DreamBrother1
Midwest
2023 F150 Lightning Pro, Subaru Ascent
Seems like people are having good success with the H4 AGM upgrades. Anyone put an Interstate MTX-H4 in their truck, or know if it would work?
jwrezz
1996 Ford ExplorerXLT, 2006 Subaru OBS LLBean, 2024 Ford F150 Lightning Lariat
Teacher/Firefighter
It would work, 100%. Mine is not the interstate as seen by my pics, but if it's an H4, with the tray modifications, any brand will fit/work.
Blochead21
PA
Black 22 XLT 311pkg
I just did this with a Walmart Everstart H4 AGM. Rockauto was 180 with shipping for an H3 AGM, and Costco didn’t stock and couldn’t order any Interstate H3 AGMs or H4 AGMs. However it’s a simple upgrade with just an oscillating tool, and for $189 at Walmart with a 4 year warranty it’s hard to beat.
Blochead21
PA
Black 22 XLT 311pkg
Both show the local store to get or order from on my screen.
Interstate H3
Interstate H4
You're better off sticking with the Walmart battery (Johnson Controls) same maker of Motorcraft and many others. Walmart at least you know you can find one open at just about any hour of day or night in practically every suburb and city. Comes in handy at 5am when you're off to work and your truck won't start. Don't ask me how I know :angel:
You have to go through Costco directly they have the link online with different stock. My local costcos didn’t stock anything lower than an H6 and wouldn’t order it for me. They told me to go through the site, but the site wouldn’t allow me to order it anyway. Which is half the reason I went with an H4 to be able to find future batteries easier.
https://www.costco.com/automotive-batteries.html
Where do you find this information?
Where can YOU find it you mean?
Any reliable battery manufacturer or tech battery course material about how lead-acid battery chemistry works.
I guess I first learned a lot of this information around the winter of 1979 in one of my first engineering courses in college - lead acid batteries haven't changed all that much, they work the same as forever.
"Lead-acid batteries were invented in 1859 by French physicist Gaston Planté. It was the first rechargeable battery (secondary cell) ever created, featuring two lead plates immersed in sulfuric acid. Later improved in 1880 by Camille Alphonse Faure, this technology remains widely used today in automobiles and UPS systems."
The Baghdad battery used an acid and two different metals, a copper cylinder and an iron rod, to produce the movement of electrons maybe 250 or more BCE, so they tell me, maybe the first wet cell battery!
I think if you searched on line for something like..."What causes lead acid batteries to stop working" you likely find the answer is most often, "sulfation due to leaving them in a discharged state." The other answer would likely be "heat or overcharging causing a loss of electrolyte."
It is kind of common knowledge among EE's I suppose.
mr.Magoo
2022 Lariat ER, AMB
It's been a month since I made that statement and it was not about battery design or chemistry in general, it was related to your statement that going below 90% for four days was bad.
While "below 90%" technically could be anything between 89.9999 and 0%, I doubt that 85% for four days is a big deal, so the statement seemed rather sweeping / generalizing and I simply wondered, where you get that information from, because not many sources talk about as low DoD as 10%
You're basically saying that any battery older than a year is "damaged" since their internal discharge rate would have brought them below 90% and at that point 4 days is nothing.
I see...I should clarify that it is cumulative.
I meant to imply that, but should have said it explicitly.
Sitting at 85% over and over definitely is not going to be good for the battery.
In essence, to fully drive off the sulfates that form during the discharge process, the battery has to be charged back up to 100%.
One time is not going to kill the battery of course.
Doing that week after week will take it's toll, as all the battery failures in Lightnings lately are proving I believe.
Overcharging can also be a problem with AGM batteries especially - distilled water can be added to a flooded battery easily.
Myth: The worst thing you can do is overcharge a lead acid battery.
Fact: The worst thing you can do is under-charge a lead acid battery. Regularly under-charging a battery will result in sulfation with permanent loss of capacity and plate corrosion rates upwards of 25x normal. Overcharging a battery breaks down any sulfation, but can cause plate corrosion rates to increase up to 3x normal. With flooded/wet batteries you can always add water. One concern is overcharging AGM batteries, which already have very little water reserve, and so there is risk of dry-out. However, most chargers sold today are “smart” chargers and will shut off after the battery is fully charged.
https://www.advancedbattery.ca/8-myths-and-facts-about-lead-acid-batteries/
I hope that clarifies things, sorry I was not clearer about the cumulative effect. :)
jwrezz
Teacher/Firefighter
Damned if you do damned if you don't! Good things we have DC/DC converters that will keep our batteries perfect for ever! Not!!!
  • Haha
Reactions: chl
Alas.
Like the Greeks (or somebody back then said) "all things in moderation."
Not too hot and not too cold, the Goldilocks principle of battery maintenance.
It is written that modern smart battery maintainers are the ticket to near eternal battery life.
The Zen of Lightning maintenance, if you will.
jwrezz
Teacher/Firefighter
Alas.
NOCO to the rescue!
Reactions: chl
@Adventureboy I've started getting occasional "system off to preserve power" messages so I know it's time to finally swap out my 12v. I assume no news is good news here but I wanted to ask you (or anyone else who put in an H4) if you have any regrets so far? I think I'm going to go this route in the very near future.
jwrezz
Teacher/Firefighter
No regrets except I wish I went larger than H4!
jwrezz
Teacher/Firefighter
I mean with the winch I just purchased and if I ever decide to get a light duty plow that is powered, I'd need it.
Adventureboy
Adventureboy
Zero regrets. I monitor it daily and the truck charges it fully. No more messages so far.
mr.Magoo
2022 Lariat ER, AMB
It's a good thing he used one of them extra strong H-V-A-C zipties, because I sure wouldn't have trusted a standard one.
Bit too much jerryrig for my taste.
