Android auto without wireless?
WildBlue
Somewhere
2024 F150 Lightning Flash
Is it possible to setup AA in the Lightning to only be used when physically connected with USB cable? And then just use Bluetooth if not connected with cable? My truck keeps connecting AA wirelessly and that's a problem for me because it losses signal frequently during my drives due to some interference along the way.
3rd rock
Automotive Technician
Yes you can, just make sure the USB cable can xfer data and not just a charging cable. Android 9.0 or higher.
BennyTheBeaver
2023 Lightning XLT ER
I think I understand what you are asking...
If I remember correctly, there is a Wireless App Projection setting in the Settings menu (probably Connectivity), disabling that might achieve what you are looking for. If that doesn't work, you can also disable Wifi on the truck.
I'm going from memory here, sorry.
I believe you simply plug in the phone to the cable.
MillieChliette
Even plugged in, sometimes mine is connected wirelessly. Not sure how or when it makes the decision to use wired vs wireless when plugged in, but it's definitely a thing.
Athrun88
Toronto, Ontario, Canada
Pretty sure even if you are using the wire for AA, there's still a BT connection for calls and such. Least that was how it was when I was using a wireless AA dongle in my previous Subaru and wife's current Q6.
B177y
Olympic Peninsula, WA
I use mine exactly how you are trying to. Turn the "Wireless App Projection" toggle off (I need to double check the name), then AA only uses the cable to connect. I use mine this way daily.
On the phone, goto settings/connection/WiFi settings/Advanced/Manage networks, look for projection SSID {PROxxxxxxx}, select, turn off auto-reconnect.
You just need to turn your phone WiFi off and plug in. It still uses the Bluetooth but it doesn't drop out.
On my Android phone there is a helper routine in Ford App that automatically switches the wifi mode back on after manually turning it off.
pscytzo
Dane
Colorado
2025 F-150 Lightning Flash
I just want a button. That the phone doesn't auto connect until I click the button.
That's an odd one. My Bluetooth comes on automagically when I plug in but it doesn't touch the WiFi.
Android is pretty customizable though so I imagine it's a setting somewhere.
B177y
Turn the App Projection toggle to OFF in the SYNC screen.
I may have misspoke, the phone wifi controls also has a feature to reenable when in the vicinity of saved SSID's, customizing that will help, only disable the projection SSID's
Ford F-150 Lightning Android auto without wireless? 1776537744165-id
Ford F-150 Lightning Android auto without wireless? 1776537759171-km
Ford F-150 Lightning Android auto without wireless? 1776537780415-8c
