I’ve been working on getting better data visibility for my F-150 Lightning. While FORScan and Car Scanner are the gold standards for seeing what’s going on, they are not always the most convenient tool for long-term logging or custom dashboards. I wanted to move that high-level data into Torque, but that requires knowing the exact hex PIDs and the specific math formulas Ford uses—and the current PID list is inadequate.
To solve this, I used Google Gemini Pro as a data science partner. By feeding the AI raw Bluetooth packet logs and comparing them to live app data, I was able to bridge the gap. We aren't "finding" PIDs that didn't exist—FORScan already sees them—but we are deconstructing them so they can be used in other applications.
The Breakthrough: AI-Enabled Correlation
Typically, matching raw hex values to real-world sensor data requires significant experience in signal processing or software engineering. You have to account for clock drift, filter out thousands of background messages, and solve for linear equations (Scale/Offset) manually.
By using Gemini , I was able to upload the raw .pcapng packet logs and the CSV logs from the diagnostic apps directly. The AI performed the time-syncing and regression analysis automatically. You still have to validate the results, in one instance it switched brake pedal travel and LF brake pressure, but to be honest it also identified that the brake pedal travel PID had unusually high precision. This mistake is not surprising, brake pedal travel and pressure exactly matched (truck was parked) so the plots looked near the same.
Ford F-150 Lightning Deconstructing the Lightning: Using AI to Map PIDs for Torque Screenshot 2026-01-30 221054
Note: While I used a paid Gemini account for the massive context window needed for long logs, you can do this with the free version by feeding it smaller snippets of data.
How to Do It Yourself (Instructional Guide)
If you want to help expand our community PID list, here is the pathway to capture the data.
Ford F-150 Lightning Deconstructing the Lightning: Using AI to Map PIDs for Torque Screenshot 2026-01-30 210342
1. The Sniffer Setup (Windows)
Standard Wireshark on Windows can’t see Bluetooth traffic without help. You need the Microsoft Bluetooth Virtual Sniffer (BTVS).
  • Download: Get the "Bluetooth Test Platform" from Microsoft.
  • The Shortcut: Navigate to the folder containing btvs.exe. Click into the Address Bar of your File Explorer, type cmd, and hit Enter.
  • Launch: In the command window, type btvs.exe -Mode Wireshark. This will open Wireshark and start piping your Bluetooth traffic into it.
2. The Capture Session
  • Laptop Method: Run FORScan and select 5–10 PIDs you want to map. Start your Wireshark capture and perform a specific action (e.g., sweep the steering wheel or plug in a charger).
  • Android Method: Enable "Bluetooth HCI Snoop Log" in Developer Options. Run CarScanner or similar, do your test, and then pull the log via a Bug Report.
Ford F-150 Lightning Deconstructing the Lightning: Using AI to Map PIDs for Torque Screenshot 2026-01-30 221027
3. The Analysis
Once you have your logs, you can use an AI like Gemini to do the math. Tell it: "I have a Bluetooth log (hex) and a sensor log (decimal). Match the timestamps and find the hex PID and the formula for [Sensor Name]."
Ford F-150 Lightning Deconstructing the Lightning: Using AI to Map PIDs for Torque Screenshot 2026-01-30 221105
What We’ve Mapped So Far
Through this process, I’ve already moved several high-fidelity sensors over to Torque:
SensorPIDEquationHeader
High-Res SOC224801(A*256+B)/5007E4
Brake Pressure (LF)222B28(A*256+B)/6.89760
Charging Power (W)22484E(A*256+B)*57E4
Energy to Empty (kWh)224848(A*256+B)/5007E4
Call to Action: Let's Build the List
This is just the start. There are hundreds of PIDs available in the different modules. Tons for the IPC, IPMA, APIM, etc. If you have a favorite sensor or trigger in FORScan that you wish you had in Torque, use the pathway above to capture a log (or give me a shout).
Post your logs or your findings here, and let’s see how large of a "community dictionary" we can build for the Lightning.
Copy into text editor and save as CSV. These need to be validated.
Name,ShortName,ModeAndPID,Equation,Min Value,Max Value,Units,Header,Description
AC Status,AC_STAT,229938,A,0,1,state,733,HVAC: Compressor Status
Blower Speed,BLW_SPD,22995A,A,0,100,%,733,HVAC: Blower Speed (100 is OFF)
Heated Seat Drvr,H_SEAT_L,229801,A,0,3,state,733,HVAC: 0=Off 1=Low 2=Med 3=High
Left Blend Door,L_BLEND,229B02,A,0,100,%,733,HVAC: Left Actuator Pos
Right Blend Door,R_BLEND,229B03,A,0,100,%,733,HVAC: Right Actuator Pos
Evap Temp,EVAP_T,224057,A-15,0,100,°F,733,HVAC: Evaporator Temp
Recirc Door Pos,RECIRC,229B00,A/2.55,0,100,%,733,HVAC: Recirculation Door Position
Cabin Heater Status,HTR_CAB,224836,A,0,255,raw,733,HVAC: Heater Core Status
L DRL Status,L_DRL,2240E7,A,1,2,state,7C4,LDCMA: 1=OFF 2=ON
L High Beam,L_HIBEAM,2242BE,A,1,2,state,7C4,LDCMA: High Beam Status
L Turn Signal,L_TURN,224255,A,1,2,state,7C4,LDCMA: Turn Signal Status
L Low Beam,L_LOBEAM,2242A0,A,1,2,state,7C4,LDCMA: Low Beam Status
L Static Bending,L_SBL,224266,A,1,2,state,7C4,LDCMA: Static Bending Status
High Beam Status,HIBEAM,2242A0,A,1,2,state,7C4,LDCMA: High Beam Output
Tire Press LF,TP_LF,222813,(A*256+B)/20,0,60,psi,726,BCM: Left Front Pressure
Tire Press RF,TP_RF,222814,(A*256+B)/20,0,60,psi,726,BCM: Right Front Pressure
Tire Press LR,TP_LR,222816,(A*256+B)/20,0,60,psi,726,BCM: Left Rear Pressure
Tire Press RR,TP_RR,222815,(A*256+B)/20,0,60,psi,726,BCM: Right Rear Pressure
Tire Temp L,TPM_L_T,22280B,(G*1.8)-40,-40,200,°F,726,BCM: Tire Temperature
Stop Lamp CHMSL,CHMSL,2240F5,A,1,2,state,726,BCM: Center Brake Lamp
Brake Pedal Travel,BRK_TRAV,222823,(A*256+B)/2540,0,5,in,760,ABS: Brake Pedal Position
Brake Pressure LF,BRK_PRES,222B28,(A*256+B)*0.145,0,2000,psi,760,ABS: LF Brake Pressure
Lateral G Force,LAT_G,222B0C,(SIGNED(A*256+B))*0.004,-2,2,G,760,ABS: Lateral Acceleration
Parking Brake Sw,PK_BRK,222B00,A,0,255,state,760,ABS: Parking Brake Status
Steering Angle,STR_ANG,223302,((A*256+B)-7800)/10,-900,900,°,760,ABS: Steering Wheel Angle
Steering Current,STR_CUR,22330C,A*0.2,0,100,A,730,PSCM: Steering Motor Current
Steering Torque 1,STR_TQ1,22EE05,(SIGNED(A*256+B))*0.737,-500,500,ft-lb,7E4,PSCM: Steering Torque 1
Steering Torque 2,STR_TQ2,22EE07,(SIGNED(A*256+B))*0.737,-500,500,ft-lb,7E4,PSCM: Steering Torque 2
Accelerator Pedal,APP,22F449,A*100/255,0,100,%,7E0,PCM: Accelerator Position
Baro Pressure,BARO,22F433,A*0.145,0,20,psi,7E0,PCM: Barometric Pressure
Coolant Temp,ECT,22F405,(A-40)*1.8+32,-40,250,°F,7E0,PCM: Engine Coolant Temp
Vehicle Speed,VSS_MPH,22F40D,A*0.621,0,120,mph,7D0,Vehicle Speed (mph)
Battery Temp High,BATT_T_H,224800,(A-50)*1.8+32,0,150,°F,7E4,BECM: Max Battery Temp
Battery Temp Avg,BATT_T_AVG,22FD70,(B-51)*1.8+32,0,150,°F,7E4,BECM: Avg Battery Temp
Battery Current L,BATT_CUR,22480A,(A*256+B)/336,-100,100,A,7E4,BECM: Low Range Current
Battery Energy Est,BATT_kWh,224848,(A*256+B)*0.002,0,150,kWh,7E4,BECM: Energy Estimate
SOC Actual,SOC_ACT,22F45B,A*100/255,0,100,%,7E4,BECM: Raw SOC
SOC Displayed,SOC_D,224845,A*0.5,0,100,%,7E4,BECM: Dashboard SOC
Charging Power,CHG_PWR,22484E,(A*256+B)*5,0,150000,W,7E4,BECM: Charging Wattage
Charge Status,CHG_STAT,22484D,A,0,5,state,7E4,BECM: Charge Status Flags
Coolant Inlet Temp,COOL_IN,224846,(A-50)*1.8+32,0,150,°F,7E4,BECM: Cooling Loop Inlet
Coolant Temp 2,ECT2,22483A,(A-40)*1.8+32,0,150,°F,7E4,BECM: Secondary Coolant Temp
Conv High Current,CONV_HI,220582,(A*256+B)*0.05,0,500,A,7E4,BECM: DC/DC High Current
Conv Low Current,CONV_LO,22D118,(A*256+B)*0.01,0,100,A,7E4,BECM: DC/DC Low Current
L Headlamp Swivel,L_SWIV,227102,(A*256+B)/6.4,0,360,deg,734,HCM: Left Swivel Angle
R Headlamp Swivel,R_SWIV,227104,(A*256+B)/6.4,0,360,deg,734,HCM: Right Swivel Angle
ECU Delta Temp,ECU_DT,22DD81,A-18,0,100,°F,7E4,BECM: ECU Temp Delta
Cell Voltage Var,CELL_VAR,22483F,(A*256+B)/400,0,1,V,7E4,BECM: Cell Variation
Current Range HG,CUR_HG,22FD39,A,0,255,range,7E4,BECM: Current Range High
Current Range LW,CUR_LW,22FD38,A,0,255,range,7E4,BECM: Current Range Low
BECM Info 02,BECM_I02,22F800,A,0,255,flags,7E4,BECM: Info Flags
Power Remaining,BATT_REM,224801,(A*256+B)/500,0,100,%,7E4,BECM: Remaining Capacity %
Motor Torque Pri,MTR_TQ1,22481C,((SIGNED(A*256+B))*0.1),-1000,1000,Nm,7E6,Inverter: Primary Motor Torque
Motor Torque Sec,MTR_TQ2,224822,((SIGNED(A*256+B))*0.1),-1000,1000,Nm,7E7,Inverter: Secondary Motor Torque
Motor Speed Pri,MTR_SPD1,221E2C,(SIGNED(A*256+B)),-6000,12000,RPM,7E6,Inverter: Primary Motor Speed
Motor Speed Sec,MTR_SPD2,224821,(SIGNED(A*256+B)),-6000,12000,RPM,7E7,Inverter: Secondary Motor Speed
Motor Inv Temp Pri,INV_T1,22481D,((SIGNED(A*256+B))*1.8+32),-40,300,°F,7E6,Inverter: Primary Temp
Motor Inv Temp Sec,INV_T2,22481E,((SIGNED(A*256+B))*1.8+32),-40,300,°F,7E7,Inverter: Secondary Temp
Charger AC Volt,CHG_AC_V,22485E,(A*256+B)*0.01,0,300,V,7E2,Charger: AC Input Voltage
Charger AC Curr,CHG_AC_I,22485F,A,0,100,A,7E2,Charger: AC Input Current
Charger AC Freq,CHG_AC_F,224860,A*0.5,30,90,Hz,7E2,Charger: AC Frequency
Charger DC Coup T,CHG_DC_T,22D00C,(A-40)*1.8+32,-40,400,°F,7E2,Charger: DC Coupler Temp
Ford F-150 Lightning Deconstructing the Lightning: Using AI to Map PIDs for Torque Screenshot 2026-01-30 210403
digitaldad
ABQ
'23 Lariat ER MaxTow
Pretty cool. I know you've posted other threads/comments about Torque...but for those of us not aware (like me):
By quick search, I see this is on Andoid & iOS (assume an alternative to CarScanner).
Does Torque (or Torque Pro) have fullscreen on CarPlay and Andoid Auto?
Are you planning custom dashboards for the app?
Any of this play into Home Assistant?
Sorry for the sidetrack, but I think there may be a wider audience if more details are known.
Thanks
chriserx
Louisiana
3. The Analysis
Torque values extracted (copy to torque csv).
Battery SOC (High Res),SOC HR,224801,(A*256+B)/500,0,100,%,7E4
HV Battery Current,Amps,22480A,(SIGNED(A*256+B))/100,-500,500,A,7E4
Charging Power,Chg Watts,22484E,(A*256+B)*5,0,20000,W,7E4
Battery Energy to Empty,kWh Rem,224848,(A*256+B)/500,0,150,kWh,7E4
Accelerator Pedal Position,Throttle,22F449,A/2.55,0,100,%,7E4
Steering Wheel Angle,Steer Ang,223302,((A*256+B)-7810)/10,-900,900,°,760
Brake Pressure LF,Brk Press,222B28,(A*256+B)/6.89,0,2000,psi,760
Brake Pedal Position,Brk Pedal,222823,(A*256+B)/2500,0,2,in,760
Lateral Acceleration,Lat G,222B0C,SIGNED(A*256+B)/100,-2,2,G,760
Battery Coolant Inlet Temp,Clnt In T,224846,(A-50)*1.8+32,-40,150,°F,7E4
Ford F-150 Lightning Deconstructing the Lightning: Using AI to Map PIDs for Torque 1769842851836-9y
mr.Magoo
2022 Lariat ER, AMB
Timeless Epoch
Chad
2024 F150 Lightning Platinum
Professionally: Disaster Recovery - Recreationally: Watchmaker
Sir, if you could use your AI correlation engine and packet capturing prowess to find and capture the CAN message sent to kick off charging pre-conditioning, you could very well be the hero of the internet for a few days.
srspring551
Scott
WI
F150 Lightning Lariat 2023 ER, delivered 10-28-23
Thanks
I see several "Torque" apps on IOS, is this the one from Collabrains Tech or Fantastic Software inc?
Jseis
Washington
While not in my skill set, fab presentation & discussion!
Watching & impressed with what several of your tech geeks can do, carry on!!!!
NW Ontario Ford Lightning
Robert
NW Ontario Canada
Contractor
I've been integrating my solar assistant into Home Assistant last few weeks, and building out automations for the property. I hear that HA can grab data from our Ford App - I hope to integrate the charging required into my overall energy management system.
Like the OP, I was able to harness AI to assist, where my own IT knowledge was too thin.
It is quite amazing what is possible now, that was unheard of just 5-6 years ago.
galstaf
North Georgia
2015 LEAF x 2, 2022 F150 Lightning Lariat ER (511A trim)
community offgrid training
Has anyone used a mechanism like this to find out how to turn on battery preconditioning manually?
There are some janky workarounds that involve tricking the truck into thinking it is going to a DC fast charger, but I want to just be able to hit a button and have it warm the battery up on the way to work where I can then charge it with an AC EVSE without having to wait for almost 2 hours for the EVSE to warm the battery up.
If Ford won't give us this very basic and useful option, perhaps we can feed the CAN bus instructions manually like the way a Comma self driving device activates steering and braking with it's CAN bus commands.
Does anyone know how the battery conditioning is implemented in the truck? A single CAN bus command? An on off switch?
Seems like something a lot of us would like especially during this cold snap!
mr.Magoo
2022 Lariat ER, AMB
I don't want this to turn into a "to precondition or not to precondition, that is the question" thread (we have a LOT of them already), but preconditioning for shorter trips is kind of a waste of energy and it'll only take 30min (not 2hrs) for it to warm up the battery enough to begin charging (unless you're in the 0F part of the world).
The one thing I wish they had is a departure time that didn't pre-condition, but managed the charging window to match your departure. The truck knows the capability of your charger/evse, so let's say you need to charge 80kWh and your EVSE is capable of 9kW, then just start the charge 9-10 hours prior to departure, no energy wasted heating things up and letting it cool, only to heat it back up again.
chriserx
Louisiana
This, but additionally I'd like to see more intelligent charging like on modern phones. Study usage patterns and have optimal juice for the drive, instead of plugging in and immediately charging, delay it so A) no wasted battery heating and B) the battery doesn't sit at a high SOC longer than necessary.
The truck knows the capability of your charger/evse, so let's say you need to charge 80 kWh and your EVSE is capable of 9kW, then just start the charge 9-10 hours prior to departure, no energy wasted heating things up and letting it cool, only to heat it back up again.
I charged everyday last week, timed to be within an hour of leave times, the trucks thermal management system still decided it needed to spend energy on warming the battery every charging session, my net efficiency plummeted, normally it's around 92% energy consumed goes into the HVB, while this very cold week had the value drop to 50-60%, and this was not using any departure times.
So intentionally eliminating the warming phase might lower battery health & longevity over the long term.
Ford F-150 Lightning Deconstructing the Lightning: Using AI to Map PIDs for Torque 1770127850709-vh
This week I'm not charging daily, and expect to use ~40% SOC for my week day trips, I will recharge Saturday the 7th to 100% and include intentional departure warming on the HVB for another NH trip.
I expect the savings of lost energy to be worth the change especially at my high utility rates.
