Can I make it? Advice needed/appreciated.
lex-man
Alex
Upstate New York, Sarasota Florida
Ford Lighning Lariat
After first drive question/advice needed:
Ok so I just finished my first long trip. Charged a couple times and after a little trial and error, I think I've got the charging down. *BUT I got home with 18% (42 mile) charge state- I haven't installed my home charger yet. Closest DC charger is 21 miles away. How risky is it to trust the GOM and drive there to charge? (very possible I am over thinking this) Thanks for any advice, I'm just starting to figure it out. That said, loving this F'n Truck!!
CTLightning
CT
2022 F150 Lightning Lariat
computer tech/ woodworker
Yeah, better safe than sorry… maybe people getting overnight and get those few extra miles in there.
K6CCC
Glendora, Calif.
As Lightning Rod said, it's a little chancy. Personally as a brand new EV owner, range anxiety is gonna be higher so your gut is likely telling you not to chance it. With that said, especially if your closest DC charger can be reached via city driving as opposed to fast freeway, your range will be better, and therefore your chances would be far better. However as he suggested, plug your mobile charge cord into 120 volts overnight and will add plenty of range to get there - and most likely far less expensive than DCFC.
If you can wait and have a mobile EVSE, I'm in the charge overnight on level 1 crowd. If you don't have anything to charge with, then you can make it. Just keep the speed down to give you the extra buffer.
An OBD reader will tell you your usable energy remaining. Using that and your current efficiency will be a pretty accurate estimate for your range.
21 miles, worse case, at 1.5 miles per kWh, is 14kWh. 11%. You have 18%. And, worse case, drive slower.
NON-ISSUE.
I would not hesitate to drive this. Don't overthink it. GO.
Doing this on a trip, when you could run out and wait hours for a free tow to the next charger, is what driving an. Ev is all about. At home, non-issue.
Rayden
'23 Lightning Lariat ER
I wouldn’t worry in a standard range truck to make that trip as long as you don’t take it over 70 mph.
However, I would check PlugShare to make sure that the charger was functioning and reliable.
That is a good point! With his mileage so low and this is the only charger in range, I'd check just to make sure that the charger is functioning.
The Weatherman
Dean
South Central KY
The only problem I see with just going for it is the Lightning has reputation of dumping the GOM at or near 10% state of charge. A little extra buffer would be advisable.
Now if you are one those folks who loves to drive with gas warning light on, go for it!
davehu
hot springs, AR
we are all assuming that the OP has an extended range battery. If so he's probably ok.
flyct
Jerry
South Florida
Blissfully Retired
are you upstate NY or Sarasota. Now
