AlaskaFlash
James
Juneau, Alaska
2024 F150 Lightning Flash
My 12 Volt battery went bad, bulging sides, Only 2 years old. Replaced with a new Motorcraft AGM H3 under warranty. This battery went bad after two weeks with bulging sides. Battery saver notices showing up on Ford Pass. I replaced it myself with a H4 AMG battery that says it's electric & Hybrid compatible. I also reset the BMS by using the 5 bright headlight switch followed by 3 brake pedal trick. It seemed to reset the BMS. I had to cut off the spacers in the tray so the larger battery would fit. I've attached photos.
Ford F-150 Lightning 12V Battery replacement with H4 IMG_0848
Ford F-150 Lightning 12V Battery replacement with H4 IMG_0851
Ford F-150 Lightning 12V Battery replacement with H4 IMG_0847
Ford F-150 Lightning 12V Battery replacement with H4 IMG_0852
Ford F-150 Lightning 12V Battery replacement with H4 IMG_0853
Zed
Chuck
2022 Lightning Platinum Rapid Red
For those of you who have installed the H4 battery in your Lightning: how is it working out? I know there's been a lot of discussion here about if/how well the BMS can deal with the extra capacity of the H4. I was considering doing the swap but decided to hold off and let the intrepid folks here blaze that trail.
I'm probably not the only one wondering about his, so please respond with your experience and any thoughts about it.
Thanks!!
Adventureboy
Adventureboy
I'm probably not the only one wondering about his, so please respond with your experience and any thought about it.
Thanks!!
BMS handles it no problem. I did mine in early March and no issues. 12v related messages have disappeared (although it is still summer).
The Weatherman
Dean
South Central KY
Martin Meeks and Zach Carpenter have a retrofit tray for this, if anyone is interested.
I personally think it’s a little pricey, but others may not.
Lyle
Lyle
Hawaii
2023 Ford F-150 Lightning Platinum ER
Yeah I think it comes out in September. I’m waiting for Martin’s to get back to me on shipping costs because I’m in Hawaii and he said free shipping was to 48 only. I think the kit also comes with the battery negative terminal extension cable as well. Certainly pricey but it’s supposed to allow drop in replacement without having to remove the tub.
Blochead21
PA
Black 22 XLT 311pkg
Thanks!!
No issues here either. Glad I did the upgrade. Should also make a swap in the future easier with more choices while out on the road.
VAL.ABAPO
2025 F150 FLASH LIGHTNING 131kwh ER
I was thinking of using an H4 as well until i heard and seen Martin Meeks method.
im all for no mods on the battery tray.
Rayden
'23 Lightning Lariat ER
This looks interesting. I watched the video on YT and didn't see any links to his store. I see that he has a few things he's made over time. Where is he selling his stuff? Google makes it look like there's just YT, FB, and maybe Instagram. :unsure:
The Weatherman
Dean
South Central KY
He hasn’t said just yet, but your best bet to reach him is on FB. I think he post there more than YouTube.
His partner is here as @ZSC100 you might DM him.
Lyle
Lyle
Hawaii
I couldn’t wait anymore, I looked around for a battery locally and here’s what I found. One Costco near me had a flooded lead-acid H4 for about $142. The local Ford dealership has the puny H3 for $250. Autozone had an AGM H4 for $250. Sam’s Club had an AGM H4 for $199 so I decided to get that. I would have preferred to have a Group 65 which Costco had for $179, but I couldn’t wait another month and started thinking that $159 plus shipping would almost get me another battery.
Cutting the battery tray was super easy with my OMT. I also bought a Noco Genius 2D. What’s interesting is that while I was connecting the negative terminal to the Noco (positive terminal connected first), it sparked many times. I watched a review of these kinds of trickle chargers via Project Farm and only the crappy ones sparked. So I was very surprised (shocked) to see it spark. I did not have the AC side plugged in.
Ford F-150 Lightning 12V Battery replacement with H4 IMG_1284
Ford F-150 Lightning 12V Battery replacement with H4 IMG_1285
Ford F-150 Lightning 12V Battery replacement with H4 IMG_1286
Ford F-150 Lightning 12V Battery replacement with H4 IMG_1287
Lyle
Lyle
Hawaii
Another update to this. After I installed my H4, Car Scanner reported the 12V SOC to be 57%. I thought this was quite low. The battery had a 8/26 sticker on it so I figured it was the freshest battery they had if this type. Since I needed to charge the truck anyways, I decided to just charge it instead of using the Noco. After charging for a couple of hours, the battery got into the mid 80’s SOC. The next day I drove for a bit less than 2 hours, spread across a couple of trips. After charging that night I got to 100% and did the BMS reset. Strangely, Car Scanner then reported only 80% SOC. I thought this was weird but probably because the increased capacity.
Lyle
Lyle
Hawaii
OMG it’s getting worse. I drove the truck 10 miles today and parked and turned it off. I came outside to eat lunch and I wanted to turn on the climate control to cool it off before I sat in it to eat lunch. I couldn’t connect to the truck, the app said it was in battery saver mode. I ate lunch in the truck with it turned on. Car Scanner said the battery was at 65% SOC. After eating lunch it was at like 82%. After driving for 30 minutes at the end of the day it was at 92% SOC when I got home. Even with my 3 year old failing battery I never had the app tell me the truck was in battery saver mode. Did I just get a bum H4 battery? It shows over 14V.
Mikerson
ID
2024 Mustang Mach-E GT, 2023 Lightning Lariat, 2001 E-250 Sportsmobile 4x4
Maybe disconnect that NOCO? A spark when connecting it (unplugged) could indicate a short circuit somewhere in that little charger which may be running down your battery.
Your maintainer is wired to the wrong side of the BMS sensor. The BMS has no idea that you are charging it.
Even if wired correctly, the BMS is still going to base its data thinking you have an H3.
Mikerson
ID
I’ll assume you meant to quote @Lyle, but I think his installation looks good and agrees with previously mentioned instructions.
https://www.f150lightningforum.com/forum/threads/charging-12v-battery.16979/post-342220
Lyle, I believe you should have charged the battery to 100% on the bench and then reset the BMS upon install. That doesn’t explain the drain you seem to be experiencing, but the battery will not get to 100% because the BMS charges based on coulomb counting (energy counting), not voltage.
In the factory configuration it’s as if you have a 12 oz beer and a 12 oz glass. You pour your can in, take a swig and the BMS refills exactly one swig. Now you switched to a pint glass, started with it half full, told the BMS it was full, and when you take a swig the BMS puts exactly one swig back in. Battery always at 50% but BMS thinks it’s full because it put in what you took out.
