above 50F should be within a tenth or two with a single occupant in the truck. Again, ford has published the times for each truck model accounting for the different weights and wheel and tire options. Furthermore Car and Driver, MoterTrend, and others have published their data.
Conversely using community HVB peak current targets can be useful if there are actually published targets to hit. So tell me, what should 2024 SR and ER owner see for peak current? Is 433kW good? How about 455kW? Perhaps 473kW?
.. those are not currents...
I just explained how it can work. I get you don't want to accept that, and are trying to push your narative about using published numbers, but I said what I did for a reason.
BTW, I have not seen individual 0-60 numbers for each trim, battery, and wheel combination as you said. Could you provide the link for that.
