DevonD
you see more than this? I didn’t think you’d get more without activating the vehicle.Just the standard FordPass app on Android or iOS
Only 3 months trial, I will skip.Just the standard FordPass app on Android or iOS
Can't find the answer to this, so what's a tear tag and modules popped?No tear tag for me yet but it’s the weekend and I know it can take a couple of days anyway. The date (8/5) was added under my “in production” status on ford’s tracker.
Your trucks electronic systems are installed and programmed, the tear tag indicates the process is complete and the file archived with Motorcraft.Can't find the answer to this, so what's a tear tag and modules popped?
How can I tell if this has happened?Your trucks electronic systems are installed and programmed, the tear tag indicates the process is complete and the file archived with Motorcraft.
Essentially the principal build is done on the main assembly line
Your built status may take a couple weeks for additions ex. spray in liner, etc. and the truck to passes QC.
Check the stickies in this subforum for “track your build” threads. They explain it in detail. You will need your dealers 4 digit order number and your trucks VIN.How can I tell if this has happened?
Index - FordServiceInfo.ComHow can I tell if this has happened?
Don't confuse the date of the email with when your build week is, most likely you are still in the 8/15 week with a build day of 8/17.My original build date was set for week of 8/15/22 and a Blend date of 8/17. However, on 8/3 I got an email from Ford saying my Lariat is in production and they gave me my VIN and a link to my window sticker. Today the sticker still shows Blend date 8/17, so I’m not really sure what’s going on.
Built Week 7/18. Blend 7/22 with In Production 7/24. I was given a target of 8/5 - 8/11. I called today and that shifted to 8/26-9/3. That ETA is definitely not accurate and will shift.Has anybody else chatted with Ford? Are they ever accurate? I did again today for clarification and they told me the order should arrive between 8/13 and 8/19.
Has this quick of a turn around been seen yet with a Lightning?
That makes sense. Thank youBuilt Week 7/18. Blend 7/22 with In Production 7/24. I was given a target of 8/5 - 8/11. I called today and that shifted to 8/26-9/3. That ETA is definitely not accurate and will shift.
