Barrels
- First Name
- Steve
- Dec 21, 2022
- Washington
- 2018 F150 3.5L
- Occupation
- Retired
My 2023 Lariat has 25K miles and had been flawless. We stored it as we have before during the winter in our garage. Per the manual I set the charge limit to 50% and charged it, disconnected the 12v battery and put it on a tender. On opening storage I reattached the 12v and noted that the frunk would not close by itself. The truck started and I saw the wrench icon. It drove normally for a short trip and I returned home and tried to charge. It charged to 60% and stopped.
I found the fault in the app. I tried a reset by disconnecting the 12v waiting 10 minutes and tried again. I noted the charge limit was 50%
and reset it high. Now I got:
- a new fault, trailer brake system, in addition to the power train
- frunk didnt close by itself. It does open
- truck charged +2% and stopped
- charge limit keeps resetting to 50% despite me setting it to 90% in the truck
so I tried removing the 12v and charged it overnight using a charger. The charger showed success and 12v tests at 13.07 volts. I reinstalled it, waited 30 minutes and tried again
- power train fault still there
- trailer brake fault gone
- frunk will now close by itself
- truck initially would not charge. Got a red ring. Reattached plug and got it to start charging after resetting the limit. Charging stopped shortly thereafter
i tried using the level one charger and results were the same. I will check this am to see if waiting overnight changed anything.
Seems like it mostly likely a 12v battery or software issue, or a BECM logic fault or module. Less likely a HV hardware since messing with the 12v produced some changes.
If nothing has changed this am after an overnight wait I will contact the dealer and hope they can see the truck soon.
