Portable EVSE Amps over 110v/120v
SmoothJ
New Jersey
2022 F150 Lightning
Over 110v/120v, do we know if the portable Ford EVSE is 8A or 12A? If 8, and can we try to set it to 12A?
It's 12amps, and you can't set anything on it.
Firestop
Firestop
FWIW, while waiting for my FCSP, I decided to conduct a home garage charge test last weekend using Ford’s portable EVSE.
Data readings were taken from the FordPass app, so, while not completely scientific, I feel this test provides no surprises and a reasonable expectation of home 120V charging based on these parameters:
Lariat ER @ 76% SoC, 20A@120V Garage outlet - direct plug-in; truck off with doors closed
76%-90%
in 24 hrs - 26 kWh added
Charge Rate: 1.083 kW/hr (26/24)​
76%-100% in 38 hr, 37 min (38.633 hrs) - 41 kWh added
Charge Rate: 1.061 kW/hr (41/38.633)​
The math says this isn’t sustainable without a more effective home charge solution….even a FCSP de-rated until @Ford Motor Company ? can fix and deliver the EVSE they promised…..?
cc: @LightningMcQueenAlbany , @PV2EV
cvalue13
Austin, Texas
ā€˜22 Lightning ER Lariat
Fun-Employed
Seems consistent with my experience. Eg from 75% to 92% in 29hr45min
What’s less clear for me - here in Texas charging outdoors with >100 degree days - is whether there is a material change in charge rates between ambient temperatures.
1kW per hour is the correct number. We charged our 2021 Mach-E from 10% to 100% in just over 3 days while at my son's house.
I used mine at L1 on my Mach-E last week while at a vacation cottage. Daytime temps exceeding 100F. The charge rate didn’t seem to decline day vs night. Anecdotal observation only - I didn’t measure anything.
FlasherZ
St. Louis Metro
Seems about right. Might work for someone who only drives 10 miles a day and occasionally takes a slightly longer trip, but 120V is more of a convenience/emergency charge than anything. We plug in to an accessible 120V receptacle when on vacation, but it pretty much just gives us enough that we don't have to interrupt vacation to go fast charging.
cvalue13
Austin, Texas
Fun-Employed
By what observation would you have observed relative charge rates, even anecdotally? Is there a display of this in the Mach-E not in the F150L?
I’m a newbie, so I’m missing lots of context.
I’d assume the only way to test would be several periods of data, each charging from and to identical percentages, half the periods performed overnight, half performed midday.
Otherwise curious what if anything the F150L might do for the batteries when temps approach 115+ ambient (as is easily the case on my driveway for hours a day).
I observed that the % charge gained per unit of time stayed constant. I gained 11% in 10 hours, both day and night. Note that % charge resolution is only to the whole number - no decimals. Outside temp peaked at 102 one day. The car was partially shaded.
The level 1 charge rate is so slow, I don’t think temps have much affect. One thing for sure, the L1 Charger cannot supply enough power to provide any battery conditioning….it barely charges the battery.
cvalue13
Austin, Texas
Fun-Employed
So then you checked the charge gain, on equal intervals, relative to day and night, and for equivalent battery charge levels? Eg you checked at say 10AM and then 8PM, from a 70% charge (to determine day/hot charge rate for 10hrs at the 70% charge level), then another day at say 10PM and then 8AM, also from 70% charge rate?
or at least, some rough version of this, apples-to-apples?
This is sort of the basis of my question in a way. My admittedly ignorant understanding is that at some high temperature EVs might, e.g., actually ā€œwakeā€ to provide cooling to the batteries, or some other functions. If the F150L does anything like this, then during the hot part of the day I would expect there to be possibly a negative charge rate given how little comes off the 120v?
Anyhow, zero claims to understanding or authority here, just learning.
That’s pretty much what I did, but nothing precise or scientific. I plugged in when we got there late PM. When I got up in the morning, I looked and noticed slightly over 1% per hour. We didn’t drive anywhere that day and that evening I looked again and figured the rate was pretty much the same as the night before.
The truck won’t try to do any battery management on L1. Charging at roughly 1KW won’t even move the needle on battery temp.
FlasherZ
St. Louis Metro
My observations are that there are some differences in various weather. In my experience with another brand, a car that normally gets 3-4 miles per hour it's plugged in might only get 1 mile per hour of charge in winter because even the 1800W being pumped into the battery isn't enough to keep up with the weather's cooling tendencies. In the summer, I haven't really observed any reduced charging rates with 120V due to needing pack cooling... but I don't live in Phoenix.
cvalue13
Austin, Texas
Fun-Employed
Rather than heat from the charging itself, I was more curious if it might respond to the 120° ambient temperature at the pavement
FlasherZ
St. Louis Metro
I don't think that's too much of an issue. With some high-performance EV's, setting the super-performance mode actually caused the car to WARM the pack to 50 degC (122 degF) for performance.
