PU-Sync-25.2.1.6.5 - Walk Away Lock Toggles: Post 203 Final FIX!
rugedraw
Javier
Miami
Auto Sales
How much does one risk warranty problems by going over to the "dark side?" For instance, I've got the part to install the overhead console motion sensor removed from 2023 vehicles, but wondered, since it's not officially supported for 2023 Lightning vehicles, whether I'm going to have Ford problems down the line, even if I successfully install it using the wonderful instructions folks on this forum have created for doing so.
The only thing that would not be covered is whatever you added that wasn't there from factory.
Ted23Lightning
Ted
Mobile ADAS Technician
If your meddling causes a failure, warranty won't cover it. The dealer has the burden to prove it, but I've heard that sometimes it's turned into a disagreement.
If you fry something when installing the sensor, or brick the truck using Forscan, yeah, warranty won't cover it. But if there is some sort of failure they blame on you installing the sensor and tell you warranty won't cover it, tell them to prove it.
As an aside, I suppose one of my pet peeves, I don't like it when people use the term "voiding" the warranty, such as "if I do xyz to my truck will it void the warranty?" The only thing that comes to mind that voids the warranty is if it's salvage titled. Warranty not covering a failure because of you doing xyz is not voiding the warranty. The warranty is still in effect and will still cover the rest of the truck.
U tryin to tell me my 2 foot lift kit wouldn’t be covered under warranty!?!? Ridiculous
lipnorth
Connecticut
2023 Ford 150 Lightning Lariat
Only took a few years but month or two ago I got a software update and since then I have ZERO wireless CarPlay issues.
What a relief.
frautumn
Fred
Northern CA
2022 Ford F-150 Lightning Lariat
Hmm, now that you mention it I haven't had this issue with my CarPlay audio in at least a few weeks. Fingers crossed it's fixed!
WHICH update was that? should mention this feedback in that thread, or I can move these post there.
What a relief.
I gave up on BlueTooth streaming music from my audio devices - drop outs disconnects etc. - and use a hard wired SSD now.
Thanks, I'll have to try it again and see if its better, assuming I got the OTA update.
Apparently I did get the update on 07/17/2025 so hope it helps.
lipnorth
Connecticut
Ok I was able to go to my truck and take a picture of the update. It’s been a while.
it looks like SYNC-25.2.1.6.5
since this update I have had zero wireless CarPlay issues where before I had an issue every 1 out of 5x
Ford F-150 Lightning PU-Sync-25.2.1.6.5 - Walk Away Lock Toggles: Post 203 Final FIX! 1754415958595-pa
Moved posts #153 to #157 to this OTA thread as the likely "positive" solution.
ThunderSnoww
Kevin
Detroit, MI
2023 F-150 Lightning - Lariat ER - Antimatter Blue - BC 1.4 (on 08/15/25)
What a relief.
I've noticed the same. I did have one Sync 4A screen freeze up since, but besides that, I haven't be employing any of my "tricks" to avoid CarPlay issues (i.e. pausing audio before turning off the truck). So far, so good. Was going to mention it to the dealer at my 20k tire rotation next month, but now I'm reconsidering. I am still curious to see if it's worth getting TSB 25-2105, but now I'm concerned I'll "re-break" it. I'll follow up if I run into renewed issues.
NeighborGeek
2025 F150 Lightning Flash
Well, here's hoping this update comes to my 25 Flash soon. I'd really love to have bluetooth audio streaming work reliably.
MichaelCA
MichaelCA
You're right. I havent had a carplay issue since either! I am on IOS26 too though.
Whitetiburon
MARK
2022 Ford F150 Lightning Lariat extended range
First of all, thank you to this forum for helping us escalate internally.
Some F-150 Lightning customers (including folks in this thread) recently received a software update with release notes stating they received the Walk-Away Lock Feature. Unfortunately, the release notes were sent in error and the feature was not delivered. While we are working to deliver the Walk-Away Lock feature on equipped vehicles with Keyless Entry, the feature is not available at this time.
The team apologizes for any inconvenience and confusion this has caused. We look forward to sharing an update when it is ready for you to use.
Thanks for the update, looking forward to the feature when available.
NAVEWO
Tucson, Arizona
2023 Ford F150 Lightning Lariat ER Max Tow
Retired USAF Navigator/Electronic Warfare Officer
I just got this one today. Updated while I was running some errands this morning. I think the number is the same SYNC-25.2.6.1.5 but unless I’m mistaken the release notes are different. I’ve had walk away locking for some time but wanted a ā€œchirpā€ when the locks engaged to let me know the lock had happened. So got a few new ā€œtogglesā€ under locks and confirmation chirp was one of them. I’ll post a screenshot of the release notes I got with this update. Seems it also included some Blue Cruise stuff.
Ford F-150 Lightning PU-Sync-25.2.1.6.5 - Walk Away Lock Toggles: Post 203 Final FIX! IMG_9062
The Weatherman
South Central KY
A lot of people here are fussing about the horn honk on lock. I personally use the fold mirrors on lock and just glance back at the truck.
PJnc284
Garner, NC
Interesting. You seem to be the first with the note about the blue cruise toggles.
