Jim Lewis
- First Name
- Jim
- Jan 10, 2023
- San Antonio, TX
- Honda Accord 2017; 2023 Lariat ER
- Occupation
- Retired
Since I usually only drive on very short trips around town (< 10 to 15 miles roundtrip), I normally charge my truck to only 50%. The FordPass app has been very reliable in general about respecting that limit. But a couple of weeks ago, I accidentally charged my truck to 100%. In trying to figure out how I managed to do that, I noticed several places where the GUI designers were thinking of ease of use without considering the consequences of tapping or swiping accidentally in the wrong place, @Ford Motor Company.
The Ford app has been updated a time or two in the intervening weeks, so right now, it doesn't seem as easy to do the wrong thing as it did several weeks ago.
The first thing I noticed in trying to find out how I accidentally hit 100% charge is that when one looks at the Charge Complete Details that show on the FordPass app Home tab, one sees the following:
The interface here is something that may have been improved since my 100% charge accident. IIRC, the "helpful" Charge To 100% button used to be a lot closer to the bottom of the screen. Very helpful to the user in quickly making that choice. But the developers didn't consider that an iPhone user typically dismisses an app or tries to view the App Switcher by swiping up from the bottom of the screen. Perhaps the developers were wrongly assuming that everyone should exit this screen by hitting the closeout X at the top left of the screen. Now the Charge To 100% button appears to have moved a lot further up the screen and is harder to hit by accident. When the vehicle is charging, just showing the end target charge % on the Charging Session button of the Home screen tab without going into the Details subscreen would help alert the user on how the charge session will end up.
The cause of my charging to 100% appears on the following screen.
The Charge When Plugged In option, which will ignore the charging limit and charge your truck to 100%, is cleverly set right next to the address of a Saved Location that you tap to open up the Preferred Charge Settings. Apparently, at some point in examining my charge settings, I accidentally tapped Charge When Plugged In, and the next time I plugged in, off I went to 100%, and I found the radio button set on the Charge When Plugged In setting afterward in searching for how I hit 100% charge.
The last GUI problem also seems to have been improved since my 100% charge accident several weeks ago. Then, just brushing across the screen by accident in the vicinity of the Weekdays or Weekends sliders would easily move the charge limit from my typical setting of 50% to 100%. Now, it seems like one has to decidedly tap and hold to get the slider to move. A marked improvement, IIRC, over the previous behavior.
My wife had the ultimate answer to these conundrums. She said if the app can send you a warning when the charge is too low, why not have an option to get notified or need confirmation when the charge limit goes above a preset global limit, i.e., request confirmation to start and then notify me when the charge is about to go above <name your limit, 80% for me>. The confirmation/notification option would be something that could be turned on or off as the user desired.
